Question about Motorola Talkabout FR50 (14 Channels) 2-Way Radio
Neither radio will receive or send
I have a set of FR50 Motorola Talkabouts.  One is working OK as I have another set of Radio Shack two ways and they will work with one of the Motorola.  The other Motorola turns on OK but will not receive or transmit. When you push the call button on the good unit you hear a click on the one that is not working correctly, but that is all.  Any idea as to the problem and is there anyway I can repair?
  • Motorola Master
  • 1,654 Answers
The radio probably needs reprogrammed to match the other units. Check your owners manual for instructions.
Posted on Oct 28, 2008
Motorola fr50 red flight flashing quickly
Hi Kenny,
While the red light is blinking, is there someone else talking on the 2-way?
If the answer is yes, that's the reason it's blinking, because it's telling you that the channel is in use...
I hope this answers your query.
Cheers,
Peter
Jul 19, 2012 | Motorola Talkabout FR50 (14 Channels)...
Can you use 2 different talkabouts fr50 and t5420 with each other? I have just one of each unfortunately.
  • Yes they will both talk together on the same channels just fine. Most of the more recent Talk About Radios are FRS/GMRS with 22 channels. These radios are FRS only with out the GMRS. The FRS are the first 14 channels in most talk about's as are your radios.
Regards, Tony
May 01, 2011 | Motorola Talkabout FR50 (14 Channels)...
One works the other does not broadcast
The FR50 is a pretty basic radio, where you set the channel select to one of 14 frequencies. The freq number will display on the screen, both radios must be on the same freq to communicate. This being said, if you have known-good batteries and the freq number is the same, your raidos should work together. If not, you have a radio which is defective and will need to be replaced.
Here is a link to the user guide: http://www.giantintl.com/RadioPDFs/Outdated%20Manuals/fr50_User_Manual_E.pdf
Best regards.
Dec 30, 2009 | Motorola Talkabout FR50 (14 Channels)...
Hi, i bought a Motorola CP200 radio and realised that it didnt work with my Motorola Talk-abouts! now i know that there is a programming that i need to operate with!!! so my question is....how can i know...
Take it too radio-shack and ask the salesman to try out a frequency meter to get the freq. you can get programming help by contacting motorola direct...1-800-638-5119
Aug 23, 2009 | Motorola CLS 1110 (1 Channel) 2-Way Radio
One radio not sending
hold the the ptt button for a minute in both handsets
Mar 07, 2009 | Motorola Talkabout FR50 (14 Channels)...
Talkabouts not communicating
What you have described is typical of the radios not being on the same frequency and/or code. If you know how to put your radios in programming mode, set all the frequencies and codes to the same number, then they will work together. If you still have the owners manual it will describe this process. Usually with a TalkAbout radio it consists of holding in the PTT while turning the radio on.
As you are probably aware, the radio will have approx. 14 frequencies installed. You can usually select these easily from the front panel. The second number you see in the corner of the screen when you turn on the radio is the "code". This is an interference eliminator. All of your radios need to be set to the same code to work correctly together. If you find one or more of your radios does not have "code", simply set those that have "code" to zero.
Jul 14, 2008 | Motorola Talkabout FR50 (14 Channels)...
Fr50 beep
Hello mtnrvr,
The Motorola TalkAbout radios, especially the FR50 and FR60, are notorious for making a variety of beeps when you push buttons and activate various functions of the radio.
The beeps can be helpful when you are trying to operate the radio in low-light situations. But they can also be mildly irritating.
Sadly most models of TalkAbout do not provide any way to disable the beeps. I'd suggest not using this particular radio for covert surveillance missions.
Best Regards,
Agent Ken
Go Ahead. Use Us.
Apr 12, 2008 | Motorola Talkabout FRS 250 (14 Channels)...
Motorola Talkabouts usually a have a CODE you can set for each channel. This is like a TPL / DPL code. If its not set the same for both radios then other radio may not receive.
GP300. Assuming they are programmed to talk to each other, ie RX and TX of each on the same frequency or they may talk through a repeater and that the TP/ DPL code are correct. If you have the Speaker icon crossed through they are probably muted, but in this case you should be able to unmute them from the keypad. Only other thing is if they are programmed for Selective Call, then they would only unmute on a call which contains their ID #. There several Selective call systems, MDC, Select V , Quick call are just some. Europe usually opts for a certain type of Select V. US uses MDC.
Nov 24, 2007 | Motorola Eliminators: GP300 Battery...
Radio shack product question
Theirs only 1-way to find out if its compatable...Plug it in
Thats what I'd do.
Have you also tried any earbuds from cellphones?
Oct 16, 2007 | Radio Communications
Motorola Talkabout FR50 (14 Channels) 2-Way Radio Logo
248 people viewed this question
Top Motorola Radio Communications Experts
eradiostore
eradiostore
Steve
Are you a Motorola Radio Communication Expert? Answer questions, earn points and help others
