Question about Maytag Kitchen Ranges
Oven door latch won't retract
F9 shows on the display
catriver
  • 878 Answers
SOURCE: Oven door locked, F9 indicator signal
Monster, F9 is the door locked error. Try turning off the breaker for 30 seconds and see if it resets. If not, you are going to have to get a coat hanger, make a U at one end and slip it between the door and latch from the left. Once you feel the latch, give it a tug and the door should open. Try resetting the board again with the door open and see if the lock mechanism homes. If not you will have to check the cam and switches for problems. Catriver..post back.
Posted on Oct 06, 2006
aborcass
  • 2651 Answers
SOURCE: F9-4 when cleaning upper oven
its related to the self clean ltach motr, if you pull hte unit out and drop teh rear panel, approx halh way down on theright side( when behind unit) thers asmall lock mechinisn mavbe 1.5 round, with a connecting rod 2 wires and a witch, well that motor sometimes as it heats looses connection with the switch. the switch is monitoring door positoin so if it loses contact it thinks the door is open and will trigger a code. the entire latch is replacabel (FRont to back comesa sone assy latch motor swittch and rod. 2 wires connect it and 2 screws(by front latch secure it. if youtry to replaceit your self i giveyou the heads up to lie a yard stick on top of latch before removing old latch (thos will keep the insulation in place) andthen when installe ing new latch also use hte ayrd stick ontop to keep insulation inplace!!!!!
Posted on Mar 10, 2008
SOURCE: F9-6 fault code on maytag gemini double oven range
I waited until the next morning and hit the cancel button. It cleared the error
Posted on Sep 17, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Jenn-Air free standing range: displays
Hello there
This a common problem with these
F9 Door lock safety circuit on power relay board sensed Replace power relay boardok I would contsact the nearest appliance parts repair center to see if this can be replaced and how much it would cost and mayby you can do it yourself it would save you a lot of money ok?
hope this is very helpful for you
Best regards Michael
Posted on Jan 18, 2010
blueextc3221
  • 15935 Answers
SOURCE: I have a Frigidaire oven model # 316244485. I
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!@!@@#@#$
Posted on Oct 01, 2010
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
Oven door is locked and digital display says F9
F9 is a door lock error. Try starting and then canceling a clean cycle. If that doesn't work you need to check the door latch motor and switches. You access the latch motor and switches by removing the left side panel. It may just be a bent latch rod.
Mar 06, 2011 | Maytag MER6772 Gemini Electric Kitchen...
Oven is locked and F9 is being displayed, what do I do?
Hi
Thanks for using FixYa.F9 is a door latch error, you’ll need to check the door latch. This is a Problem with door lock circuit such as pinched wire between Electronic Range Control (ERC) and door lock switch. You’ll need to check wiring and replace the door latch assembly if required.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jan 14, 2010 | Maytag Ovens
The oven isn't working and it says FO in red letters
GE / Hotpoint / RCA
Oven Fault Codes
Display Condition Remedy
F0 & F1 Failed Thermistor Control Replace ERC
F2 Oven Temp Exceeds 590 with unlocked door High resistance in Sensor, likely a bad sensor
F3 Open Sensor circuit Open (blown) sensor fuse or bad Sensor
F4 Shorted wire or Sensor locate short and correct it
F7-A Function pad button stuck Clean and unstick
F7-B Bad Clock Replace Clock
F8 Electrical component failure Replace ERC
Frigidaire / Westinghouse / Tappan / Gibson
Oven Fault Codes
F0 & F1 EOC failure Replace EOC
F2 Oven over heat Defective Sensor or EOC
F3 Oven Sensor Open Replace Sensor
F5 EOC failure Replace EOC
F6 EOC failure Replace EOC
F7 EOC failure Replace EOC
Maytag / MAYCOR / Magic Chef / Jennair / Admiral
Oven Fault Codes
F0 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F1 Defective Touch Pad or Membrane Replace Touch Pad or Membrane
F2 Oven over heat defective Relay Board or (if present) or defective Sensor
F4 Shorted wire or Sensor locate short and correct it or replace Sensor
F5 Hardware, safety circuits disagree Replace Clock
F6 Missing AC (power) signal Check for proper voltage (plug, breaker, etc.)
