Lg wth 750 washing machine top loader
I get soap **** all over my clothes no matter how many times I clean the machine...can you help...it's driving me crazy...
    Top Expert:
  • Washing Mach... Master
  • 35,531 Answers
The instructions for your washer may advise what type of detergent to use and how much. If not, refer this issue directly to LG.
Posted on Jan 01, 2014
  • 100 Answers
SOURCE: diesel smell in washing machine
Try using a cup the the same soap you would put in your dishwasher and run is with the hottest wash setting possible
Posted on Oct 30, 2007
  • 209 Answers
SOURCE: Brown spotting on washed clothes
chances are if you have eliminated anything thats got in by accident that the drum bearings are about to go, the drum bearings are protected by a water seal, this has started to leak and is now washing the grease out of the bearings back into the wash, you may also find a small amount of water on the floor, if you also remove the back and look behind the large pulley you may also see brown water marks running from the center of the outer drum
the next step will be a very noisy spin, like a rumbling noise
DRUM BEARINGS sorry
Posted on Oct 15, 2007
SOURCE: hoover 600mb 6.0 kg top load washing machine (not as below)
Machine unbalanced or belt is worn maybe
Posted on Apr 04, 2008
TechBrian
  • 15 Answers
SOURCE: Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Posted on Mar 10, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
How do i use LG front door washing mechine
These are very similar to top loaders, with the exception of the fact that the use a fraction of the water the older top loaders use. To work best, use the recommended amount or less of your favorite detergent that is available as an HE formula. The HE detergents to not create as much suds as the non HE types; which is required with the small amount of water the machines use. It also ensures the clothes will rinse all soap out completely. Resist the urge to use the less expensive "regular" detergent instead of the HE types - it will cost you more in the end if you don't - trust me. Like top loaders, don't overload the machine either.
When done washing clothes for the day, leave the washer door open over night - to allow the insides of the machine to dry. These doors are water tight as opposed to the top loader and allowing it to dry will prevent nasty mold from forming inside. You might consider running a clothes-less cycle with hot water and bleach to kill mold or as a preventative measure once a month or so too.
Feb 20, 2015 | LG Washing Machines
My washing machine fills with pieces of black matter. I have done machine clean washes and it still happens every time, covering my clothes in black pieces that look like cardboard. Please help my - the...
Hi mine does exactly the same! I have to call in my washing machine technician more often (he told me this would happen with a top loader as opposed to a front loader, boy was he right!!) and he cleans out the drum. Mostly it is the fabric softener which is too thick. I water mine down to 50/50 and I do another spin after my final wash. I also empty the filter of water at the side/bottom of the machine. This annoying problem is caused by the way the drum turns on a top loader as opposed to the front loader. My top loader cannot heat water automatically either like a front loader, and I think this also adds to the problem as hot/boiling water would dissolve all that soap/fabric softener. Hope this helps.
Jul 12, 2014 | Samsung SW62ASP Top Load Washer
Mold and mildew in door deal of LG front loader WM
Barb,
This is a problem with all front loaders. We have used those cleaning tablets in a regular hot cycle per the directions on the box. You can also try placing 1 cup of crystal dishwashing detergent in the tub and fill the soap dispenser with bleach and run a quick cycle full hot.
Aug 09, 2009 | LG WM-2277HW Front Load Washer
Clothes are not clean How can I take washer aprt to clean soap dispenser???
Make sure you are washing at the correct temp, and that you have the correct prog selected for what you are washing. and that you have suficient powder and or detergent in. Check to see if the water is getting hot, because if it is not , then the heater may not be working, and then your clothes will not be clean.
Hope this helps with your prob.
Plz rate my solution.
Thanks.
Jan 03, 2009 | LG WM-2277HW Front Load Washer
Mildew smell on cloths
The brand of your front loader is not that material on this issue. What is happening is that your old top load washer may have used as much as 45 gallons of water per cycle, while some front loaders use as little as 12. Because of the low water use, you must cut back on the additives you are using. Use only 1 tablespoon of HE detergent (even less if 2x or 3x detergent) per load. If you use fabric softener, use only 1 teaspoon per load. Odor on clothes after wash is indicating that the detergent and or softener has not been fully rinsed out. If you throw a load of washed towels into your machine and start a cycle without any soap, then stop the cycle, you should not see any suds. If you do, there is obviously soap left in the clothes. With bath towels, the towels are used to absorb clean water off a clean body. They do not need soap when you wash them, and never use fabric softener on towels.
If your washer is a LG WM-1832 it has a assessable filter behind the access door on the lower left front of the machine. Clean that out first, and if it has a tub clean or sanitary cycle use that cycle (if not, use hottest longest cycle available) with 3 Affresh tablets or use whirlaway to clean out the washer outer tub (the not visible tub that holds the water). You might want to use another cycle like that with bleach to head off mold or mildew growth. Use of proper amount of detergent and fabric softener should really help the clothes odor issue from then on. Also check the tub seal at the bottom of the door area to clean out any lint from drain hole areas to help prevent water from remaining in the tub seal area.
Oct 28, 2008 | LG WM-1832C Front Load Washer
Usage of HE detergents
The best he soap I have seen yet is all, he is high effieciency low suds soap. The rule of thumb for liquid he soap is 2 Tbl for every 1 Tbl of softener. Powder can be used but is not good on pumps and build up in tubs. If you have a water softener you can use 25% less soap. Still with powder you need about a 1/4 cup per load to equal a 2 Tbl liquid variety. Suds damage pump impellers, seals and hoses from expansion and that is it on the reason "why to use he".
Sep 04, 2008 | LG WM-2277HW Front Load Washer
Front loading washing machines
not really front loaders have top loaders beat all the way but stay away from admiral and maytag .a front loader will wash your clothes using the soap that your top load failed to get out if i may suggest buy a frigidaire with a mechanical timer not electronic control more junk on them more to fail the best combo in my mind is a frigidaire front loader and whirlpool dryer front loaders use 2/3 less water 2/3 less soap and will get your clothes twice as clean they have no transmissions and are direct drive the most common promblems with them is having to clean out the pumps where people leave stuff in their pockets also you need to buy soap thats for front loaders its called high effincey or he soap and they will get your clothes make sure you read the installation guide and remove ALL the shipping braces
Mar 18, 2008 | Admiral AW22 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
