Question about Samsung 4.0 cu. ft. Washer
What makes a samsung sw68asp agitate one way - Samsung 4.0 cu. ft. Washer
Samsung top loader, inner and outer drum not cebtralising and making noise when spinning
check for unbalanced spring tensions and some dirt in the agitator motor. thanks.
Mar 02, 2016 | Samsung Washing Machines
Agitator only going in one direction
either clutch pawl tip broken or fallen off or capacitor fault
Nov 14, 2015 | Samsung SW62ASP Top Load Washer
Samsung washing machine model no WA80T4G everything is alright water also taking inside but wash & other options not working
No agitation or spin? try these:
Motor Coupling If the washer won't spin or agitate the motor coupling might have failed. The motor coupling connects the motor to the washer transmission. It is designed to fail if the washer is overloaded in order to protect both the motor and
Drive Belt If the washer won't spin or agitate, check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't spin or agitate properly.
Drive Motor If the washer won't spin or agitate the drive motor might be defective. This is not common. Check all of the other related parts to this symptom before replacing the motor. If the motor is visibly burned out or physically damaged, replace it.
Stator Assembly If the washer won't spin or agitate the stator assembly might be burned out. The stator is essentially one half of a motor, it interacts with the tub by creating a strong electro-magnet. If the stator burns out the washer won't spin or agitate. Check the stator for continuity. This part is often misdiagnosed.
Transmission or clutch assembly not engaging due to going out or slipping.
Door or Lid Latch Assembly If the washer won't spin or agitate the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Door Lock Motor and Switch Assembly If the washer won't spin or agitate the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Motor Control Board If the washer won't spin or agitate the motor control board might be defective. The motor control board provides power to the motor as well as direction and force. If the motor control board is defective the washer may not work at all or function properly.
CHECK THE CAM DOGS INSIDE THE AGITATOR, AS THEY WILL HINDER THE AGITATION PROCESS.
Mar 17, 2015 | Samsung Washing Machines
How do I remove the agitator from LG top Load washer
the agitator is held by a bolt with a 7/16 drive nut located inside the middle of agitator from the top downward? however by ur description sounds like maybe u have bad bearing in the hub? the cam dogs in the agitator dont usually make any noise especially when bad they just dont allow the agitator to move or catch the groves to agitate. The grinding could also be coming from something stuck inside the tub or on its outside and thus is hitting the wall lining and makes a screeching scraping sound, Ive seen this several times, a bra wire, or loose coin or key, etc
Sep 28, 2014 | Washing Machines
My Samsung SWT5V9W top loader spins when you turn the power button on. It still spins during the cycle and 'fights' itself to agitate. Would this be a computer issue?
This can be related to a mechanical issue, Check for free movement of the drum and shaft. check the mountings of the motor,check the suspension and finally the level of the machine, use a rubber mat if the machine moves around.
Jan 23, 2013 | Samsung Washing Machines
Samsung sw68asp manual
Hello & Welcome to FixYa
Please click on this link to download the manual. Please get back if you have any other questions.
Kevin
Nov 24, 2012 | Samsung Washing Machines
Agitator making clicking noise when washing clothes; clothes wrapping around agitator
If this a whirlpool brand washer, there are sone parts bad in the agitator it's self. These parts are called dogs and they make the agitator rachet so that the top half only goes one direction. Does this sound like what you are experiencing? If so, let me know and I can assist you further.
Thanks
Vic
May 13, 2009 | Washing Machines
How do I locate the water pump on my Samsung SW68asp. I think there's something stuck in it.
pump on samsung is better acessed from back remove rear panel that should at least give you abetter idea
Apr 24, 2008 | Washing Machines
Samsung 4.0 cu. ft. Washer Logo
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
