Question about Electrolux Vacuums
Ultraactive cleaner low suction problem - Electrolux Vacuums
  • 125 Answers
Check hose for clogs
Posted on Jan 06, 2014
Mt dyson has too much suction
Hi there, it's Jack at Dyson.
I'm sorry to hear you feel your DC40 has too much suction. This sounds unusual, and in order to help you resolve things we would need to take some further details about your machine, and the particular flooring type you're having difficulty with.
When you have your machine to hand, please call us directly so we can talk you through some simple troubleshooting checks to make sure everything is correct with your DC40. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
We'll look forward to speaking with you.
Sep 27, 2014 | Dyson DC40 Animal Upright Vacuum -...
Electrolux Ultraactive losing suction and turbo head brush won't spin. Canister is empty, no blockage in hose or nozzle of turbo head, filters cleaned, but Hepa not replaced recently. Could that cause it...
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try to fix the suction of your Electrolux vacuum. The first thing you should check is the height of your brush-roll. Your height setting may be too high for the type of floor you are vacuuming. Raise or lower your brush-roll depending on if you are vacuuming on carpet, tile, or wood surfaces.The second thing you should check is the vacuum bag. If it is full your vacuum can lose suction. This is simply remedied by replacing it with a new and clean bag. The third reason for a loss of suction is your hose is clogged. Check the hose for debris or foreign objects that may be obstructing the flow of air in the vacuum. The last potential reason for your vacuum losing suction could be the brush-roll itself. If it is clogged with dirt and hair it may not be spinning and not picking anything up. Check to see the condition of your brush-roll. If it is clogged remove the debris.
You can purchase direct your Electrolux replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/electrolux.html
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Aug 05, 2014 | Vacuums
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Remote control Electrolux flashes 3
Can you give more information...what model and what is happen.
Aug 23, 2013 | Electrolux UltraActive EL4300A Bagless...
Kenmore progressive 360 vacuum cleaner has low suction
Check the tube that leads down to the brush head for clogging as well as any motor or HEPA filters. If that still shows nothing, take the cover off the brush head (like you're changing the belt) and look for obstructions in there. Usually, if you have low suction on the accessory hose, the problem is with a motor filter, HEPA filter, or a clog where the hose goes into the unit. If you have good suction on the accessory hose but none on the floor, it's usually in the brush head (clog or broken belt) Good luck
Feb 28, 2010 | Kenmore 35912 / 35913 Progressive Upright...
Machine turns on, has little suction, then stops working.
It would be helpful to know what model of vacuum cleaner you're talking about. Basically though, your machine has a blockage somewhere (hence very low suction), and is cutting out after just a few minutes because of overheating.  You need to explore the suction hose (or whatever your machine has), find the blockage and remove it. Blockages almost always happen where the pipe-work takes a sharp bend.  In the worst-case scenario (although in almost all modern machines this is not possible) the blockage may be in the vacuum fan enclosure itself, and then you'll probably need a professional to take care of it.
Feb 03, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Low suction on Eureka spinduster vacuum cleaner
The belt has stretch enough so as to not drive the brush roll under load. Try a new belt.
May 10, 2008 | Eureka 2971AV EZ Kleen Bagless Upright...
Miele vacuum cleaner not working properly
Is the suction low or ok at the vacuum without the hose attached? If it is ok, then there is a clog in the hose. If it isn't, then check filters, is the speed variable, is the contol set too low. Could be a bad motor, running too slow.
Mar 05, 2008 | Vacuums
Low suction
Is the water seal in place or missing? Another cause would be a bad motor, running at a slower speed will mean low suction. If it is a motor, then you would have to replace it. Is the suction low at machine without the hose, if it is ok then may be a clog in the hose.
Feb 09, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Vacuums Logo
16 people viewed this question
Top Electrolux Vacuums Experts
Mack Baxter
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
