Question about Vision G1163801207 Webcam
Need a driver
I have been on my pc for 4 days trying to get my webcam with mic to work even tried 5 other ones no luck the camera works but not mic i have done everything that i think can be done except this driver and i cannot find it
My microphone is not working when I try to Skype but the camera does work
Good day,
This sometimes happens if skype is using the wrong mic line.
To set the correct line:
1. In skype go to Tools in the top menu bar and then select options.
2. Select audio settings on the left hand menu.
3. Click on the drop down box next to microphone.
4. Select each setting until you see the green bar respond when you talk into the mic.
5. Click save.
This will solve your problem. Make sure that the mic is plugged into the red audio jack!
Regards
Nov 28, 2010 | Microsoft LifeCam NX-3000 Personal Web...
SEGMATEL MIC NOT WORKING
1. Click Start
2. When the menu opens, highlight either All Programs or Programs.
3. Click the Dell Webcam folder, then click the Dell Webcam Manager icon to open it.
4. In the Dell Webcam Manager, click the Dell Webcam Center.
5. In the lower right-hand corner of the Dell Webcam Center window, click the drop-down arrow next to Audio Source and click Digital Mic (Realtek High Definition Audio) to enable the microphone.
Alternatively you can try downloading the updated audio driver
http://tinyurl.com/2a3czup
Thanks for using fixya
proton
Jun 09, 2010 | Dell Dimension E520 PC Desktop
Cant hear enything when i am speakin with friend on the mic
Unplug the camera, remove all the Logitech camera AND Logitech camera drivers via Control Panel/ Remove Applications, then reboot. After re-boot, plug in the camera, Windows will identify it as a USB Camera / Mic and it will work in all applications including Skype. You will not have access to the Logitech menus but the camera and Mic WILL WORK in all your communications needs. After a number of instances where I lost my Mic input, I finally gave up on the Logitech software since they are incapable of finding the Windows Update driver that conflicts with their own driver. Although mine is currently working fine as a Windows recognized "USB Camera Mic", the next Webcam I get will NOT be Logitech. It's a great Webcam but since they are clearly incapable of keeping their software compatible with Windows updates, I'll switch to another make. Hope this helps.
JamesTBaines@BTopenworld.com
Mar 08, 2009 | Logitech Quickcam Chat Webcam
Compaq c700
I CANT HAVE MY INTERNAL MIC WORKING WITH XP.
TRIED EVERY POSSIBLE DRIVER. 3.45 and found around a 3.47.1
everithing ok except that i cant find anywhere the internal mic and i cant use that.
How can they be so clever to put a mic line in when there is a buil in one?
I bought this pc for webcam and mic built in.
Vista kills the pc (it a celeron) so i need XP (mine is sp3).
And the internal mic is not working?????? Noone can find solution??? Even HP doesnt post correct drivers, how awful.
found many drivers around but nope with internal mic, i cant even find it anywere around in config or system...
Anyone got any results?
Nov 08, 2008 | Compaq Presario 700 470024-192 Notebook
My microphone on my acer aspire one isnt working
This solution works for the Windows XP version. Go to msconfig.exe, then the Startup tab. UNCHECK rthdcpl and restart. Realtek driver doesn't load, but who cares...the microphone works now.
Aug 09, 2008 | Computers & Internet
Gigaware 25-157
try uninstalling the webcam and when installing don't have it pluged n till the inasallation has finished then plug in webcam and when pc finds new device just go throuh the wizards to find the device and reboot pc with device then try and using it if you can't see any thing with it you should get it replaced as the webcams come with programs so you can set it up properly.
Best of luck
Jul 08, 2008 | Radio Shack VGA PC Camera Webcam
Gigaware PC Camera with Mic
Window say they can find the Driver for Gigaware Pc camera with mic
Jun 17, 2008 | Computers & Internet
WEBCAM
Start,settings,control panel,system,hardware,device manager.
If the device is listed with no problems (no yellow exclamation or red /) Then you might want to try this web chat software.
If the device does have a ! or / it needs updated drivers or firmware.
Apr 17, 2008 | Computers & Internet
Webcam not working 5520laptop,shows not connected My aspire 5520 came with Vista, was running extremely slow. Installed XP and everything's working fine now except the webcam. I've tried every driver on...
http://www.acerpanam.com/synapse/forms/AcerDrivers/Aspire%205520.pdf?CFID=2214079&CFTOKEN=50862842
I suggest you install the web cam application as well as the drivers. Also the Acer empowering application needs to be installed. You can click on the link supplied to see all of the applications and drives for your model.
Hope this helps. You can get additional help on the website Notebook forums and discussions site.
Mar 23, 2008 | HP Pavilion dv6000z Notebook
Mic
first u check whether your mic is correct, try to plugin some other pc where mic is working in good condition,
if the new mic is working properly on another pc then
Re install your sound card Driver, and try
Cheers
Nov 30, 2007 | Philips SPC 200NC Webcam
Vision G1163801207 Webcam Logo
46 people viewed this question
Top Vision Computers & Internet Experts
micky dee
Jim Goldsmith
Jim Goldsmith
Are you a Vision Computer and Internet Expert? Answer questions, earn points and help others
