Question about Kitchen Ranges
Auto timer on blanco bose 960 oven - Kitchen Ranges
Blanco oven bso 422w..The thermostat light "C" will not go out when everything turned off
DO YOU KNOW WHAT THE C STANDS FOR? DOES IT STAND FOR CLEAN? IF SO MAYBE YOU NEED TO CLEAN YOUR OVEN IF NOT LOOK UP ON LINE TO FIND MANUAL. TYPE IN BLANCO BSO 422W MANUAL OR MANUAL FOR BLANCO BSO 422W.
Jan 28, 2015 | Blanco Ovens
I'm after a blanco oven manual for BSO632. The
Blanco Oven
http://www.scribd.com/doc/7992811/Blanco-Oven
Sep 20, 2014 | Ovens
Hi, my Blanco freestanding electric oven-FD9045WX-(gas cooktop) went out with a flash & a bang. The fan element was in pieces and the thermostat totally fried. The clock/timer does not go nor do the sparks...
Check for power at the supply terminals, follow it up to the high temp cutout > timer > multifunction switch > thermostat > element
Careful, don't electrocute yourself!
Oct 13, 2013 | Ovens
Hi i have a blanco electric oven model no bms 901 sse and the timer shows A and no time . And the oven does not work can u please help me
I had a similar problem with the same model of Blanco Oven but in my case the clock was completely dead apart from the letter A which was lit (and this proved there was power to the oven).
The oven would not work because the clock module (electronics control unit) was dead.
I rang a Blanco parts supplier, who advised the clock module was no longer available (Blanco advised the same). Another supplier said they could supply the clock module for A$425 which is an absolute ripp off (a reasonable price would be A$50 as it only has a couple of components).
As the clock module is not essential (it only provides the time, alarms, and fancy features most people don't need) I decided to by-pass it by shorting out the two (brown) wires on the LHS (which connect to the relay on the clock module). In effect it behaves as if the relay is always ON, supplying power to the stove.
The oven now gets power and works fine and it cost me virtually nothing to repair. I strongly recommend this solution to anyone experiencing problems with the clock module.
Some basic understanding of electrical/electronics systems is all that is needed to implement this repair.
Aug 10, 2011 | Ovens
My Blanco oven will not work. Display shows 0:00 'auto' flashing. Cooktop works fine. I have checked the manual but it was of no help. Model number is BF95W. Tried turning off/on at power. This did...
Hi You need to set your clock If it is a digital timer you usually have to press 2 of the buttons on the bottom and once you see a change in the clock (usually it stops flashing) press the up or down button to set the time once the time is set you may need to push the manual button sometimes this button is identified by a hand regards Geoff Stove Recyclers WA
May 29, 2011 | Ovens
How do we make the oven work?
Have a look 1/2 way down this page: http://www.blanco-australia.com/Blanco-User-Manuals.html BCG95W and others are listed. Regards.
May 25, 2010 | Ovens
Oven Problem
http://www.blanco-australia.com/IgnitionSuite/uploads/docs/BSO632.pdf
This link should take you to the manual- if not, go to www.blanco-australia.com, link on "customer service", select "user manuals", and scroll thru to your model BSO632
Jan 15, 2010 | Bosch Ovens
Kitchen Ranges Logo
16 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
