Garden Logo
Anonymous Posted on May 20, 2009
Engine stalls I'm in need of some advice on what to look for in order to get my ride-on tractor to stay on. Here is the whole story. * Tractor sat unused for 12+ months, including a new england winter. No fuel preservatives or winterizing was done. * When I went to start it, battery was dead. I had it recharged successfully. * After starting running for 10 minutes engine (without deck engaged), engine stalled. I was unsuccessful at getting it running again until I added engine starter fluid in the carburator. Also topped off fuel tank (about 4 gallons were put in) * Used the tractor for 1hr (without deck engaged). Tractor speed felt sluggish. It stalled a couple of times but I was able to restart it. * On another day, I started it and it stalled. Noticed the fuel filter was empty. I suspected a fuel problem so I changed the pump and put in a new filter. * Now when running (deck unengaged), the battery light sometimes stays on. When I engage the deck, the battery light always turns on. When a little bit of load is placed on the deck, the engine stalls. * After stalling, I can get it started but it won't stay on unless I push on the choke level all the way up. * The speed of the tractor, even deck ungaged, is noticeably slower. I think the key to finding the problem here is the battery light turning on and the slower speed. It is indicative to me of a fuel problem but I can't find the problem yet. The spark plugs were new before the tractor sat unused for 12+ months. I will probably replace those today as well. In the meantime, any more suggestions?? Thanks Roger
  • Anonymous May 20, 2009
    I'm sorry about the bad formatting for the initial post. I can't figure out how to edit it or delete it, so I'm adding the new formatted version here.
    The tractor is a 2000 John Deere LX277
    Thanks
    Roger
  • rjivaro May 11, 2010
    Disassemble and clean the carb, particularly the jets. I suspect the charge light being on is a result of your destroyed battery, which needs to be replaced. Sta-bil over the winter and a smart trickle charger will prevent the problems you are having in the future.
Mike McDowell
Level 2:
  • Expert 148 Answers
  • Posted on May 20, 2009
Mike McDowell
Expert
Level 2:
Answers
148
Questions
0
Helped
90258
Points
359
DId you remove the existing gas or just topped it off? If you topped it off, I would dump the fuel and replace the fuel filter, after that I would clean the carb (Spray cleaner).
John Deere L130 riding lawn tractor will not start what do I do?
I'm assuming the motor will crank over, but not start. Remove the air intake cover & filter off the carburetor air intake. Do you smell gas? Is gas dripping out of the carburetor? If not, spray a couple shots of starting fluid or carburetor cleaner into the carburetor air intake throat. Close the choke & crank the engine. If it starts, & stalls, repeat the process. If it won't stay running, your carburetor float jet is gummed up & needs to be cleaned. Check & clean the spark plug. Does the spark plug fire when the engine is cranked? If no, then you have an ignition problem.
Tractor
be careful with starting fluids, they strip cylinder walls, NOT a good thing. Prime with WD 40 or gasoline. forget the starter fluids. In all likely hood your carb needs cleaning. Pull the fuel line off the carb first though, and crank the engine. If you get good fuel flow, you just have a plugged fuel filter.
2166 stalls after it heats up
Sounds like you've got a bunch of debris around the engine, not allowing it to cool properly. I'd pull the shroud off the engine, and clean out any accumulated debris and clippings (considering your symptoms, I'd expect a lot of it. My preferred method is to use an air gun connected to my compressor - I don't like spraying under the shroud with pressurized water.
Craftsman Model 917.259566 Tractor starts perfectly, but stalls out when the clutch is released. Whats happening?
Most likely your seat safety switch is not working. In order for the engine to run with blade engaged, the operator present switch must be made when the brake is taken off (releasing clutch).
Because my garage is full I have had to leave my Deere x720 ultimate tractor with snowblower outside in 20degree weather. It starts immediately but stalls the minute I take foot off brake. I noticed that...
You probably need the seat switch replaced if the tractor will stay running until you let off the brake,to confirm just unplug if and jumper the plug plug across with a piece of wire that has been stripped at both ends.
3helpful
John Deere LA145 B&S 22Horsepower engine starting and running
You may simply need a new fuel cap,vacuum in the tank will rob your fuel and stall it engine,try taking off the fuel cap and see how it runs.If this does not help you may need a new fuel pump,which runs off of crank case pressure and should take over from the choke once the tractor has started.
1helpful
Lawn tractor, engine model 42A707, starter spins but won't start engine; noted starter gear on top is worn down. Need help to either replace whole starter assembly with gear or just gear?
I had this same problem with a twin cylinder B & S engine and was able to get just the gear drive replaced without replacing the whole starter. Hope this helps you
Model 111 - worked great in Spring. Sat out all
SOUNDS LIKE THE PT O SWICH IS BAD OR THE SEAT SWICH IS
1helpful
Tractor starts, stalls when blade is engaged, or brake released
you have a safety switch malfunctioning or a transistorized relay not working properly. Go to www.partsdirect.com, this is sears website. It should be able to find and illustrated parts list for your mower.
1helpful
2answers
John deere tractor won't stay running
Its using up the gas in the carb then it stalls. take the carb off and clean it and make sure the float in the bulb of the carb isnt sticking closed.
Top Garden Experts
Jay Finke
Jay Finke
john h
