Fujitsu asta24jcc timer 2 green flashes
Fujitsu split. Asta24jcc indoor unit running, no cooling, timer light 2 green flashes
    Habit-Forming:
  • 109 Answers
The indoor unit has the problem and it's the air thermistor. You need to replace it.
Posted on Jan 01, 2014
4 Suggested Answers
  • 10 Answers
SOURCE: Outdoor unit does not start. indoor unit fan does run.
by the sound of it the relay in the outdoor section is bad
Posted on May 31, 2009
jgwhomeequip
  • 1902 Answers
SOURCE: Fujitsu mini split outdoor unit not running, but indoor unit is running after turnning on
Check the disconnect switch and make sure that both the fuses are good and not shot. If one is shot then the system wont work. There are two fuse. Also be careful due to you will be working around 210 volts
Posted on Jun 01, 2009
hvac1960
  • 2133 Answers
SOURCE: fujitsu asta24jcc error code is 4 x grenn and red
Indoor pipe sensor faulty..Replace it.
Posted on Jan 19, 2011
My Fujitsu ASTA30JCC has the timer light ( green) flashing twice every 15 seconds and is not cooling
Serial signal error. This means that the outdoor unit is not talking to the indoor unit. There are 5 circuit boards in the outdoor unit and the faulty board could be any one or combination of these. Usually it's the controller board but you will need a tech to diagnose.
Nov 23, 2017 | Fujitsu Heating & Cooling
Fujitsu ASTA12LCC WILL NOT HEAT OR COOL. GREEN TIMER LIGHT FLASHES TWICE AT INTERVALS. FAN WORKING. IS IT REPAIRABLE?
Serial signal reverse error. Basically the outdoor unit is not talking to the indoor unit. This is normally due to damage to the outdoor controller PCB and it needs to be replaced.
Jul 03, 2017 | Fujitsu Heating & Cooling
FUJITSU Inverter wall mounted split air conditioner Model : AST12LSBCW not working, flashing lights
This is a "PFC circuit abnormal" in the outdoor unit meaning that the outdoor controller board is faulty. Try turning the machine off at the isolator switch for 10 mins, then back on to see if the error resets. If not you will need a new controller PCB.
Nov 15, 2016 | Fujitsu Heating & Cooling
On my Fujitsu ASTA24JCC wall mounted A/C The operation and timer light flash together x 2 then operation lightred flashes another 3 times after. Then repeats all over again
CT abnormal. This is the current transformer error. It usually means there is a problem with your controller board in the outdoor unit. You will need a tech to check that the compressor and fan motor are OK before ordering a new controller board.
Jan 09, 2016 | Fujitsu Heating & Cooling
I have two flashes on the timer light of my indoor unit of Fujitsu Inverter ASU9RLS
Serial signal (reverse) error, at operation start up. operation led - off, timer led - 2 flashes, coil dry led - off, check wire between indoor and outdoor
Jul 10, 2015 | Fujitsu ASU9RLS2 Single Zone Wall Ductless...
I came across a brand new Fujitsu Split System out door unit (AOTR24JCC), so Im look for the indoor unit (ASTA24JCC) Where can I find one? Thanks
Model is over 5 years old so unlikely to get a new one. However, the outdoor units fail while the indoor is good so check eBay or your local installer.
Feb 01, 2014 | Fujitsu Heating & Cooling
My fujitsu inverter asta12jcc outside fan is not working. On the inside unit the operation light is on for a few seconds than the green timer light flashes every few seconds. but the fan inside is running.
Communication error between indoor to out door.Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Jan 02, 2011 | Heating & Cooling
Heating & Cooling Logo
350 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
