Question about Craftsman 25cc Gas Line Trimmer
Craftsman lawn will not start
What should I do to get it started. I already put in a new plug and gas and oil mixture
  • 10,865 Answers
Your carbeurator is crudded up. Get some carb. cleaner spray and remove the air filter to shoot a couple of squirts into the air intake. repeat until it starts and runs smoothly.
Posted on May 20, 2009
What is fuel mixture on 25 cc craftsman weedwacker
This small engine needs a 40:1 ratio. Use only 2 cycle oil, not motor oil. If you are mixing one gallon of fuel use 3.2 ounces of the 2 cycle oil. This should give correct mixture so you do not get lots of smoke when you start. Take the time to measure. Note: there should be a marking somewhere on the engine about the mixture.
Sep 21, 2014 | Craftsman Convertible 25cc Curved Shaft...
I have Gas in my oil sump and sprays mixture out exhust when trying to start mower
what has happened is the rubber seal on the needle and seat has dried out and fuel is leaking passed then the carb overfills and then the gas flows into the cylinder and crankcase
Sep 03, 2012 | Craftsman Garden
I have two craftsman lawn mowers that will no start. Both have new plugs and are sparking. Changed air filters and oil. One will start for a couple of seconds then stops. When I kept priming it, it stayed...
it sounds like you have compression but the fuel air mixture is out of setting. This could be due partialy to a stuck fuel needle or mixture needles that are worn or out of allignment. If you could give me the model # on the unit i could help with the type of carb and the inital settings on the mixture needles.
Dec 24, 2009 | Craftsman Garden
Won't start
May have moisture in the fuel. Try draining the old fuel out, put in new, add Stabil, or some other fuel stabilizer, clean & gap plug. Should start.
Oct 31, 2009 | Craftsman 4 Cycle Blower/Vac
Willnot start no matter what new plug fresh gas
90 %of the time its a fuel problem either it turns stail and clogs the carb or the wrong oil/gas mixture etc, try this first dump out your gas can and refill it with the proper mixture use PREMIUM GAS then fill tank remove air cleaner prime fuel line r&r spark plug with new one then shoot a little starting fluid as you start it if you can get it running alot of times you can blow out the gunk/gum causeing the problem? if this dosnt work i would probbably toss it for a new one ? the repair bill will cost more than a new one ? hope this helps
Aug 26, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman Lawn Tractor/ hard start/ whitish smoke
does it turn over slow or fast if it turns slowly thats the problem so it could be battery or starter they have to have a good amount of rpms to burn fuel right when starting if not it floods out the engine with gas hope this helps thanks wade
Jul 05, 2009 | Craftsman 21 Hp 42" Deck, Ys 4500 Lawn...
Craftsman 6.75hp self propelled mower starts and turns off
I think that this is a 4stroke engine and runs on neat petrol.Have you been putting oil in with the petrol like a 2 stroke engine needs because this would account for the smoking.If not the check that you havn't overfilled the gearbox oil.
Jun 12, 2009 | Craftsman Garden
I just foun out that i forgot to add oil to gas mixture to my blo
hello, what you should do is drain out the gas from the tank into a clean container so you can add the oil to it and you should also check your spark plug make sure it's o.k. after draining out the gas try starting the blower a few times with out the spark plug wire connected to the spark plug this will flush out and of the pure gas from the fuel lines, after doing this re-connect the Spark plug wire and add your fuel/oil mixture and re-start, it might take a few times for it to start due to all the gas in the engine but it'll start also if your blower has a primer bulb you may want to prime it a few times after adding the fuel oil mixture to get it in the combustion chamber, if after doing this you still get nothing you'll want to re-place your spark plug it might be fouled out. good luck
Mar 25, 2009 | Craftsman 4 Cycle Blower/Vac
Wont start
try some starting fluid in the intake, clean the spark plug. is it an old blower?
Mar 20, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 25cc Gas Line Trimmer Logo
135 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
