Question about Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water
I have an Amana SBI20NW and want to replace it. How many cu ft is this refrigerator?
aborcass
  • 2651 Answers
SOURCE: Filter change
didnt post the model number, but a general rule of thumb is the filter is in top right section of refrig compartment, a counter-clockwise turn will unscrew and rescrew the new one in
Posted on Nov 16, 2008
rpbuice
  • 161 Answers
SOURCE: Ice build up in freezer
Defrost system failure.
Defrost timer, heater, therma disk, any one could be bad.
You could manually defrost and this would get the Ref back to working for a couple of days before it iced up again. Remember there is a lot of ice build up on the cooling coils in the freezer that you can't see so, a little extra time with a hair dryer is needed to do a complete manual defrost.
Posted on Jan 21, 2009
  • 61 Answers
SOURCE: heat along inside of doors
this is normal the refrigerator has a heater that runs between the doors to keep mousture from building up there. There is no reason to be alarmed.
Posted on Jan 23, 2009
SOURCE: How to replace the rear wheel on Amana 22.1 cu.ft refrigerator
Remove anything in the unit that could spill or tip over. Raise the front leveling legs to allow unit to roll. Slide the unit out from the wall. Place something between the refrigerator and the wall to protect surfaces. ***Make sure you have someone to assist with this next part. Tilt unit to the side and lean it against the wall to raise up the roller to be replaced. There is a metal base that supports the rollers, compressor, condenser and fan motor. You will see a heavy duty metal pin that goes through the roller. Bend down the metal tab in the base to remove roller pin. Replace the roller, reinstall bin and bend the tab back up. Carefully set the refrigerator back down on all four rollers. push back in place and screw down the front leveling legs.
Posted on May 02, 2009
Sheikhtijani
  • 1284 Answers
SOURCE: Proper refrigerant levels for Amana Side by Side refrigerator
Hi, normally the suction pressure on a refrigerant -22 system will be between 60 pounds gauge pressure (which keeps it above freezing point) and about 80 pounds. This depends on the temperature condition.Make sure that the superheat and subcooling are correct to see what is to be considered normal for the conditions you have present.
Take care
Posted on Jun 03, 2010
How many cu. Ft. Is the Amana TR21VW?
The 21 in the model should be the cu. ft size.
Apr 02, 2015 | Amana Refrigerators
I am looking for a compressor for 220volt for Amana food center SBD522VE
Fixya does not sell replacement compressors. Check with a local appliance parts supplier.
Mar 30, 2014 | Amana 22.6 cu. ft. Side-By-Side...
What is the cu. ft. of this model refrigerator Amana TZ21Q2L
Per my Manual , The Amana TZ21Q2 is 21.1 cu ft. and energy guide $69
Apr 02, 2011 | Refrigerators
Take care
Jun 03, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana 25 Cu. ft. French door Freezer Fridge quit
IN MOST CASES THERE IS A FAN THAT SENDS COLD AIR FROM THE FREEZER TO KEEP THE FRIDGE COLD. EITHER YOUR FAN MOTOR HAS GONE BAD OR YOUR THERMOSTAT IN YOUR FRIDGE IS BAD.
Feb 20, 2010 | Televison & Video
Frig is not cooling, fan is running but not the compressor?
compressors thermal overload relay needs to b replaced , or starting and running capacitors to b replaced
May 24, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Filter change
Nov 10, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Water from chilled water dispenser on my amana side by smells bad and tastes bad
its either the icemaker itself or could be water actuator padle needs replacing.
Aug 12, 2008 | Amana 22.6 cu. ft. Side-By-Side...
Amana 22.6 cu. ft. Side-By-Side Refrigerator with FrontFill Ice and Water Logo
52 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
