Question about McCulloch MC1275 Steam Vacuum
Leaks steam underneath when heating up and then big puddle of water afterward. NO leaks when turned off. Steam does not come out of the hose.
2 Suggested Answers
SOURCE: McCulloch Steam Cleaner Problem
I have a similar problem but the light is not even coming on. This was a refurbished unit and the retailer sent a replacement so I can get into the broken one and see what's there.
Anyone have any ideas on how these work? Is it just off/on or are there saftey switches/fuses/breakers etc?
Posted on Sep 25, 2008
Steam mop not putting out steam although it is heating up
Well, if you have heat and there is water in it then this is one of two things. The delivery hose is clogged either too or from the heating unit or the heating coil is not getting hot enough. Look for dripping water that is not turning to steam while it is running. That would eliminate the clogged problem. Then you could look at the heating temperature at that point.
Jun 03, 2016 | Vacuums
HOSE LEAKING WHEN USING TOOLS OTHER OSE STUTTERING AND WON'T STEAM HAVE USED KALSTOP
on further inspection the hose that is leaking appears to have a big 2 cm short faill like its been pushed into itslef thats hwy its leaking its not connecting correctly and the other hose i think a spring may have gone on the trigger itself. as when press steam come out and then won't its like the button you press to swith it off is shyt off and no steam.
Nov 20, 2013 | Polti Vaporetto 2400 Canister Steam Vacuum
Is there a trigger handle to turn off and on
no betty, stupid bit of kit imo, no operating switch, just on/off at the switch, which heats the water up. i measured 500ml of water heated using my kettle, put the top on, switched on, and waited. first time the steam didn't come out of the nozzle, so i removed the end and cleaned the nozzle with water, blew down the end from the big end, and replaced it, steam came out. big grumble though, the steam coming out is not that warm, don't advise you to, but i directed against my fingers, it's only hot at the exit of the pointing bit, used it to try and clean floor tiles and grout, complete waste of time. i wouldn't advise anyone to buy one.
Dec 11, 2011 | Tristar SB Steam Buggy Vacuum
Using my hoover steam vac tonight and too much water coming out. once it's turned on, water and shampoo continuously come out underneath until tanks are empty. looks to be leaking from left side bottom as...
make sure that you have filled everthing properly and the hoover steam is in a good condition. or check else is there any loose coonections in the bottom of the hoover, which makes the tank empty.
if the problem persists take it to service.
Feb 25, 2011 | Hoover Steam Vac Dual V w/ SpinScrub...
No steam out of the pad. Steam coming out of the unit and water all over the place. But no steam out of the pad only making puddles of water
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
Dec 04, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Polti 1500 no steam just droplets of water
Before trying anything else make sure you turn up the pressure control knob in the direction of the + sign if it is turned right down you will have steam in the system and the gun will be heard to click open the flow control valve but you will not get any steam because the control screw is set too low just turn it anti-clockwise to increase the flow and your good to go .I hope this helps I have one too and I some times forget to turn up the flow and wonder why for 3 minutes then realise that during storage and manuevering it gets turned down by accident and i turn it up and all is well again.
Jun 20, 2008 | Polti Vaporetto 2400 Canister Steam Vacuum
McCulloch MC1275 Steam Vacuum Logo
20 people viewed this question
Top McCulloch Vacuums Experts
JoeVacs
Are you a McCulloch Vacuum Expert? Answer questions, earn points and help others
