Question about Lanzar Htg157 htg157 3000w Heritage Monoblock Mosfet Power Car Amplifier/amp
Keep blowing fuses
It plaed for a fe minutes ane blew the fuse now it wont play it keeb blowing the fuses
Why would my iron heart Lainey 212 combo amp combo be blowing fuses?
Because some component in the amp is failing/failed and drawing too much current. The amp needs a repair shop. Poking around without knowing what you're doing can expose you to leather voltage. Don't do it.
Oct 13, 2016 | Laney IRT60H Ironheart Guitar Amplifier...
My aquabot keeps blowing fuses in or out of water
may be waterlogged. internal seal failed and its shorting out..
Aug 06, 2012 | Pool & Spa
2003 nissan pathfinder blows tail lamp fuse
you got a wiring issue that keeps shorting out fuses find that and that should take care of everything else
Mar 08, 2012 | Nissan Pathfinder Cars & Trucks
I purchased an orange terror bass 500 watt amp online. I plugged it in andit played fine for roughly 10 minutes, then the fuse blew in the back. Now I am having trouble locating a new fuse, andin doing...
please dont keep replacing fuses...its a short in the actual amp circuit..causing this issue...yes contact orange or go to a retail dealer...for quicker repair or replacement...also google product brand and model for any type of recall..for fire hazards....
Apr 27, 2011 | Audio Players & Recorders
Chevy silverado keeps blowing fuses
Your 20 amp fuse will not blow if glowplug wire shorts. each plug draws 15 amps which is 120 amps total.I think there are in line fuses for them. Try to wring out where each output from the fuse goes, disconnect all and reconnect one at a time till it blows.That should point to your problem process of illumination! Good Luck!!
Aug 25, 2017 | 1994 Chevrolet K1500
Heat worked fine all winter. Turned on A/C and blew a fuse. Replaced 3amp fuse and worked for a few minutes and blew another fuse. Checked all connections, filter, obstructions, need help...
If your blowing fuses then you have something grounded or shorted. By grounded I mean a wire has come loose and is touching the cabinet or a part that allows it to go to ground or your motor, capcitor or compressor is shorted.
Apr 25, 2009 | Heating & Cooling
Fuel system fuse keeps blowing
where wire run to pump over fuel tank i thing you will find they are chaffed .use a lenth of twin flex and rewire it quickest and easyest
Feb 02, 2009 | 1991 Jeep Wrangler
Hotpoint NVL333EY Electric dryer blows thermal fuse
I had the same thing happen, I replaced the thermal cutoff and made sure no lint build up. It lasted a week then blew again. I then replaced it again and got to thinking why it would blow. I then took apart the exaust inside the dryer running fron the drum to the motor and right before the motor was a build up of lint ane particals that was almost like compressed sawdust which was blocking half of the line. I cleaned this out and it seemed to work much better.
Jan 04, 2008 | Hotpoint NVL333EY Electric Dryer
Car Amp keeps blowing fuses
The reason why fuses blow is that the current is too much. Is the fuse rating according to the specs ? If yes then ... One or more output power transistor (or audio power IC) may be shorted. have it checked before replacing another fuse as this might cause more damage.
May 22, 2007 | Profile CL1200 Car Audio Amplifier
Lanzar Htg157 htg157 3000w Heritage Monoblock Mosfet Power Car Amplifier/amp Logo
114 people viewed this question
Top Lanzar GPS Experts
Are you a Lanzar GPS Expert? Answer questions, earn points and help others
