Question about HP w17e Monitor
Hp w17e monitor randomly shuts off and turns back on
I used this monitor for almost 3 or 4 years. it started few days ago. the monitor keeps turning off randomly and turns back on. sometimes it turns off and on like 6 times a minute or occurs every 3 hours. it turns off the monitor goes black and the green light shuts off. few seconds later it turns back on and the led light becomes green. it can turn back on 5 seconds after it turns off or even half an hour later. when it turns off and doesn't turn back on for few minutes i press the menu, auto, or the power button randomly and it turns back on. the problem is very random and impractical. i know the monitor is causing the problem because i hooked up a different monitor to my pc and it works fine. the power and dvi connections are fastened securely and i cleaned the monitor with canned air spray.
5 Suggested Answers
SOURCE: HP mx705 17 in.CRT Conventional Monitor vertical goes bad
it seems that youre monitor has a dry solder problem, try tapping it if the picture resumes to normal for a while than get it resoldered from a technician. if it soesnot solve problem than look out for a burnt resistance.
Posted on Jun 26, 2007
  • 38 Answers
SOURCE: monitor randomly shuts down
This is either power supply (not usually), backlight drawing to much current, or most likely an invertor board component failure. Built in overcurrent protection on many of these boards will provide a shutdown signal. Weak transistors will crash when they get hot. Hp monitors are notorious for inverter problems. The time between blackouts will decrease until it no longer will light at all. Repair or replace the invertor.
Posted on Jan 15, 2008
SOURCE: Auto Adjustment keeps turning on every few seconds
I have had the same problem and now suspect that cleaning fluid from when I cleaned the screen may have seeped in. After a number of things I did over a period of 2 weeks the problem went away completely.
1. You may be able, if that is your problem, solve it quicker with a hair dryer at a distance (no melt down!)
2. Run HP diagnostics and clean the registry
3. Re- install drivers
Like I said I think 1 is the most likely. I went from every couple of seconds to completely solved.
Another possibility is that an MS update may have caused the problem and then another solved it.
Posted on Jan 11, 2009
Geekman
  • 32281 Answers
SOURCE: i have an hp w1907 monitor i start up puter and
You could have a faulty inverter board. The inverter supplies high voltage to the CCFL lamp/s, these lamps are mini fluro tubes approx 1,5mm dia. and the length of the screen.
Check the inverter output/inverter board and you maybe able to get parts from
www.lcdparts.net
Posted on Dec 13, 2009
HP 17'' L1706 LCD Monitor image shacking
shacking?
well you proved its bad.
a refurb at walfart is $50, about 1 /4th a repair bill.
most the monitors all before magic year 2010 LED year.
all of the now are dead for CCFL back lamps.
1: dim
2: FLASHING JUST LIKE HOME FLORESIENT LAMPS TO.
3: TURNS yellow
4: goes dead, but flash light played on front show data.
5: works not, not next day, repeat,(random)
all do that, ever one, unless your was parked on self for 5 to 10 years.
they all die 20,000 hours (not days , hours)
Feb 28, 2018 | HP Computers & Internet
I have an emachines E181H TFT LCD monitor and a few months ago it would turn off at random and would come back on.After a few days it stopped turning off by itself I have had no problems till recently,...
After a while LCD monitors develop problems that are usually caused by faults in the internal circuitry. This could be an issue with the power capacitors failing. If you feel confident enough, you can remove the back cover and check to see if any capacitors are bulging or leaking. (Give it at least 24 hours unplugged to allow the capacitors to discharge before doing so). I found THAT little bit of knowledge out the hard way
Jan 22, 2011 | Acer AL2017 20" LCD Monitor
Hi I am Nithya form Bangalore, India. I bought an Acer CRT monitor (14" inches) 4 years ago. I am facing a problem with it since the last 2 days. I am unable to view the picture clearly, only part of...
Hi Nithya
Try this Turn off the monitor then unplug all the cables , press and hold down the power button for 15 sec , see whether there is any magnetic device near by the monitor , eg Anything which is made of Iron, or any metal, keep them away from the monitor , if this is not fixing the issue , i Guess the monitor need to be serviced !
Nov 09, 2010 | Acer Computers & Internet
White screen on monitor
o cant suggest anything appart from buying a new one sorry.
please rate my help to you.
thank you
Apr 22, 2009 | Dell E173FP 17" LCD Monitor
Menu keeps poping up & won't turn off
have you found a solution to this problem? i have the very same problem. i have taken apart the back of the monitor and found that if i take the small circuit board that is plugged into the power switch it goes away leading me to beleive that it is this small board but i do not know where to get it at. the number on the board is ar577 vk-583 rev:1. any help would be greatly appreciated. my email address is sachckc@gmail.com
Oct 22, 2008 | Acer AL1914 19" LCD Monitor
Kia Rio 2002 turns over but does not fire
This may be the fuel pump failing, if it is it will strand you some time in the next few months.
Oct 05, 2008 | 2002 Kia Rio
Buzzing and low temps
sound like a compresser relay/overload ,uplug the refigerator remove back cover, remove relay that is on the compressor and check it by shaking it , it should not rattle. if it does replace it..
Aug 10, 2008 | Frigidaire FRS26R4A Side by Side...
Monitor show picture for a few seconds, then turns black
It sounds like the power supply board on your monitor is failing. If it's still under warranty you might be able to get a replacement from the manufacturer - if not, you might be able to have it repaired at a computer or TV repair shop.
May 14, 2008 | E-Machines E17T4 LCD Monitor
Menu keeps popping up
Never a good idea to clean with any spray cleaner. The cleaner does get down in the button bar and cause corrosion and shorting along ribbon cable. Use screen wipes for computer monitors only on TV's and any type of monitors. You can remove the back of the case. And remove the button board and clean with a cue tip and alcohol along ribbon cable.
Nov 04, 2007 | Acer AL1912 19" LCD Monitor
HP w17e Monitor Logo
109 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
