Question about 5.5 HP GX160 Engine
Setting valve clearance - 5.5 HP GX160 Engine
    Sergeant:
  • Honda Expert
  • 402 Answers
Intake .006" exhaust .008"
Posted on Dec 30, 2014
  • 6 Answers
Go to youtube and type or cut and paste this into the search " how to adjust valves on honda gx, or chinese replicas ", Hope this helps
Posted on Nov 26, 2014
I have a 24hp vtwin B&S engine. I need to know whether to make the valve adjustment with the engine hot or cold. Would please answer with this information? Thank you.
you can set the clearances cold but the measurements will be .002" bigger to allow for valve stem length increase when hot
example --a setting of .012" hot will be .014" cold
Hot is best as the stems do not always expand uniformly so valves in one engine may expand more or less in another engine
always check the clearance when hot
B&S engines are noted for valve stem stretch for a period from new so a regular monitoring of the hot clearance is a good idea ( check say every 20 hours operation for the first few periods until the clearance remains steady)
Oct 02, 2016 | Craftsman 42 in. Precision Cut Plus 24hp...
What is the valve clearance for intake valve and exhaust valve for mitsubishi engine 4D32?
Please follow link to complete instuction's on the Correct way to set valve clearance on the 4D32 engine type.
6 INTAKE AND EXHAUST VALVE CLEARANCE INSPECT AND ADJUST
May 15, 2016 | Mitsubishi Cars & Trucks
Set valve clearance on 21hp briggs and statton
Valve clearances are set by either tappet screws in the lifters or on a lot of small engines, clearances must be set by either cutting out valve seats with a special cutter tool (to DECREASE clearances) or grinding the end of the valve (to INCREASE clearances) and generally are from .008-.010 on intake valves and .010-.012 on exhaust valves. Check engine specs to insure proper clearances.
Sep 24, 2014 | Garden
Valve setting
Personally, the valve clearance (if nobody's been messing with it) would be last on my list of suspected causes.. Knowing diesel engines like I do, my very first suspect would be a dirty fuel filter.
Dec 03, 2013 | Cars & Trucks
How adjust valve clearance
guys mainly the valve gets heated and gets expand so the valve clearance is adjusted . according to my studied knowledge the inlet valve clearance should be perfectly 0.5 mm and the exhaust port must be 0.6 to 0.7 mm. this the perfect tuning for the 2 wheelers . [ remember guys before you set valve clearance make sure that engine is fully cooled condition.....
thankyou........................................................
ABHI ROCKRANGER
Aug 04, 2012 | Hero Honda Splendor Motorcycles
Torque settingsfor head on lister petter mini6 engine
I have just rebuilt one for our Westerly 21. This is from my Petter 'A' range workshop manual:-
The water cooled engines (AC1W etc.) are:cylinder head nuts: 30NM (22 lbft) except 32.5NM (24 lbft) for the one that also holds the rocker.
Valve clearances are 0.1mm (0.004") COLDReset valve clearance after one hours running since torquing the head.
Retorque head and set valve clearance after initial 20 hours running
I believe Mini-6 refers to the water cooled engines but just in case, the air cooled engines are 27N (20 lbft)
Mar 27, 2012 | Cars & Trucks
Valve clearence settings mazda protege 2003
This is for a non turbo2_24_2012_5_45_49_am.gifNew adjustment shim =Removed shim thickness+ measured valve clearance- STANDARD VALVE CLEARANCE (0.26 mm or 0.010 inch)
Feb 24, 2012 | Mazda Protege Cars & Trucks
I have problem with my engine 4K toyota. It heard an engine noise during idling, for my little knowledge in engine repair, can you give me any procedure mannuals in adjusting engine valves for my...
Valve Clearance Valve clearance is there to allow the valves to cool in between combustion events (spark), and to make sure the valve closes properly and contains the combustion explosion. You need to cool the valves a little bit, the exhaust valve moreso than the inlet, as it's what sees the most heat as spent burnt gases go past it into the exhaust port. Run too little clearance and you'll cause the valve to "weld" a little bit to its' seat every time it closes, and then take seat metal off again when it opens. Do this enough times and you burn out the valve seat and need the head reconditioned. However, by running less clearance, the valve stays open for that little but longer, and you get more air in and out of the motor, and make more power. Run too much clearance and your motor just sounds like a diesel and loses power and tappet rattle annoys you while you're driving, so it's better to err on the side of caution.
The stock valve clearance (0.008" inlet / 0.012" exhaust, warm) is pretty good for any of the cams I've listed above, they're well-sized street cams, not really wild top heavy race cams that require super high compression to work, so don't be afraid to close the valves up a bit from the suggestions of the cam grinder, which will usually say between 0.010" and 0.014". There are a few ways to set your valve clearances:
Yellow Book Method This is from the factory 3K/4K/5K engine manual, aka The Yellow Books. It's the quick and lazy method.
Set engine to #1 TDC. Crank pulley timing mark should be on 0, distributor rotor should be pointing towards spark plug 1 or 2. Set tappets (counting from the front) 1, 2, 3 and 5. Rotate engine 360 degrees, crank pulley to 0 again, distributor rotor turned 180 degrees. Set tappets 4, 6, 7 and 8.
Nine Method I've never really gotten into doing this, takes too much time and maths for my liking :P Rotate the engine through its' range of movement, as one valve is "on the rock" of its' max lift, subtract the valve number from 9 and that's the tappet you should be setting. For example, if #8 valve is open, set clearance on valve #1. If valve #7 is open, set clearance on #2. And so on.
Stewart uses this method, and rotates the camshaft through its entire base circle and sets the clearance at the highest point. Which is a pretty good idea, as it compensates for the possibility that the base circle has been ground unevenly, and allows you to run the proper valve clearance that you want to run, instead of something that may be a few thou larger in reality.
Feb 10, 2011 | Toyota Corolla Cars & Trucks
I need to know the valve adjustment procedure and
Valve clearance ideal setting is 0.10mm however as ideal replacement size shims are not always available use tolerance 0.05 to 0.2mm inlet and exhaust Procedure remove tappet cover rotate motor to tdc compression (inlet valve lobe pointing to rear wheel and exaust lobe to front wheel) measure clearance if no clearance depress cam bucket hold down by wedging a screwdriver or suitable tool (allen key) between cam bucket and cam remove shim measure with micrometer an relace with a shim 0.15 thinner depress valve remove wedge and measure clearance (if any) repeat procedure 4 each cylinder if clearance to large replace shim with a thicker one till clearance is in spec
Jul 20, 2010 | 1981 Suzuki GS 750 L
Valve clearances for a ford econovan 1.8lt, 1990
what are the valve clearance specs for a 1990 ford econovan maxi
Mar 14, 2010 | 1989 Ford Econoline
5.5 HP GX160 Engine Logo
418 people viewed this question
Top Honda Vehicle Parts & Accessories Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Spud Howell
Are you a Honda Vehicle Part and Accessory Expert? Answer questions, earn points and help others
