Question about GMC stud. bolt. engine coolant thermostat housing. generator mounting
Coolant Type for Nissan Liberty 2001
Is there a special type of coolant for my car. I filled the reserve tank with another type of green coolant.
    New Friend:
    Problem Solver:
  • 9 Answers
Some newer cars require a special anti freeze that protect the rad and engine because of the material = metal that they are made from like aluminum and last a lot longer than the regular green anti freeze for protection
Posted on Jan 01, 2014
Refilling radiator
Before you add coolant always make sure that the engine is cool never add coolant to a hot engine.Next remove the radiator cap and fill it to the top with a 50/50 mixture of coolant and water.After you have filled the radiator with the coolant water mixture put the radiator cap back on and then fill the reserve tank to the cold level mark on the side of the bottle
Apr 27, 2014 | 2005 Chrysler Town & Country
What type of coolant should I add to a 1999 Buick Century...dashboard lite says coolant low
gm put DEX- COOL in the car when it was built, but who know what has been done to it since then so you should probably go get some all makes all models anti-freeze you can get it a any auto parts store.......HAVE FUN
Jan 16, 2011 | 1999 Buick Century
How do i drian the radiator to put in new coolant
there should be a petcock on bottom of radiator. just turn it, to open up drain. if it does not have a radiator cap, fill from coolant tank while running. release air from coolant line, if needed. just put coolant in tank to proper level, also turn heater on high. to get through whole system. run for a while then check coolant level.
Jul 18, 2010 | 2001 Nissan Altima
Do I add anti freeze to the radiator or the lid tat says coolant
IT DEPENDS SOME OLDERS CARS USE GREEN ANTIFREEZE.MOST NEWER VECHICLE USE DEXCOOL ORANGE ANTIFREEZE.YOU NEED TO LOOK UP TO SEE WHAT TYPE ANTIFREEZE VECHICLE USE BEFORE PUTTING ANY IN SYSTEM.IF YOUR CAP SAY COOLANT THEN THATS WHERE YOUR ANTIFREEZE GOES.
Jun 18, 2010 | Cars & Trucks
2002 7 Series: what type of coolant specification do i use for 20...
Coolant type is for all of the world BMW cars used freon-free
R134a for fill
May 18, 2010 | 2002 BMW 7 Series
Radiator Reserve Tank
Your engine is pressurizing the coolant system through a leak in the head-gasket, it could be airgaps but I'm going to be your head gasket needs replacement.
Mar 10, 2010 | Honda CR-V Cars & Trucks
I have a 2001 chevy Malibu. Have problems with
Due to the complexity of the newer cars on the raod today!! what you are experiencing is Normal!!! since the coolant systems on the newer cars run at such a higher pressure and a high Rpm the reserve tank which has it's on drain hose for excessive overflow from the radiator allows the extra high pressure release from the radiator to back flow to the reserve tank and then out the reserve tank overflow hose on to the raod
Jan 17, 2010 | 2000 Chevrolet Malibu
Where is the thermostat sensor
Both the 4.0L and 4.7L engines use 195� thermostats for all model years from 1999-2004. When replacing a thermostat it is very important to install one with the same temperature rating (the only exception might be with certain performance modifications or chips that recommend or require a different temperature thermostat).
4.0L engine - Draining the cooling system WARNING: DO NOT REMOVE THE CYLINDER BLOCK DRAIN PLUGS OR LOOSEN THE RADIATOR DRAINCOCK WITH SYSTEM HOT AND UNDER PRESSURE. SERIOUS BURNS FROM COOLANT CAN OCCUR.
1. DO NOT remove radiator cap first. With engine cold, locate radiator draincock on the right lower side of radiator facing to rear of vehicle.
2. Attach one end of a hose to the draincock. Put the other end into a clean container. Open draincock and drain coolant from radiator. This will empty the coolant reserve/overflow tank. The coolant does not have to be removed from the tank unless the system is being refilled with a fresh mixture. When tank is empty, remove radiator cap and continue draining cooling system. To drain the engine block of coolant, remove the cylinder block drain plug, located on the side of cylinder block below the exhaust manifold.
4.0L engine - refilling the cooling system Coolant recommendations and cautions: The recommended mixture is 50/50 ethylene-glycol and low mineral content water. Never use pure antifreeze. Only Mopar Antifreeze Coolant, 5 Year/100,000 Mile Formula (glycol base coolant with corrosion inhibitors called HOAT) is recommended. This coolant offers the best engine cooling without corrosion when mixed with 50% distilled water. Antifreeze mixture must always be at least 44%, all climates year round. Maximum protection (-90d) is provided with a 68% mixture protection. If the percentage is lower than 44 percent, engine parts may be eroded by cavitation, and cooling system components may be severely damaged by corrosion. CAUTION: Mopar Antifreeze/Coolant, 5 Year/100,000 Mile Formula (MS-9769) may not be mixed with any other type of antifreeze. Mixing of coolants other than specified (non-HOAT or other HOAT), may result in engine damage that may not be covered under the new vehicle warranty, and decreased corrosion protection.
CAUTION: Do not use coolant additives that are claimed to improve engine cooling. 4.0L coolant capacity: 1999-2000: 13.0 qts. (including 2.3 qts. for resevoir) 2001-2004: 15.0 qts. (including 1 qt. for resevoir)
1. Tighten the radiator draincock and the cylinder block drain plug(s) (if removed).
2. Fill system using a 50/50 mixture of ethyleneglycol antifreeze and low mineral content water. Fill radiator to top and install radiator cap. Add sufficient coolant to the reserve/overflow tank to raise level to FULL mark.
3. With heater control unit in the HEAT position, operate engine with radiator cap in place.
4. After engine has reached normal operating temperature, shut engine off and allow it to cool. When engine is cooling down, coolant will be drawn into the radiator from the reserve/overflow tank.
5. Add coolant to reserve/overflow tank as necessary. Only add coolant to the reserve/overflow tank when the engine is cold. Coolant level in a warm engine will be higher due to thermal expansion. To purge the cooling system of all air, this heat up/cool down cycle (adding coolant to cold engine) must be performed three times. Add necessary coolant to raise tank level to the FULL mark after each cool down period.
For more details, you can refer to the Jeep WJ Service Manual Section-07-Cooling-System-Ewj7
Hope helped.
Nov 02, 2009 | 1999 Jeep Grand Cherokee
Type of coolant required
They have special coolant now that is accepted by either color (green or orange) I believe Nissan uses Orange, just make sure you dont mix the two as it will gel up on you
Aug 26, 2009 | 1994 Nissan Sentra 4-Door
GMC stud. bolt. engine coolant thermostat housing. generator mounting Logo
50 people viewed this question
Top GMC Electrical Supplies Experts
Andrew Taylor
Andrew Taylor
 Mikey
Mikey
Hugh Mckernan
Hugh Mckernan
Level 1 Expert
Are you a GMC Electrical Supply Expert? Answer questions, earn points and help others
