Question about Frigidaire Affinity ATF7000E Front Load Washer
Frigidaire affinity front load washer not filling with water
onthejob5130
  • 640 Answers
SOURCE: Frigidaire Affinity Atf7000e...Does not load up water.
clean your inlet screen...onthejob...take hose off and take screens out of inlet water vavle and clean then replace..onthejob
Posted on Jan 31, 2009
  • 4 Answers
SOURCE: frigidaire affinity front load washer doesn't start
mabye there is something keepin the door open, thats usually why most washers dont start
Posted on May 11, 2009
MakeupWizard
  • 39 Answers
SOURCE: What does error code E59 means on a Frigidaire
Hiya
if you have pressed any of the buttons during a wash cycle then you will be given an error message on the display to change the wash options once started you must 1st pause the wash before making any changes, this i think would be the main reason for such an error to appear however you can download your operaters manual at http://www.frigidaire.com/manuals
if you do not already have it & from there you may be able to have a read & work out why you received this message alternativly from the site you will get a link to a contact us section where you may be abal to ring the customer services & then have the assistant check the code for you..
Hope this helps
Posted on Apr 22, 2010
SOURCE: won't do spin cycle
http://www.servicematters.com/maytag_library/docs/16022808.pdf
http://www.repairclinic.com/Washing-Machine-Repair-Help
http://frigidaireservicetips.com/pdfs/360_TumbleActionWashers.pdf
OK please find above a service and repair manual and a DIY washer self help site, with all this and the troubleshooting procedures in the manuals you should be able to isolate and repair.
Posted on May 21, 2010
Jahn27
  • 1554 Answers
SOURCE: I have a Affinity frigidaire front load washer and
Disconnect power then open the door and remove the spring-hoop assembly that secures the door gasket. Peel off the part of the door gasket near the door lock and switch assembly. Remove the screws securing the door lock and switch assembly to the front panel then pull the door lock and switch assembly out. Transfer the wires to the new door lock and switch assembly then install into place. Put the door gasket back and secure it with the spring-hoop assembly. Click on the link below for the detailed procedure.
Replacing the Door Lock and Switch Assembly on Frigidaire Affinity and Gallery Front-Load Washing Machine
Posted on Nov 13, 2010
Why does my frigidaire affinity smell
clean it by using 5 cups bleach fill soap cup put rest in tub wash in hot water long cycle run another or 2 after to make sure bleach is gone
Jun 07, 2014 | Frigidaire Affinity ATF7000E Front Load...
FRIGIDARIE AFFINITY WILL NOT FILL UP WITH WATER ALLTHE WAY
Hello Carl Kjonaas - Is the house valve(s) fully turn on? Typically when water is not filling completely, the washer could possibly have a faulty switch that does not allow the valve inside to turn or a kinked fill hose. Other possibilities of more potential serious issues are water valve faults, faulty control board, pressure switch or wiring failure. If I was in your position, I will personally consult a professional to move forward accurately and assist with the repairs.
Feb 19, 2013 | Frigidaire Affinity ATF6000F Front Load...
My frigidaire affinity front load washer ATF6000FS1 wont fill with water
Hello hitman43 - Are the house valves turn on fully? Most common cause is a faulty switch that doesn't allow the value inside turn or a kinked fill hose. Other possibilities can be water valve faults, faulty control board, pressure switch or wiring failure. Contact a professional to move forward accurately.
Jan 01, 2013 | Frigidaire Affinity ATF6000F Front Load...
Problem with water in tub of front load washer
Two possibilities here - bad valve, not closing completely when off or you have a bad control that is sending residual voltage to the valve when it is off. Contact a service technician.
Aug 11, 2012 | Frigidaire Affinity ATF7000E Front Load...
My washer is filling with water when i'm not using the machine. I read somewhere abot some wort of inlet vavle needing to be replaced?
Unplug the machine. If it still fills with water then mechanically the water valve has failed. If it don't fill while being unplugged then something in the control is doing it, might be the main control is bad. Who knows?
Affinity Service Manual
Jun 25, 2011 | Frigidaire Affinity ATF7000E Front Load...
Fabric softener dispenser fills with water after every load
your overfilling it at start up ,,and its sphioning down only fill to metered line...and theres always alittle water in dispencer to keep it from sticking ,,but just a little..onthejob
Jan 31, 2009 | Frigidaire Affinity ATF7000E Front Load...
My Frigidaire affinity washer doesn't start: the "door locked" button doesn't come on though the door is closed properly
If the washer fills with water, but will not start the wash cycle or spin, it is 1 of to things. the most common for frigidaire front load affinitys is the door lock assembly. I have had to replace numerous of these. if the door lock indicator is not on when it tries to wash, you need to replace the door lock assembly. if the door lock indicator is on, but wont wash, it is likly that you have a bad motor control board.
Dec 01, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Affinity front load washer
my front load washer won't spin water out
Jan 21, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire Affinity ATF7000E Front Load Washer Logo
16 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
