Question about Maytag MAT12CS Top Load Washer
I lost key to my coin machine - Maytag MAT12CS Top Load Washer
Just bought brand new whirlpool top loading commercial washer and dryer with the coin sli
i think the answer is in the question....
you have bought a machine for multiple users (apartment. camping sites)
did you get a key for the coin box?
if so. just keep coins handy run them through the coin-op.
otherwise, you may need to employ an electrician to bypass it
May 16, 2014 | Washing Machines
Lost the keys to maytag coin op washin machine, need to open it
Strike a nice pointed center punch right in the center of each of the rivets shown and drill the heads off of those. This will gain you access to the locking mechanism (defeat the lock).
Mar 26, 2013 | Washing Machines
My machine unable to complete program its saying check coin trap? where is the coin trap?
To find your coin trap:Loot at the front of the machine, and at the bottom-left is the coin trap.Put towels in front of the machine to mop up any water (it's going to get wet).It opens anti-clockwise (remember righty-tightie, leftie-loosey), but you need to move the little bit of yellow plastic (12-oclock position) up first. The machine dose come with a little tool to do this, but you may have lost it. You can move the bit of plastic up by carefully using a flat screwdriver, and turning the round plastic with your other hand. Don't force anything. After you remove it, just swim over to your machine and remove the yellow thing in the middle by pulling it gently towards you. Clean out the coins/paperclips/buttons that you find in there.Push back on the yellow bit into the coin tray, tighten back on the cover the coin tray (the yellow thing at the top will 'click' back).Using a mop, take the opportunity to clean the kitchen floor now that it is all wet.
Feb 26, 2011 | Dyson Memory CRO1 Front Load Washer
Lost coin op washer keys
you need a locksmith.  Because of the key design
Mar 11, 2009 | Maytag MAT12CS Top Load Washer
Open coin trap
use side of spanner to open the circular water drain plug on coin trap, remove all water.
use flat screwdriver to lift yellow tab at top of coin trap whiloe turning coin trap anticlockwise.
Mar 05, 2009 | Dyson Memory CRO1 Front Load Washer
I have a maytag coin operated washer and dryer. After the last service call the repair man ran off with the keys to the coin boxes. How do i get new keys to the coin boxes? Alternatively, how can i remove...
Unfortunately if you do not have a good locksmith, you will have to drill out the locks and replace them. Not a cheap solution by any means.....If I can help further, I am here.... Eric Campion
Feb 27, 2009 | Maytag MAT12CSD Top-Load Coin Operated...
Roper coin operated washer and dryer with no keys
call A locksmith to drill out the lock then re-key the machines
Dec 19, 2008 | Roper RAK2751WWH Top Load Washer
Coin trap
Bosch, the maufacturer @ 1-800-944-2904 says there is "no" coin trap so whatever is lost in the washer has been flushed down the drain , lesson learned : check your pockets and collars before you wash,everytime.
Jun 14, 2007 | Bosch Nexxt Premium WFMC6400UC Front Load...
Maytag MAT12CS Top Load Washer Logo
23 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
