Question about Polaroid FLM-3732 Television
Can't get the darn panel offin the back of the TV
I tried to take the back panel off but no matter how many screws I take out it still won't budge. Someone please Help. Ty Clarissa of Colorado
  • 112 Answers
Only 3 screws necessary to remove back plastic panel.
(1 large black, 2 small black)
Pull down - use fingernails if needed - and out to remove.
http://www.fixya.com/support/r741402-polaroid_flm_373b_lcd_tv_black_screen
Posted on May 22, 2009
How do I take apart a Boston Acoustics BA7800 subwoofer?
If you've undone the 8 screws on the back panel... I would suggest the only thing holding it in is..... it's an interference fit... try carefully prising it out.
Nov 18, 2014 | Boston Acoustics (BA7800) Computer...
Tip
My panel won't come off, I've taken out all the screws but it's...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jul 26, 2011 | Washing Machines
Lens stuck open
None of the suggested solutions worked for me and my Elph 300HS. However, I took it apart, removing the back. There was a screw inside holding on the front panel which I could not budge no matter what, so I gave up. I put it back together, reinserted the battery, powered on and voila, it was back to normal. Perhaps disconnecting the battery for a while was key. Had I not tried the multi-step approach suggested, it would still be stuck. Caution: Beware the capacitor. It must be discharged if you go into the camera or it can knock you across the room.
Dec 11, 2013 | Samsung S860 Digital Camera
Canon efs 18-200 zoom lens stuck
Nov 03, 2013 | Cameras
Fan pulley nut won't budge
it may be reverse threaded
Aug 11, 2012 | BMW Cars & Trucks
Can't get the handle off the faucet hex won't budge
Don't even bother. I have 3 Delta shower faucets and have run into the same issue WITH ALL 3 .
Step 1: Call Delta and have them send you replacement parts before you follow the next step (Trim sleeve, cartridge, handle)
Step 2: HACKSAW just outside the handle, right through until it snaps off.
That's the only way you will be able to access the nut.
I tried eveything - Vinegar, WD40, CLR, Banging, Jiggling...
Problem: The brass nipple on the cartridge will fuse with the metal on the handle. Alternately, so does the Allen Key screw. They will not release no matter how hard you try.
I called Delta and they confirmed that the two metals will fuse together over time (a short period of time, in my case), but it's not a fault design but the water. Their solution (moving forward) is to wrap the brass nipple with Teflon Tape before attaching the handle, so that the 2 metals won't make contact.
However, one would think that Delta would rectify this issue. Say by enclosing a thin plastic cap that seats over the brass nipple, or better yet, pre-coat the inside of the handle themselves?
Regardless, don't expend too much energy. If you can't loosen anything,
HACKSAW RIGHT THROUGH THE TRIM SLEEVE AND BRASS NIPPLE OF THE CARTRIDGE and snap it off to access the cartridge nut.
Apr 01, 2012 | Delta & Single Handle Shower Faucet
I am trying to get the case of this darn thing, I have removed all the screws and it won budge Help!
Go to www.singerco.com and get a copy of your manual for free, you can also call them at the number on their website
Aug 23, 2010 | Singer 118 Mechanical Sewing Machine
Removing the base on a tv
There are 5 screws on the back of the TV under the inputs in an x pattern:
X X
X
X X
Remove these and set aside. You should also see 2 screws on either side of the X pattern, loosen these. You should then be able to slide the TV off the base. Remember to re-tighten the loosened screws. Place the removed screws in the base in case you ever wish to use it in the future.
Nov 30, 2008 | Digital Lifestyle FA1B32Z 32 in. LCD...
Televison & Video Logo
248 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
