Question about managemylife.com
I have a Craftsman 1 hp 12 gallon oil lubricated air compressor with a bad motor/pump. Sears Parts Direct no longer carries the motor. I need the part number of the motor to begin a search for a replacement. I believe it was made by Midwest Air Technologies but I have been unable to get them to return my phone calls. Can you help
    Sergeant:
  • 316 Answers
I don't think you need an exact replacement. I think you can go to Harbor Freight and get a 1 hp electric motor with the same shaft size and use the pulley off the old motor. You may have to make a few modifications to mount it but it should work ok as long as the RPM of motors are the same.
Posted on Jan 01, 2014
What type oil for model 90234 4 HP 10 gallon
The model number is not enough info but assuming it's a run of the mill, Home Depot or Craftsman type electric air compressor, you need to buy compressor pump oil at Wal Mart or an auto parts store. Please don't use Automotive motor oil because that's not going to withstand the heat of your compressor pump and you'll be buying a new compressor because of it. If your compressor has a gasoline, 4 Hp. motor, it needs Mobil 1 synthetic and change it after every 30 hours of operation.
May 19, 2017 | HP Air Tools & Compressors
What oil do I use for a G Force 2 HP air compressor, model 50622
  • www.air-compressor-guide.com/.../air-compressor-oil Keep your compressor in top condition by using the right air compressor oil. Make your compressor run nice and smooth. Using the right air compressor oil for your ...
  • Oil - Air Compressor Oil ' RONA www.rona.ca > ... > Parts and Accessories - Compressors Compressor oil. 473 ml. For all oil lubricated air compressors.
  • Husky 16 oz. Air Compressor Oil-HDA10700AV - The Home Depot www.homedepot.com/p/Husky-16-oz-Air-Compressor-Oil-HDA10700AV/...
    • 5/5
    • 1 REVIEW
    • $2.49
    • IN STOCK
    Air Compressor Oil from Husky is designed to reduce carbon buildup in compressor valves to ensure a longer compressor life.
  • Air Compressor Oil & Lubricant www.ecompressedair.com/compressor-oils.aspx eCompressedair is your source for Air Compressor Oil & Lubricants for major air compressors and synthetic compressor oil brands in 5 gallon air compressor oil ...
  • Oil-free air compressors - Atlas Copco Canada www.atlascopco.ca/caus/products/air-and-gas-compressors/1472896 Oil-free centrifugal compressors. Oil-free reciprocating piston compressors. Oil-free rotary tooth compressors. Oil-free screw compressors. Oil-free scroll compressors
  • Air Compressor - Oil-Free Air Compressor ' RONA www.rona.ca > ... > Products > Tools > Pneumatic Tools > Compressors Air Compressor - Oil-Free Air Compressor. Oil-free air compressor. 26 gal. Vertical, saves 50% more space. 1.7 running HP. 120 V. 15 A. Easy to operate controls with ...
  • May 17, 2016 | Air Tools & Compressors
    Sears troubleshooting
    Sounds like motor is frozen; it happens. Most likely its bad brushes and/or commutator. It will be cheaper to buy new motor or compressor.
    Jul 30, 2014 | Craftsman 25 gal Air Compressor 3 12 hp...
    Why won't it pump up past 40#?
    If you don't have any air leaks, the cylinder head gasket is probably bad on the pump. Easy fix for less than $10. you can get the parts you need here:
    http://www.mastertoolrepair.com/sears-craftsman-919195411-p-48270.html or ebay.com. For around $50 you can get the whole rebuild kit.
    May 09, 2014 | Craftsman 20 Gallon Portable Horizontal...
    My new 80 gallon Craftsman Professional air compressor's oil turned dark right away. I changed the oil and it happened again. Is there a problem? Thanks, Trevor
    Problem sounds like the type of oil being used. The oil should be a gold color. It will get dark over time but not like oil in a car. Check your owners manual to be sure that the right oil is being used.
    Compressors use a 30 weight non detergent oil. If you don't have a manual Go to any Sears Home and garden Department and they will be able to help you.
    Feb 22, 2011 | Craftsman 25 gal Air Compressor 3 12 hp...
    I just bought a used Craftsman air compressor at a garage sale...100PSI, twin cylinder, 1HP motor. Model # 106.154440. Runs fine, but wondered how to check the oil level in the compressor case and if it...
    I have a Sears 106.154581 most likely like yours. You will find a small plug (fill hole) and slightly larger plug on side of pump close to bottom (drain hole). Fill compressor with compressor oil to top thread of fill hole. Oil should look rather clear with very little odor. Compressor oil is available at Lowes for about $3. Good luck
    Aug 16, 2010 | Craftsman Air Tools & Compressors
    Broken connecting rod
    i broke the rod in my air compressor and cant find a place to buy a new one it is a pro source
    Nov 10, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
    Sears Craftsman 3-Gallon, 1.5 HP Air Compressor Hums
    YES IT MAY BE THE CAPACITOR . IT COULD ALSO BE THE WIREING IN THE MTR, THE PUNP ITSELF.
    managemylife.com Logo
    41 people viewed this question
    Top managemylife.com Computers & Internet Experts
    thinksewfast
    Are you a managemylife.com Computer and Internet Expert? Answer questions, earn points and help others
