Question about Bushnell NorthStar 78-8831 (525 x 76mm) Telescope
I cannot see anythingthrough the telescope. i wanted to use it to view, and couldn'teven see a star... all i see is black? it was a clear night
I haven't completely figured out the computerized part of it
4 Suggested Answers
SOURCE: telescope venture rx9 view blocked
I have this same issue. A star or planet is vlocked by a circle with 3 prongs - like the mirror holder in the tube.
Posted on Oct 19, 2009
  • 15 Answers
SOURCE: dot in view
Sounds like a collimation problem!! do you know how to collimate the optics?
Posted on Nov 05, 2009
SOURCE: Hi, We have a Bushnell Telescope (North Star with
Not really-- you will need to contact one of these repair centers:
http://www.opticsplanet.net/bushnell-warranty.html
Posted on Feb 22, 2011
When using telescope for the first time (looking at venus) it would not focus, also the cross at the front of the tube was most prominent.
Do stars appear as small pinpoints in your scope? If not then it sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
With the telescope pointed at the distant object, focus the telescope until the object is sharp and clear. The object might appear upside down -- that's normal for many astronomical telescopes. When you have achieved a sharp focus, leave the focus control alone until you are outside at night under the stars.
The focus should now be fairly close for viewing stars and planets. Small adjustments of the focus control may still be necessary for the sharpest view.
Venus is sometimes a difficult object. It is often fairly low in the sky where the atmosphere is most likely to blur the view. Find a bright star and focus it to a pinpoint, then swing your scope toward Venus.
- Jeff
Dec 27, 2016 | Celestron Optics
Why can I not see the difference from the sky and a star even when I allign my laser well?
It sounds like you have not adjusted the focus properly. I recommend you take your telescope outside in the daytime and point it toward a building or tree or hilltop that is somewhat distant from you. The exact distance is not important, but it should a block or more.
- Jeff
Jun 08, 2014 | Celestron NexStar 4 SE Telescope
Hi ive got a galaxsee tasco telescope but im having trouble seeing anything at night, i've took all the caps off lined up on a star but its just pitch black can you help thanks.
1. During the day, point the scope towards an object and align the finder scope to the telescope.
2. First object at night should be the moon. it will verify your finderscope alignment and you should have a clear view of the moon.
3. Use your lowest power eyepiece (largest number in mm) and point the finderscope to a star. The star should be in the center of the eyepiece.. If not, adjust the finder until it and the scope are centered.
4. You can use your higher power lens on the star nd it should still be in the FOV (field of view)
5. Scope may need to be aligned (collimated). Instructions on this should be included with the scope
Mar 10, 2011 | Tasco Galaxsee 46114375 (375 x 114mm)...
Not really a problem, but a question on expectations for a Venture RX-9 900mm reflector telescope. What should i be able to see on a clear night concerning Jupiter and Saturn? I am just getting started...
Is this your telescope?
http://www.fleamarketstore.com/ca/4-280501979376-28179/venture_rx_9_reflector_900_x_114_telescope_675x_power.htm
If it is you can forget about 675 power magnification. The maximum magnification for ANY telescope is about 50 times aperture. You have about a 4 inch aperture mirror so 200 power is the highest it will go, and ONLY on perfect nights when the sky is very stable and if your optics are PERFECT.
Most of us only get 30-40 times aperture. You will not see color almost everything is shades of gray. If you are expecting a GIANT view you will certainly be disappointed. BUT-- the scope can show you many objects in the night sky.
Start with the moon and also Jupiter which is up shortly after dark. Download this free monthly star chart and read my tips on my profile page.
www.skymaps.com
Jan 19, 2011 | Optics
When i look through the high powered eye peice i can never find the object. i can see colours if i look at buildings and such, but if i try to see a star its just black. i am lining it up right on the...
Telescopes have VERY small fields of view, and YOUR telescope will never reach 375 power.
Why? The maximum magnification of any telescope is 50 times aperture. So a 3 inch scope is 150 power.
Do not try to use max power-- I own several scopes in the 10 inch range, many times larger than your scope. Normally we use from 80-150 power to show objects in the night sky. Remember the scope has a field of view smaller than the tip of your finger held at arm's length!
Oct 11, 2010 | Tasco Galaxsee 45-114375 375X (375 x...
Bought the tasco 525 x 60 used and all we see is black. looked up and down for something obvous and can't find it?
Did you try focusing during the day time on a distant object?
Objects in the sky are very tiny, smaller than the tip of your finger held at arm's length. The scope must be pointed directly at them to see anything----- and your scope also has a VERY small field of view. That's why we recommend binoculars to a beginner. The wider field of view makes it easier to find objects in the sky at night.
Download this free monthly star chart:
http://skymaps.com/downloads.html
Locate a local Astronomy club and attend their star parties and meetings. They will help you.
Read my tips on my profile page for more information.
Sep 02, 2010 | Bushnell Tasco Telescope Galaxsee 525x60mm...
Having a clear sky last night i took my new scope out and started to view the night sky, but focusing on a star ! i found that when viewing it at magnification a could clearly see the the area infront of...
Stars are ALWAYS pinpoints of light when the scope is focused no matter how much magnification is applied.
You are NOT focused properly -- when you are you cannot see the secondary mirror or the "spider" bracket that holds the mirror.
You will NEVER see a star as a disk, only as a pinpoint light. If you are seeing what looks like a donut with a dark center you are not focused.
May 07, 2010 | Celestron PowerSeeker 114 EQ Telescope
I see images in the daytime but at night complete blackness
Your scope must be pointed directly at the objects in the sky. They are very tiny, and no bigger than the tip of your finger held at arms length. Try for the moon first, and buy a good star chart like, "Sky & Telescope Pocket Star Atlas" available on amazon.com.
All telescopes have very small fields of view, 1 degree or less usually.
Also read my TIPS on my profile page.
Apr 04, 2010 | Celestron PowerSeeker 114 EQ Telescope
Want to see images right side up
You do not need an erecting prism to view objects at night. These are used if you wish to view terrestrial objects since it turns them right side up.
If you have a reflecting telescope (it uses mirrors) it's normal to not use an erecting prism or as they are also known as star diagonals. Objects will appear inverted and that's normal. A refracting telescope (no mirrors, just lenses) will also invert the image but it is quite often used with a star diagonal to make it easier to view. There are many other types of telescopes that use a combination of mirrors and lenses.
I hope this helps.
-jodair
Mar 29, 2009 | Optics
Telescope venture rx9 view blocked
Jun 13, 2008 | Bushnell 675x5 EQ Reflector Telescope
Bushnell NorthStar 78-8831 (525 x 76mm) Telescope Logo
Top Bushnell Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Bushnell Optic Expert? Answer questions, earn points and help others
