Question about Daewoo 8.0 CuFt Top Freezer Refrigerator - FR-0820BRW
Reverse doors - Daewoo 8.0 CuFt Top Freezer Refrigerator - FR-0820BRW
Can you reverse the door swing on a upright freezer. Frididaire model fffh17f1rwo
Hi Debbie,
I'm sorry, but I don't think so. There is a key that pops out when you lock it so I doubt the door can be reversed.
See page 8 of this manual under Optional Features and reversing the door swing is not listed.
On the positive side, it does have a high consumer satisfaction rate.
Happy 4th! :-)
Jul 05, 2017 | Freezers
How do I reverse the door from right to left
Usually srews at top hinge remove and lift door, same with other side, and then reverse doors, handles need to be reverse also
May 19, 2015 | Freezers
Reversing door
some can be many can't use your head and look at the hinges
May 11, 2015 | Freezers
Can the door opening be reversed
Most refrigerators and freezers have the option of door reversal......look on the opposite side of the door and there should be screw holes under plastic plugs....which will enable you to swap the hinge to the other side.Here are a few pics for reference.
Feb 19, 2015 | Freezers
How do i reverse the doors on my ffp187b
most freezer door are not reversable if there are no holes in the top of the cabinet that may be filled with a removable plastic plug. if there are holes in the other side then simply switch all the hard ware
Mar 02, 2011 | Freezers
Door swing
yes any door swing can be reversed.take a good look and you will see the screws covered up with plastic covers .the door has to be removed first but check it out and you will see its not a big job get everything ready and it can be done within 10 minutes.adrian,,,,
Jun 29, 2010 | True 19 cu. ft. / 538 liter Commercial...
I would like to remove the door,The door has two screws holding the hindge on what type of screw driver do I need
most upright freezers have a 3/8" screw to hold the hinge to the cabinet. most also do not allow you to reverse the door so are you wanting to do something else by removing the door?
Jan 03, 2010 | Freezers
Coldtech freezer door reversal
http://www.ascendmfg.com/PDFs/CT/hdmanual.pdf
start at this web site and see if this manual will help. It has phone number on last page if you need to call them.
ColdTech is now Jimes Corp. Just Google you unit if what I have does not help enough.
Good luck to you.
Oct 21, 2009 | Coldtech 21 cu. ft. / 595 liter Commercial...
Can i reverse the way door opens
Yes. Take doors, off, switch hinges to other sides of door and fridge (there will be holes available) Then place back on.
Sep 14, 2009 | Freezers
Cannot reverse door on Electrolux fridge freezer
Basically they needed to supply an additional door mount for the left hand side of the door as well as the right hand side. Problem now sorted. Poor instructions in the manual didn't help here!
May 26, 2008 | Freezers
Daewoo 8.0 CuFt Top Freezer Refrigerator - FR-0820BRW Logo
Top Daewoo Freezers Experts
mike cooper
Ken Wieczorek
Ken Wieczorek
Nater13
Are you a Daewoo Freezer Expert? Answer questions, earn points and help others