F7 Function key shorted or stuck button Clean and unstick button or replace Touch Pad or Clock
F8 A/D Warning Replace Clock
Amana / Caloric
Oven Fault Codes
Type with display - glass link ERC
F0 No Safety Signal Replace adapter board
F1 No Safety Signal Replace ERC
F2 Oven over heat Replace defective Sensor
F7 Shorted Touch Panel Replace Glass Panel
FF Lock Error Check switch and motor
ERC III - Relay board with separate board/push buttons
F0 Shorted Push Pad Replace Push Pad
F1 Defective ERC Replace ERC
F3 Oven Sensor Open Check/Replace Sensor
F5 Defective ERC Replace ERC
F6 Defective ERC Replace ERC
F7 Shorted or sticking button Clean button or replace touch pad
F8 Defective ERC Replace ERC
The following diagnostic chart Does not apply to Whirlpool 'Y' line products. If the model number contains a Y near the end of the number, DO NOT use this chart.
Whirlpool / KitchenAid / Roper
Oven Fault Codes
Ovens with 4 digit displays
F0-E0 Analog to Digital failure Disconnect panel for 30 seconds. if error re-appears then replace control
F1-E1 Defective ERC Replace ERC
F2-E0 Shorted Keypad Replace Keypad
F3-E0 Sensor or Sensor Fuse Open Replace Sensor or Fuse
F3-E1 Shorted wire or Sensor locate short and correct it or replace Sensor
F3-E2 Oven over heat Replace Sensor
F3-E3 Cleaning Temp over heat Replace Sensor
F5-E0 Door Error Check Door
F5-E1 Door Latch Check Latch
F5-E2 Door Switch Check Switch
Ovens with 2 Digit Displays
F0 Defective ERC Replace ERC
F6 Problem with time keeping circuit Reset Time or cooking operation and check for proper ground
F7 Shorted or sticking button Clean button or replace ERC
Dec 18, 2009 | Ovens
Getting F9 Code & beeping
Hi. this fault code represents a door latch fault. You will need to inspect the door latch components. Once this issue is fixed, it will start to work normally. Its nothing serious like a control board or power supply board. Its juts that the door latch components are malfunctioning.
please rate and god bless..
Mar 24, 2009 | Maytag MGS5770 Gas Kitchen Range
MICROWAVE WILL NOT HEAT. F9 APPEARS IN THE DISPLAY WINDOW
F9 indicates a problem with the door latch.  There is a safety switch that will not allow the microwave to operate if it detects the door is not closed properly.  Even though physically it may seem the door is shut, the safety switch is not relaying the message to the onboard computer.  You need another door latch switch.
Mar 10, 2009 | Kenmore 63663 Microwave Oven
Kemore microwave model number 721.63763300
F9 is an error that indicates an inverter board or magnetron
has failed. With the F9 error cleared, start the oven and
listen for a ticking sound. The inverter will attempt to
'fire' the magnetron 5 times.(ticking sound). If can hear
ticking, replace magnetron. Check owners manual. Part may be covered by limited warranty.
Mar 26, 2008 | Kenmore 62622 Microwave Oven
F9 code on stove
Here's what F9 code means:
1. Door lock safety circuit on ERC sensed Replace the door latch assembly
2. Door Lock Warning Check door lock circuit or Replace Clock
Try pressing and holding the door latch to unlock position and then press cancel for a few seconds. The latch should return to its original position.
Jan 23, 2008 | Ovens
Kitchen Ranges Logo
16 people viewed this question
Top Maytag Kitchen Ranges Experts
Lawrence Oravetz
Joyce Nokleby
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
