Question about YouTube Videos
PST 800 PEL
Bosch jigsaw operation of PST 800 PEL jigsaw, fitting blade
A bosch PST 54PE jigsaw...the blade falls out when in use
If it works like mine, you need a long, thin screw driver (flat) to tighten a screw that holds the blade. The screwdriver goes in, in line with the blade, on the opposite side.
Jun 12, 2017 | Bosch Saws
I have a Bosch Jigsaw Xcel PST. I purchased the Jigsaw about 6 years ago but it has not been often used. Recently the blade will not lock into and remain in position for cutting. I cannot find my manual...
You will need to obtain a new [Roller Lever Assy] from a Bosch parts dealer. Its a fairly simple install. This is a wearable part due to the pressure put on that portion of the tool during normal use.
Feb 07, 2011 | Bosch Garden
How do i change a blade for my jigsaw pst 50a
there should be a allen head bolt in a slot at the top of the blade. you loosen it and pull out blade , replace blade and tighten bolt back up. hope this helps. have a good day,
Jan 08, 2011 | Bosch 24V Jig Saw W/ 2.4 A H Battery...
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 | Bosch Saws
WANT TO FIND PARTS LIST FOR BOSCH PST 54 PE JIGSAW
you can trying going to Boschtools.com and you will need the exact model number, the parts list section is on the left hand side of the page towards the bottom.
Jan 25, 2010 | Bosch Saws
Bought a jigsaw a bosch pst 54e how do i change the blade.thanks
In the handle directly over the blade is a deep hole. You insert a long thin bladed screw driver into this hole all the way down. Twist slowly and it will locate with a screw. Undo the screw and then twist the remaining piece of blade 90 deg and pull. Replace new blade in the opposite way. Twist it so that the cut is to the front and then tighten up the screw. Do not tip up the unit while doing this as the screw might drop out and you might loose it
Sep 24, 2009 | Bosch Saws
YouTube Videos Logo
19 people viewed this question
Top YouTube Computers & Internet Experts
Rizwan Hanif
Level 1 Expert
Michael Terence...
Michael Terence...
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
