Question about HP LaserJet 9050 Printer
In 9040 printer control pannel is not show any thing and all the three led in action
YOU SHOULD CHANGE SMALL STEEL RAM. YOU FIRMWARE IS NOT WORKING
Posted on Jan 06, 2014
4 Suggested Answers
57 varieties
  • 1653 Answers
SOURCE: memory error 100000
This indicates that the Black Cartridge has a memory chip error or is missing. You will need to remove the cartridge and make sure there is no protective covering over the chip area orf the cartridge and then reinstall it. If the issue persists then try using a new cartridge and if it still persists you will need to call a service engineer or take the unit to a repair shop.
Posted on Sep 25, 2009
  • 1575 Answers
SOURCE: prinder show in control pannel but if iam give
Turn off the printer.
Disconnect the printer and unplug it from power.Do the same with the PC.
Reconnect them after a while.
Turn the printer on and start the PC.
Make sure the usb connections are well fixed.
Now print.
Hope this helps.Thanks!
Posted on Oct 10, 2011
  • 33 Answers
SOURCE: hp laserjet 9040 printer shows paper jam but i can't found any paper jam
This can be caused by a few problems.
1. dust in printer: get blower an blow the printer out.
2. Paper stuck somewhere in printer: look as error and where paper jam is in and inspect that part of the printer
3. faulty sensor: replace sensor
Posted on Dec 27, 2013
Testimonial: "thanks sir"
What causes paper jam in hp 9040 laserjet copiers
IT all depends on the location of the paper jam. The usual causes are bad feed rollers and fuser units.
Mar 04, 2015 | HP LaserJet 9040n Printer
Hp laserjet 9040 printer shows paper jam but i can't found any paper jam
Dec 27, 2013 | HP LaserJet 9040dn Printer
Prinder show in control pannel but if iam give print command then printer show offline in control pannel. i does not give printout
Now print.
Oct 10, 2011 | HP DeskJet D1460 InkJet Printer
Some time showing on display pannel 51.10 error
51.1 is a beam detect error.
You are probably going to have to have a tech replace the laser/scanner assembly.
Sorry for the bad news.
Jan 25, 2011 | HP 9040 Laser Printer
The green go button is very hard to push to make the copies start.
Odds are that the switches connections on the PCB are broken and the switch is not closing to make the copier work. There are two things that can be done, first is to replace the control pannel or if you are good with taking things apart and not afraid of sodering. You can take the control pannel PCB off and repair the the broken joints on the control pannel PCB.... Good Luck
Jan 12, 2011 | Canon NP 7130 Black and White Copier
My canon ip 1980 printer cannot feed paper and the led blink 1timeof green and1 time of orange
reseat the papaer tray and the cartriges .. and then look on the control pannel of the printer you will have a menu option .. there you can reset the printer. that should work.
Oct 21, 2010 | Office Equipment & Supplies
Three Black Steaks down one side of the printed pages.
The streaks on the page can be cause by 2 different things. You could have a damaged toner cartridge or a faulty fuser assembly. The first thing to check is the toner cartridge. Remove it from the printer and open the little flat that goes from side to side, it should just lift off and fold back. Look on the cartridge for the strips and see if they are there. If so then replacing the toner should solve the problem. If you don't see the streak on the toner then the fuser is the cause. To replace it you will need to order part number RG5-4110 this is available from several places on the internet (Google search) or we carry them in stock, call us at 318-769-9040 for more info.
I hope this helps, if so please rate our solution.
CCL_Tech
Corporate Computer
www.ccl-la.com
Aug 17, 2010 | HP LaserJet 6p Printer
LCD not showing nor displaying character HP Color Laserjet 5500N Printer
write down the full discription wether it is printing or not LED condition on pannel etc then i can suggest tips for any resolution.......
Jul 29, 2010 | HP Color LaserJet 5500 Printer
I have a wrnch picture
What is being diplayed on the control pannel beside the wrench is there a C05 or C70 or C some thing I need some more info.
Feb 21, 2008 | Office Equipment & Supplies
Initializing problem
Possible problems are
1- there is a paper that has not been removed and is sitting on a sensor. ( most likely the fuseropen and loofrom both sides of where the paper is supposed to came out
2-fuser is gone and needs to be replaced
if there are no paper jams, then the most likely thing is the fuser ( where it come out) is not turning on and getting HOT)
replace fuser ( not for the novice) scale of 1-10 this is a 7-8
Oct 01, 2007 | Lexmark E220 Laser Printer
HP LaserJet 9050 Printer Logo
Seeker5211
Seeker5211
