Question about Canon LBP 660 Laser Printer
Paper stuck in the machine. I"cannot get it out. How to handle thsis problem without a manual, that explains how to deal with these kinds of problems.
Ik would like to receive the manual of the Canon LBP 660, that I'am using during some years. By now, the paper has stuck and I do not know how to handle. I hope, the Manual can help me out of trouble. that I'm facing now.
    New Friend:
I need a manual for our Canon LBP5050 because the mover company didnt pack include it when we move to new location. Where can I download it? I visited the Canon wedsite, but I couldnt download the manual. Im having some problems with the printer. So, Id like to check it myself the manual.
Thank you very much.
Posted on Jun 28, 2013
  • 3 Answers
You can try contacting Canon themselves for the manual. http://www.canon.co.uk/Support/User_Manuals/index.asp
I haven't been able to find it free to download on the internet anywhere.
Posted on May 20, 2009
Paper stuck in machine...can't find where to 'losen' the grip of rollers
You don't say which printer you have but you can get the manuals at;
http://kmbs.konicaminolta.us/kmbs/support-downloads/user-manuals
that should explain how to clear paper jams.
Aug 30, 2015 | Konica Minolta Office Equipment & Supplies
Had been fixed 10-12 times
Whether you have a copy or not, the dealer(s) should have it all on record. If they repaired(or tried) to repair it that many times without success, they certainly are required to stand by their work, and if they won't I'd contact chrysler owner relations dept in your manual and explain to them. Quite often if it's a legitimate complaint, Chrysler will contact a dealer and have you bring it in for evaluation and /or repair.
Feb 09, 2014 | 2008 Chrysler 300
I have problompeper is stuck up side pls solve my prolom your problem for a solution...
hmm i believe you might have a hardware problem. can you explain the problem more in details like your paper get stuck from the feeding place below or before getting out. this kind mostlt called paper jam or stuck
Sep 12, 2012 | HP LaserJet 1320n Printer
Hi, we run a canon ir 2016i in our office, and frequently the paper feed doesn't work properly. Especially the paper out of tray 3 and 4 gets stuck almost all the time. But quite often the paper f
The only thing I can think of, without actually seeing it work, is the feed rollers. I've never liked the feed system on this model, seems to be very temperamental. It could also be the feed clutches. There was a modification that should have done years ago dealing with the feed system. I don't know if this applied to the extra two cassettes but the two upper paper pick-up assemblies were to be replaced. Gears were updated.
May 08, 2017 | Canon iR 2016i Black and White Copier
Brother MFC 3360 - a few small pieces of paper are
On the machine display,use it to find the model that has only one cover then follow its instructions.Then get the right amount of paper that the printer can handle.
Feb 15, 2010 | Brother MFC-3360C All-In-One InkJet...
WHEN I PUT THE BLANK PAPER AND PRESS PRINT, THE PAPER DOES NOT GO DOWN FULLY AND IT GETS STUCK. I DID TRY SHAKING IT AND PASSING A PIECE OF PAPER THROUGH AND UNDER AND NOTHING YET. ANY SUGGESTIONS
It sounds like your paper stock may be too thick for the printer. Many printers do not handle paper heavier than about 26 lb. without some problems. The issue is the paper-rollers are not sufficiently strong to grab the paper, bend it toward the paper path, and then feed the paper into the machine.
Try using a lighter weight paper - 20 to 24 lb. max., and see if the printer does a better job for you!
Jan 04, 2010 | Lexmark X4550 InkJet Printer
The paper went through and got stuck, and I do not know how to open the machine to get the paper out, nothing in the manual
Kindly visit www.kodak.com/go/itg and follow the step by step process.Basically we have to open the back door of the printer where the power cable is.It can be opened easily by pushing the latches.You will find the paper stuck between the rollers.Take the whole paper out and do not tear it.If facing any problem call kodak @ 1800 421 6699.
Dec 16, 2009 | Kodak ESP 5 Printer
When we put paper in the printer it goes cricked
Lexmark printer have paper roller problem take printer for once service
Jul 25, 2009 | Lexmark X1270 All-In-One InkJet Printer
Paper jam
I do not know how much of your machine you can take apart or are comfortable to do, but you definitely need to take the paper trays out and the ink cartridge and get those things out of the way. Next lift the lid so you can see the path the paper feeds through. Do not just pull on the paper with a great deal of force to dislodge it because you may pull on a part that is not intended to move. Following the path will allow you to see where it is stuck. You may need to remove another small cover that is in the way but it will be obvious when and if you need to do that. Be sure your machine is off as you do all this. After you dislodge the paper jam blow out the paper dust that has accumulated in that area as it will cause you alot of problems. More than likely one of your blank pages was slightly bent at the top as it tried to feed through and did not feed evenly. Good luck.
Jan 13, 2009 | HP OfficeJet 6210 All-In-One InkJet...
NOISE OR PAPER GETTING STUCK IN FAX MACHINE WHILE SENDING FAX
look in or around scanner area to see if there is any foriegn material trapped in paper handling area.
This is area where the original document feeds through
Jan 22, 2008 | Brother IntelliFAX 2800 Laser Fax
Canon LBP 660 Laser Printer Logo
141 people viewed this question
old marine
old marine
