Email weatherwall the ac doesnot give cold air. it blows air but the normal air. how to fix it?
22yooper
  • 828 Answers
SOURCE: Refrigeration AC not blowing cold air
If you can hear the A/C compressor start and run then your system has lost it's charge of refrigerant. If the compressor does not start and run it could be a control problem.
Posted on May 17, 2008
koolbreezes
  • 540 Answers
SOURCE: AC doesn't blow cold air
Threr are suppose to be two sounds comming from the window unit. One, the fan sound and the compressor sounds, (this compresses the refrigerants aove room temperatures (around 240*) & send it to the back coils and remove it to room temperatures and send it to the front coils which if enough freon, it will cool to at least 40*. Turn the thermostat all the way up or down while its off and see if you hear a clicking noise which tells you the thermostat is working which that what calls for cool. If it started loosing cools little by little, then you have a leak, and leaked all the freon out! If it stopped cooling all of once, then your compressor is not kicking in.
Posted on Jun 18, 2008
SOURCE: I need a user manual
I have a single sheet "unit controls and operating instructions" as below.
Posted on Jan 17, 2009
  • 4 Answers
SOURCE: carrier air-v AC is not blowing cold air
There could be a freon leak, or just low freon levels. If this is the case, you have to call a certified a/c technician to recharge your system.
Posted on May 19, 2009
  • 587 Answers
SOURCE: carrier RV AC is not blowing cold air, compressor
If the compressor is running and the air is cool but not cold it's probably low on refrigerant.
Posted on May 20, 2009
Fan is blowing, but why not blowing cold?
? 6:22
https://www.youtube.com/watch?v=hgar6Q1lV6A
Apr 5, 2013 - Uploaded by Fixbook
It's generally either your blower motor, or blower motor ... ... And am having a problem with my ac it blows cold air normally buthot doesnt.
"Why is My Air Conditioner Not Blowing Cold Air?" [FAQ ...
www.servicechampions.net/.../why-is-my-air-conditioner-not-blowing-c...
Jan 01, 2016 | Cars & Trucks
Ac compressor cycles on and off to frequent
diagnose ac in ford is difficult process: however go to this page and read how to fix: God bless you
http://www.ehow.com/way_5444654_ford-air-conditioner-problems.html
May 21, 2012 | Ford Explorer Cars & Trucks
The AC stops blowing air for a while and then re-start working normaly.
Have you noticed that the AC quits blowing cold air when you are heavy on the throttle, or climbing a hill? Does it return to blowing cold air when you let back off the throttle and relieve the load from the engine?
If you answered YES to those questions, your AC is operating normally. AC compressors take quite a bit of power from the engine to operate. In vehicles with smaller engines, the AC compressor will disengage when there is a heavy demand for power placed on the engine, and you will not get cold air. When that demand is gone, it re-engages power to the AC compressor.
Dec 03, 2009 | 2006 Mazda 3
I need a user manual for a email brand weatherwall air conditioner, do you have one?
Dec 28, 2008 | Heating & Cooling
Ac blowing hot air
This sounds like the mode selector is stuck on heat. Under the dash is the location of the hvac plenum and you need to check the cables and levers that are on it to see if they move when heat and cold are changed as well as the lever for where the air is directed.
Oct 16, 2017 | 2002 Nissan Maxima
RE: AC does not blow cold when stopped at red light/stop sign, etc.
when your at idle speed at the red light what is your rpm gauge reading is your idle to low
Sep 11, 2008 | 2001 Dodge Durango
Email weatherwall wiring
RED-- power--r)( yellow-- cool--y) (blue--same as yellow or don't use) (green--fan--) (white--heat) these are wires from the thermostat. Now the ..........................HEY, is this a window unit or central air system!
Aug 25, 2008 | Heating & Cooling
AC works when ever.
vacuum line reserved vauum bottle crack not enought vacuum reserved when you give gas vacuum goes down that normal that why they put a reserved tank follow the vacuum line to the reverved tank check it out hope it help fixye our post thanks pierre
Jul 12, 2008 | 1995 Chevrolet Lumina Apv
Heating & Cooling Logo
47 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
