Question about Bosch KAN62V40 Side by Side Refrigerator
Display panel - Bosch KAN62V40 Side by Side Refrigerator
Display panel blank
No fuse, if you replace the display and you are sure that the display is good, then the controller or motherboard that the display plugs into is bad.
Dec 11, 2015 | Office Equipment & Supplies
How to clear the usage counter?
From Samsung site:
1. Press MENU # 1 9 3 4 in sequence rapidly. The LCD panel should now display TECH.
2. Press MENU, and then press ENTER. The LCD panel will display Tech Mode.
3. Press the left arrow (<) button once. The operator panel will display NEW CARTRIDGE.
4. Press ENTER. The operator panel will display [YES].
5. Press ENTER. The toner warning message should be gone.
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH.
Oct 18, 2014 | Samsung 5pk - Scx-4521 Scx-4321 Scx-4521d3...
Laptop all whit screen
Dell Inspiron 1420 Notebook PC?
The white screen can be fixed. How?
Connect a VGA monitor to the laptop. Connect to the VGA port on the right rear. Example of a VGA Cable, and VGA connector,
http://en.wikipedia.org/wiki/VGA_connector
You can use a CRT type monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable.
By default the display should show on the external VGA monitor.
No?
Press, and hold the Fn key down, and at the same time tap the F8 key ONCE.
Still no?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F8 key.
No display on the external VGA monitor, means you have a bad graphics chipset. Replace motherboard.
Display does show on the external VGA monitor, means you have a problem with;
1) Video Cable
or
2) Screen Inverter
or
3) LCD screen
Video Cable:
The Display Panel Cable (Video Cable for Dell), connects to the motherboard by the left Hinge.
Goes under the left Hinge, and up into the Display Assembly.
It then connects to the Screen Inverter, and to the back of the Display Panel. (LCD screen for Dell)
From normal opening, and closing of the laptop, the Display Panel Cable may become pinched in the left Hinge.
This can cause;
A) The connection at the motherboard to come loose
B) The connection at the back of the Display Panel to come loose
C) Stretch the wires inside the Display Panel Cable's sheath, and damage the wires. (Break)
If you are lucky just the connection at the motherboard, and/or connection at the back of the Display panel, may have come loose.
Diagnoses is to NOT just look at the connections, but physically push the connectors of the Display Panel Cable, into the connector at the motherboard, AND back of the Display Panel.
Visually inspect the Display Panel Cable's sheath. Do you see any outward appearance of damage? This means the tiny wires inside may be damaged.
Replace the Display Panel Cable.
Remove ALL power. Remove the AC adapter (Charger), and Battery.
Remove the Keyboard Cover.
Unfasten the Keyboard, LEAVING the Keyboard Cable ATTACHED to the motherboard. Roll the Keyboard over, and lay it upside down on the Palm Rest Cover,
http://support.dell.com/support/edocs/systems/ins1420/en/SM/display.htm#wp1129771
[ NOTE*
Two Philips head screws at top of Keyboard. After removing, lift the top of the Keyboard up a little, slide it a LITTLE towards the Display Panel.
DO NOT lift it straight up at first.
There are 3 plastic tabs on the bottom of the Keyboard, that slide into the Palm Rest Cover. If you pick it straight up you will break those tabs off ]
In Removing the Display Assembly, note where number 1 points to.
This is the Display Panel Cable's connection, TO the motherboard.
Note where number 2 points to. Those cables going to the Mini-Card Antenna, HAVE to be reconnected, right back to the SAME terminals on the Mini-Card. Make a mark on the cables, and matching marks on the Mini-Card.
Use the instructions in Removing the Display Bezel.
Use the instructions in Removing the Display Panel.
View the last illustration in Removing the Display Panel.
Note how the Display Panel Cable attaches to the Display Panel, and Screen Inverter
Number 2 points to the connection at the back of the Display Panel
Number 6 points to the connection to the Screen Inverter
The Black connector that is not numbered at the bottom, is the motherboard connector of the Display Panel Cable.
This is a better view of the screen Inverter,
http://www.ebay.com/itm/Dell-Inspiron-1420-1421-LCD-Inverter-Backlight-Combo-/370274752470
Display Panel Cable checks out? Look at the screen Inverter. This small circuit board is located at the bottom of the Display Panel, and behind the Display Bezel. Closer look at link listed above.
Is the cable coming from the Display Panel Cable, plugged in tightly to it?
Does the screen Inverter look damaged?
Post back in a Comment, and we will go from there.
Regards,
joecoolvette
Jun 09, 2012 | Dell Inspiron 1420 Laptop
How do I clear Fax log entries for HP J4580?
You can try this,
"A 'Fax Log Full ' message displays on the control panel display when the Fax Log is full."
1. Press the Setup button ("Spanner logo")
2. Press the Right arrow button (?) until Tools displays on the control panel, and then press OK .
3. Press the Right arrow button (?) until Fax Log displays on the control panel, and then press OK .
4. Press the Right arrow button (?) until Clear Fax Log displays on the control panel, and then press OK . A message that says the fax memory is clear displays on the control panel.
5. Press the Cancel button (X) to exit.
Hope it helps.
Jul 14, 2011 | Computers & Internet
Toner not reset
Mar 01, 2011 | Samsung SCX 4521F All-In-One Laser Printer
I just purchased my HP 4500 printer and began to install it. I see an error (!) symbol and I believe German writing. I need to remove that symbol and change the language to English.
Selecting the display language
To change the display language on the printer control panel, do the
following:
1 Press and hold [SELECT] on the printer control panel while pressing
the standby button (power switch). Continue holding [SELECT] until
the control panel displays
SELECT LANGUAGE (in English), and then release the [SELECT] key.
2 When the control panel displays LANGUAGE=ENGLISH *, press
[VALUE] repeatedly until your language choice appears.
3 Press [SELECT] to save your language choice. An asterisk appears
next to the selected language. Then press [GO].
4 After the printer warms up, the control panel displays READY in the
selected language.
Note
If the control panel does not display the message in the language you
selected, press the printer standby button and repeat the instructions for
changing the display language.
Dec 07, 2010 | HP LaserJet 4500 Printer
SCX4521 Printer is displaying error message Scanner Is locked how to solve this problem
Solution from samsung site i hope it will work for you
3. Press the left arrow (4. Press ENTER. The operator panel will display [YES].
Oct 18, 2010 | Samsung SCX-5530FN All-In-One Laser...
How to reset the scx 4521
6. To exit TECH MODE, press MENU # 1 9 3 4 in rapid succession, as if you were dialing a phone number. The operator panel should no longer display TECH. www.nakshatraworld.com
Dec 08, 2009 | Samsung SCX-4521 All-In-One Laser Printer
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
Cracked screen can it be fixed
No..the Glass Display Panel ... If cracked... Cannot be repaired.. it is not just a piece of glass, it is a layered panel with pixel grid panels along the top and sides that show color to the grid on the screen panel and go all throughout the display ..
If the Crack ocured behind the display panel on the plexiglass protective panel, that can be replaced... but No Not The Front LCD Display Panel.
Nov 19, 2008 | Acer Aspire 5100 Notebook
Bosch KAN62V40 Side by Side Refrigerator Logo
15 people viewed this question
Top Bosch Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Bosch Refrigerator Expert? Answer questions, earn points and help others
