Question about Microsoft Video Game Consoles & Games
Making a usb atari pc controller - Microsoft Video Game Consoles & Games
Does the Atari 5200 have the same controller as the Atari 2600?
It does use a slightly different controller. The joystick that comes with the Atari 5200 has 360 degrees of control while the Atari 2600 controler only give you 8 ways of motion. Teh 5200 also has a number pad and buttons for start, pause and reset.
Dec 16, 2013 | Video Game Consoles & Games
Regardless of controller on the left controller port i cant move up
Well it sounds like the controller that you have is not working properly so you could buy a new controller then. Lukie games sells atari 2600 stuff. Or you could open up the controller and try re soldering it the. To see if it works
Apr 29, 2012 | Atari 2600 Console
Atari Problems
Well it should have a button on the top part of the console thAt says on and off or a button thAt says power on top of the. Console YouTube has how to turn on an Atari 2600 console.
Apr 19, 2010 | Atari 2600 Console
Atari 2600 problem with left control plug on console
Well maybe the controller ports need to be resoldered then try soldering then with a solder iron.
Nov 21, 2009 | Atari 2600 Console
Atari 2600 Console Power Adapter
The Atari 2600 adapter has the following information on it:
Input: 120V AC 60Hz 12W
Output: 9V DC 500mA
Positive tip
Make sure you test the power supply before you use it. I have 2 original atari power supplies, and they are both putting out about 15V DC, which may be why my atari's aren't working anymore!
Anubis
Jan 05, 2009 | Atari 2600 Console
Paddles don't work for atari 2600
Sounds like a pin has come loose from the main board inside your unit. If you are handy with a soldering iron, and not opposed to opening up your console then, you can take a look at the connection between the connector and the board... If you are not comfortable with this idea, then you can find a competent electronics repair shop on the internet. You could also replace that unit with a "new" one from a number of internet shops or eBay, then retire that one. Hope this helps.
Dec 21, 2008 | Atari 2600 Console
Atari 2600 jr. console + paddle controls = DonĀ“t work !!!
get a refund for the item
then buy a new console
Sorry but thats the only way your gunna get this to work :(
pls rate.
Dec 17, 2008 | Atari 2600 Console
Video Game Consoles & Games Logo
29 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
