Question about Marantz Audio Players & Recorders
Marantz pm 6300 amplifier problems
Pm 6300
jedimazter
  • 7 Answers
SOURCE: marantz pm 7200
Could be a power supply failure or a Power "On" switch failure.
Kev
Posted on Feb 24, 2008
robotek
  • 1512 Answers
SOURCE: Marantz PM-34 Problem
Hi there
The part that you speak of is called the emitter stabilizer resistor. It is common to the output pair on one channel. You will find that the large "output" transistors mounted to the heat sink either side of this resistor will most probably be faulty.
Best not to run the amp at all whilst in this condition.
To be sure that you have an effective repair, you will need to change both these parts, and also the "driver" transistors that connect to the outputs. They too are in symmetrical positions close to the the output transistors. You should also check that the 3 legged resistor you mentioned is measuring its correct value, and check all other low value resistors in the output stage area to that channel.
If you are not familiar with repairing this sort of equipment, perhaps you can find a repair guy with some experience on audio equipment, then this work should be all he needs to do to repair the amp. I would also ask him to "blanket resolder" the output/bias stages and power regulator stages in the amp as problems with heat stressed cracked/failed soldering and dry joints often cause these amps to blow the output transistors.
BE SURE THAT THE CORRECT PARTS ONLY are used for the repairs. Different transistors could cause future problems with the amp. The parts can be obtained relatively easily from a marantz distributor(we can find one in a country near to you). OR if you can give me the markings to each of the parts you need, I can provide you with an international source to get them from.
The amp is decent HiFi, and worth repair. Happy to provide you any assitance I can, Good Luck
regards
robotek
Posted on Nov 03, 2008
mikeymiddles
  • 58 Answers
SOURCE: marantz pm 7200 integ.amplifier
Dear Sushant,    I do not think your use of an equalizer has caused any problems.  I will explain the proper use of the source/direct button.  This button's function is to monitor the output of a recorder connected to the record outputs of your amp.  When this button is pressed on the sound going to the speakers comes direct from the "source" (cd, radio tuner, phonograph etc.) when in the off position you can monitor the recording of whatever source is being recorded via the tape deck.  This switch must be off to record through the amps record outputs.    To test this, put a blank tape in the tape deck, choose the source as phono and place the dec in record/pause.  With the source direct button pressed on you should hear a change in volume when moving the amp's volume knob only.  When source direct is off you will be able to hear the output of the tape deck, so adjusting the tape deck's record level will also affect the volume coming out of the speakers.  more record level in/ more level out.!    Below is copied from page 9 of your user operation manual for Marantz's explanation of the source/direct button.  image.tiff
best of wishes, Michael Mittelsdorf
Posted on Jan 05, 2009
  • 66 Answers
SOURCE: Marantz Pm-7200 left channel weak compared to the right
hmmm. Let's start by swapping the wires you are using for your speakers. Double check the wire connections first, then take the left and place iton the right and vice versa.
Posted on May 05, 2009
  • 99 Answers
SOURCE: Marantz PM-48 connecting to TV
look on the back of the TV and there should be L/R audio outputs (white & red), connect this to a spare input of your amp via a connecting lead eg. AUX or any other input except PHONO.
hope this helps.
Posted on Jul 02, 2010
The fuse keeps blowing in my marantz pm-57 amplifier. It says it takes a T 2.5A 250V fuse. I can only find 2.5A 250V fuses. What relevance is the ''T''.
Goo day sir, the T on the fuse has nothing to do on you marantz fuse blowing up, chances are you amplifier is shorted, check you IC amplifier/power transistor for shorts. Check also your speaker impedance. usually they are 8 ohms. You can use a technician's multitester device to check the impeadance. An imbalance or mismatch speaker can cause a fuse to blow and destroy your amplifier. hope this helps.
Jul 31, 2009 | Marantz PM-15S1 2-Channel Amplifier
Marantz pm 15 s1 amplifier and marantz sa15 s1 Cd player
There really is no point in  connecting the two components with an optical (=digital) cable, if you didn't want to use the SA-15s DAC- and analog output section you might aswell have bo bought the chiepest one you could find...
To get better sound than the SA-15s analog outputs can provide, you would have to spend a load of money (not as much as for the SA-15 but quite a bit) on a DAC - and the DAC would only work with CDs, you would still have to use the SA-15s analog outputs to listen to SACDs.
So in conclusion:
-Use the SA-15s analog outputs
-If you have other digital sources that you want to use - if you care about their sound quality - you can sell/return the SA-15s, buy the chiepest CD-Player you find (only look and feel matter) and spend the rest on a good DAC. (note: SACDs won't play on this setup)
I'm using a PM-15S1 with a DAC (Apogee Mini DAC, Studio-Equipment, nominal price ~1000$, got mine 2nd hand for 400€ ) myself. A DAC is usually the better choice over an expensive CD-Player - especially if you've got other digital sources (PC, ...) - but you'll probably lose a lot of money if you sell the SA-15, so think about it (IF you're still thinking about it, I realise that your question is 8 months old...)
anyway... have fun with the PM-15, it sure is beauty
Jan (Hamburg, Federal Republic of Krautistan)
Jul 01, 2009 | Marantz PM-15S1 2-Channel Amplifier
May 05, 2009 | Marantz PM7200 2-Channel Amplifier
How do I connect a subwoofer to an amplifier marantz pm-68
double up the speaker and then use the two extra screw to hook sub and center
Feb 10, 2009 | Marantz PM-68 Amplifier
Heat in operation of marantz pm 74d
Sounds like your left channel output transistors are getting weak.
Jan 17, 2009 | Marantz PM-68 Amplifier
Can I remotely control speaker outputs on the Marantz PM 8003?
HI...
You need an 8 ohm stereo "L-pad"
Try partsexpress.com
or
mcmelectronics.com
Dec 21, 2008 | Marantz Audio Players & Recorders
Marantz PM 4000 has cut out
May be the problem solved here :
http://www.audiotoolers.com/ubbt/ubbthreads.php/ubb/showflat/Number/5316/page/1#Post5316
Nov 21, 2008 | Marantz Audio Players & Recorders
hope this helps.
Oct 19, 2008 | Marantz PM-68 Amplifier
Marantz pm 7200
Kev
Feb 23, 2008 | Marantz PM7200 2-Channel Amplifier
54 people viewed this question
Top Marantz Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
