Question about Breville BES820 Espresso Machine
How to descale the bes820 espresso machine - Breville BES820 Espresso Machine
2 Suggested Answers
SOURCE: Breville BES820 Espresso Machine internal short
  • steve_s741
  • 4 minutes ago
Ok, I'll describe my own fix to my own problem in the hope that it helps others. First of all, the symptoms: your machine just stops working altogether; all lights go out; you try and turn it back on but nothing happens; then you realize half of your house has lost power. So you try and reset the circuit breaker, but you can't succeed until you turn off the machine at the wall plug.
The diagnosis: probably an internal short circuit.
This is what happened to my machine, and because it's out of warranty I thought I'd have a quick look at it myself. Turned out to be simple fix, so here goes...
Getting access to the wiring we need to look at is easy enough.
1. Disconnect power from outlet (obviously);
2. Use your Torx T20 to driver bit to remove 4 screws holding the rear cover, then turn the machine upside down and remove 2 small philips-head screws securing the base of the rear cover. remove the cover.
3. Gently bang the top die-cast cover from the back to try and dislodge it and move it towards the front of the machine (there are no screws holding the cover on the BES820, it is just a tight fit under some lugs). Your attempts to move the cover will be met with resistance. In the end I needed to thump it quite hard with my hand. A rubber mallet would probably be ideal, but I don't have one. Once you have pushed the cover forward by about 10mm, you should be able to lift the cover off.
4. Unscrew the earthing cable form the top cover and put the cover aside.
5. Now inspect the visible cables. Look in particular for any pair of wires that may be making contact with each other. This was what I found in my case. Two wires had been rubbing against each other, probably due to the vibration cause by the pump, and eventually had rubbed through the insulation to the point where the circuit was shorted. Smoking gun found!
6. If you find this evidence, you will need to a) add some additional insulation where the original has worn through (make sure it is heat and steam resistant, consult with your electronics store), and b) ideally, try to rearrange the cabling to keep some physical separation between the cables so it doesn't happen again.
When you are satisfied with your work, you can test it by plugging it back in and turning on at the wall. If you haven't replaced the covers yet, be aware that most of the visible wiring you see in there is running mains voltage, so keep hands clear!
Reassembly is the reverse of above. Don't forget to re-connect the earth lead to the top cover before replacing it. Good luck!
Posted on Apr 09, 2011
Testimonial: "This guy is a gun"
Tip
How to descale espresso machines.
Have you ever wondered, 'how do I descale my expresso machine?' First lets us understand what is exactly is scaling. The build up of minerals inside the hot parts of your coffee machine or espresso machine is commonly called lime scale. When lime scale builds up inside the Espresso machine, it slows down the water flow, reduces the boiler capacity and can prevent your coffee machine from working properly. To keep your Espresso machine operational at full order, it is important to descale it every three months. The time intervals between descaling depend upon many factors. Quality of your water and the amount of water running through the machine are the two main factors that decide the frequency at which you should descale your Espresso machine. The more you your machine, more often should you descale it. In some cities, in conjunction with a water filter you can use your coffee machine for a year or more without descaling at all. If you use less water by drinking espressos you'll need to descale less often than if you make cappuccinos.
Descaling products are widely available from stores that sell coffeemakers and espresso machines. Be sure that the product you buy to descale your Espresso machine is intended for this specific use only. Before you descale your Espresso machine, always unplug it and make sure that it is cold. Also, never immerse the appliance in water and nor should you use abrasive cleaning products or scouring materials on any part of your Expresso machine. In case your Espresso machine does not come with a instruction guide or booklet, then use a proper citric acid based descaling solution designed for espresso machines. This should be mixed and prepared as per the instructions on the bottle or packet. Once your Espresso machine has been descaled properly you would not be left wondering, 'how do I descale my expresso machine?', treat yourself to a great cup of coffee. Some popular models of Espresso machines are Krups EA8080 Espresseria Automatic, DeLonghi Magnifica EAM3200S, Krups Nespresso CitiZ & Milk XN 7106 Fire-engine red, DeLonghi Perfecta ESAM5400, DeLonghi PrimaDonna ESAM6600, DeLonghi Magnifica ESAM4200S, DeLonghi Perfecta ESAM5500 and Magimix Nespresso Citiz M190.
Here is a basic generic picture of a espresso system of how they work.
I hope this helps. Feel to contact me for addition questions. Thanks Mike
on Jul 26, 2011 | Coffee Makers & Espresso Machines
Lost directions - how to descale keurig ?
Hello, Here is a tip i wrote, see if this helps you.
Jun 29, 2011 | Microwave Ovens
How do you descale the machine,as we have no manual
HOPE THIS HELPS. MIKE (MR BEAN MAN) FROM FIXYA
Jun 14, 2011 | DeLonghi Perfecta ESAM5500 Fully Automatic...
The CLEAN light has come on. How do I clean it?
Jun 12, 2011 | Mr. Coffee BVMCPSTX91
How to descale the delonghi icona pump coffee machine?
Jun 12, 2011 | DeLonghi EAM3500 Espresso Machine/Coffee...
How to clean coffee machine properly? i was given one and want to ensure that it is save from "everything" so i can start using it.
Jun 09, 2011 | Coffee Makers & Espresso Machines
Who in New Zealand supplies replacement seals for a Breville 800 series coffeee maker
You can get them from Need A Part. They are an online shop, but they have a phone number as well. I think this is the seal you want:
http://www.needapart.co.nz/shop/products/10120008
Nov 27, 2010 | Breville BES820 Espresso Machine
Breville BES820 Espresso Machine Logo
Top Breville Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Steve
Colin Stickland
Colin Stickland
Are you a Breville Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
