Discontinued power IGBT
I'm trying to find the specs on a  discrete power IGBT.
It is probably a discontinued product.If it is what I think it is,it is quite valuable
as I can use them for a high power H- bridge inverter for my welder to convert DC to an alternating square wave for welding Aluminum.I can also use the same IGBT for a high current controller coupled with a PWM and suitable gate drivers;mabe even for an induction heater circuit.
  • ammoniaman Oct 18, 2007
    The part number for the discrete power IGBT is 12-713200-00.It
    was made for Fuji Electric by the Toshiba Corp.Apparently this is a
    hard to obtain milspec quality discrete power IGFET that cost $228.00 each.If they are high enough current capability,these would be quite useful.
    Excuse me!That's IGBT not IGFET.
  • 363 Answers
This is a fairly ordinary 200 Amp, 600 Volt IGBT. It might cost this much because they just aren't made anymore.
Unless you wanted this part for a specific reason that you didn't mention then I think you'd be better off buying some more modern 'bricks' with better performance.
I got five 600amp 1200volt IGBT's for $100 off ebay a few months ago.
An avenue of research that might be of interest to you would be SSTC or solid state telsa coils. Google searches will find you many SSTC sites with IGBT H bridge circuits and drivers basically doing the same thing as you are intending.
Posted on Oct 18, 2007
Graphics card
Graphics Search for products based on specifications GPU type Intel HD Graphics Integrated / discrete graphics Integrated Check out this WEB sites for the full specs.
Apr 22, 2013 | Acer Computers & Internet
My nikon coolpix l110 is now dead. not powering on. 300v dc is shorted with the gnd. IGBT is short. what to do
Fixya does not provide manuals of any kind. If you are unsure of what you are doing, you should take it to a reputable repair facility.
May 15, 2017 | Nikon Cameras
Thyristor for cdi
Triac or SCR? Either way for the discrete 3 terminal device, go with a 1000 volt 8 Amp device. A Triac can replace an SCR in some circuits. Depending on triggering source, sometimes a "Sensitive gate" type is needed for trigger pulsea that are only about 2microAmp.
If you have the specific specs for the discrete device, you can scroll through the products available at Digikey and enter Triac or SCR into the search criteria, and then you can narrow the choices down by the filters.
Feb 08, 2012 | Motorcycles
When i plug the electricity it start to maximum power uncontrollable , please help, thank you
You have to check the Driver circuit board for the motor. There is motor control IGBT Insulated Gate Bipolar Transistor) in this board .If the IGBT is short then the treadmill will try to run at high speed without setting any value or witout pressing the start button. You have to check the OHMS between the seocnd and third of lead of the IGBT. If it shows less than 100 Ohms then the IGBT is short and you have to replace the same. Also you have to check the connection to the control pannel. Is there is any loose conatct. Remove the connection in the motor control board which go to the control pannel and reconnect it. Also check the speed sensor. In most of the treadmill you can find the speed sensor near the motor pully. Remove the speed sensor and clean it and the refix it. Remember one thing remove the power of the treadmill and leave it for 30 minutes then only oppen the treadmill. Because there is high voltage storage capacitors in the motor control board which will hold charge for some time even after the power is disconnected. i ahve added the picture of IGBT for your refference
Aug 15, 2011 | Weslo Cadence Ct 5.8 Treadmill
What IGBT demeged
hi pradeepkambl.
good day.. UPS manual is the IGBT manual..
Jan 18, 2011 | Emerson PowerSure Personal 500VA...
I lost my power supply adapter/transformer....there is no manual....what size do i need for the adapted/transformer
The last item on this page is the user manual for the Xantrex 300 This is a pdf. Right click, and "save as"
I would suggest it will be almost identical to your 200.
From personal experience, I imagine it uses 12volt lead acid sealed cells, Typically this would use a 13 to 14 volt powersupply probably at 2.5 to 3 amps.
You can also charge the device from your cig lighter socket. See pg 16 of manual.
Jan 16, 2011 | Xantrex Technology XPower Powerpack 200...
E30 IGBT fault If an excessive current is applied at an IGBT (transistor in the power end stage), the output voltage
is switched off to protect the transistor.
Sounds like maybe a fan has gone bad and is drawing too much current.
Try disconnecting the fans and reconnecting one at a time. Also check
the fans to make sure they turn free and are not blocked.
Aug 17, 2009 | Electronics - Others
Does anyone have the voltage specs on a PNT-426 Power Supply. It is for my NEC PlasmaSync PX-42VM5A Monitor. My electrician has found a faulty diode but doesn't have the voltage specs on it. I have a...
I have a PX-42VM5A and my Power supply is a PNT-426 (by Sanken Electric Co. LDT). Here are my specs: INPUT: AC 100-240V; OUTPUT: (there are nine outputs) +170v 1.6A; +60v 1.6A; +5v 4.0A; +2.5v 1.9A; +3.5v 1.9A; +7v 1.0A; +12v 0.5A; +12 v 1.9A and +6v 1.2A
Jun 17, 2009 | NEC PlasmaSync 42VP4D 42 in. HD-Ready...
Manual for UPS Model P2-1000C
it seems you have a knack about inverters? why dont you just pull up a circuit and build it inside since you have not been able to get a solution to the repair you did.
May 12, 2007 | Exide 850ERT 850VA (fc010bb2a0a0a0a) UPS...
Open Questions:
Computers & Internet Logo
267 people viewed this question
David Payne
David Payne
