Question about Sewing Machines
Pfaff sewing machine repair
Pfaff model 1119 can't work out how to do ZigZag. have pressed Zig Zag button and length is on 3. no other buttons work except straight sticking. Machine hasn't been used for several years.
  • 1027 Answers
SOURCE: How do I change the stiches?
The brother website has a users manual for it that can be downloaded. Use this link to get it:
http://welcome.solutions.brother.com/bsc/public/us/us/en/doc/manual_index.html?reg=us&c=us&lang=en&prod=hf_ls2125eus&type2=5&flang=English&dlid=
Posted on Jul 10, 2008
SOURCE: Kenmore 1560 Sewing Machine
Be sure TOP control shows zig-zag. Flip top right bar from red to black or black to red on side of machine facing you. You can then change the widths by changing the numbers on that same circle control.
Posted on Jul 17, 2008
RickE1
  • 202 Answers
SOURCE: Zig Zag Not working on my Bernina 830.
Basically it is a matter of a stuck part. Flip open the top by prying up on the front or ends of the lid. You already noticed the hinges on the back. When you get it open, exercise the right hand lever on top (marked ZZ at bottom and 1-20 at top. If you look just to the right of this lever against the back wall you will see that it moves a little part back and forth into triangle shaped grooves. The part is not going completely into the grooves so drop some oil in there and exercise it a few more times, using your fingers if necessary to make the part move into the triangle grooves at the front and back. After a while it will loosen up where it should operate by itself smoothly . Hope this helps.
Posted on Dec 12, 2008
  • 980 Answers
SOURCE: Kenmore 2142 sewing machine won't zigzag.
Before you put the cam in did you make sure the machine was set on straight stitch and then select zig zag?
Posted on Nov 06, 2009
  • 11 Answers
SOURCE: PFAFF 362 Sewing Machine: The shift
Remove the top cover (grasp and lift straight up), spray with "Tri-Flow, liberally inside. Pay attention to the right 1/2 and behind the front dials.
In Front, each dial has a small square opening on the side, use the tube included with the "Tri-flow" to squirt lube inside them. DO NOT use WD-40.
Run the machine daily for 5-10 minutes (set the dial "C" [top front that goes up to 8] to 0 also set the dial on top of the case to 0. Move the Zig-Zag lever (upper right) from 0 to 4 and back again. Respray with Tri-flow. After a couple of days, if it is still stuck place a hair-dryer or light nearby to warm it up to skin temp.
Between the temp and the oil, it should begin working.
Break a Leg!
Posted on Jan 08, 2010
White 1521 only zig zag even on straight setting had it cleaned but still only zig zag zig zag on all setting how or can it be fix?
I don't think it needs to be fixed. If you want to zigzag, there are two setting you need to do. One is the stitch length and the other is the stitch width. When you sew a straight stitch, the width is 0. If you want it to zigzag, make the width wider (usually 1, 2, 3, 4, or sometimes 5). I've looked at the manual for this machine and page 21 has some info. There's probably more if you read further. If you don't have a copy, go to singer.com. They have tons of manuals for many brand of machines. Click on the support button and go from there.
Dec 02, 2017 | Sewing Machines
What number is satin stitch on Piaf quilt expressions 4.0
A satin stitch is simply a zig-zag stitch that is shortened enough so the threads lay next to each other without laying over another but also without any space (fabric) showing between. Keep in mind that the thread weight will cause the satin stitch to differ.
Sewing Perfect Satin Stitch Wildly Wonderful Wearables Patterns Notions...
Feb 19, 2017 | Sewing Machines
Hi! I'm looking for a manual for a vintage Morse 550 zig-zag sewing machine. Need help with tension assembly.
manual for a vintage Morse 550 zig-zag Kathleen, Check the attached links,manuals and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Morse 550 zig zag manual Google Search
Morse 4300 Zig Zag Sewing Machine Instruction Manual Fotomatic III
Morse Pushbutton ZigZag Sewing Machine Threading Diagram
http://www.sewusa.com/Sewing_Machine_Manuals/Morse_Sewing_Machines.htm
Mar 31, 2016 | Sewing Machines
Pfaff 360, how do I stop the zig zag stitch on my machine?
could you explain more about what the machine zig zag stitch is doing or not doing?
Mar 13, 2016 | Sewing Machines
Pfaff tip matric 1047 will not zigzag or create buttonhole when programmed to do so?
possibly could be a problem with the cam that does the zig zag, also could be a problem with the computer, if the problem continues the machine needs to be checked
Feb 02, 2016 | PfaFF Sewing Machines
Pfaff 362 won't zig zag
yes, it's very possible that the control/knob needs to be replaced
or the cam or gear that works the zigzag
Jun 03, 2012 | PfaFF Sewing Machines
Will not zig zag
When you push the button to zig zag what does it do? Are there any messages that come up on the screen?
May 07, 2011 | PfaFF Quilt & Craft Pro 7530
1222 Pfaff can not adjust to a large stitch
Will need more info to help you. Is the white dot on the zig-zag dial still at the top? If not you will NEED (no way around it) a zig-zag dial rebluild. Most pfaff repair shops do not know how to do this repair, will need to find a 1222 expert.
This is my gess with what you have told me.
Hope this helps
Mar 31, 2011 | Sewing Machines
Pfaff 360 automatic slows and stops after only minutes of use
Pfaff 360's don't like to sit, they like to drink. . .. oil.
Set top knob "C" to 0
Right top (zig-zag knob) set to 4, lever below but on the same dial points straight down. Set stitch length to 4. Run 5 minutes medium speed.
After that lift off the top cover and spray inside with "Tri-flow", then run a hairdryer on it for 20 minutes to warm up or set near a warm lamp overnight. Run daily 5-10 minutes and exercise the right knob between 0 and 4 (zig-zag). It should come back to working with oil, time, and heat.
Apr 13, 2009 | PfaFF Creative 7570
Sewing Machines Logo
269 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
