Question about General Electric GE GSH22JSX (22.0 cu. ft.) Side by Side Refrigerator
Fan runs but compressor does not try to start and stopped cooling today
LG window air unit. Been having trouble with control panel for months, but unit cooled. Now it will light up and fan will blow, but compressor does not kick in. Unit about 4 years old.
Possibly a faulty run capacitor in the control box. This is fairly common to LG. the fan motor and compressor use them to start and run more efficiently and when they fail the fan or compressor either don't start at all or run poorly. You can usually tell if you can hear the compressor 'hum' briefly then stop every 10 - 30 secs. this is the compressor trying to start but unable due to the faulty part. LG often have a dual capacitor (two capacitors in one case) so the fan may stop working also or at least run slower. They are common parts available at most electrical wholesalers although the genuine LG parts are normally dirt cheap. Need a model to check the circuit diagram to be more certain.
Aug 24, 2017 | LG Heating & Cooling
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
Model GSI-26 suddenly stopped cooling
It sounds like your compressor is having a hard time starting. Take your model number to an appliance parts store and ask for a compressor start relay. It plugs directly into your compressor and is easily replaced. Remember to unplug the refer first.
Dec 17, 2012 | Frigidaire Refrigerators
My unit was cooling yesterday and stopped today i put my gage it was 0psig i found a leak on the condenser fix leak and notice the condenser was so hot and not running not even humming.What next iam an...
Air conditioner compressor will not start. When power is applied to the air conditioning outdoor unit the fan starts, but you hear a sound like the compressor is trying to start, "UGGG"..., for about 5 to 10 seconds and then all you hear is the outdoor condenser fan run. The compressor is locked and will not start. What is happening is the compressor is trying to start, but because the compressor motor is locked it tries to start for a few seconds and then because of the high amperage being drawn goes off on internal overload. The internal overload protects the compressor windings from overheating and burning up. I see this many times during the start of the air conditioning season.
Jun 16, 2011 | Heating & Cooling
Plug in frig starts cooling will make a thin layer of ice in trays and frig fresh food will start to cool down then cooling stops and fan is still running. Unplug wait 30 min plug back in and starts...
That problem may take a little work finding but that is no problem if you can pull away from the wall and unplug. Then remove the lower cover that covers the compressor area so you can feel the top of the compressor. Feeling the top of the compressor tells me several things like if it has been running all this time or if very hot it will tell me that the compressor has been short cycling. Compressors short cycle for a few reasons and one is the start components photo #8 and #4 in this photo here=> ASD2628HES_COMPRESSOR_Components Another reason may be the evaporator fan or the condenser fan #20 in the photo link above are not staying on or there is an airflow restriction. When the compressor runs there should be a good steady flow of warm air from below the refrigerator. That warm air is the warm conditions being removed from inside your refrigerator. The most likely reason for this is the start relay/overload or number 4 in the photo has become defective. That is this=> Relay Overload with Start Capacitor
With that part out and able to get the=> 65889-4 15uf run_capacitor
out I would carry the run capacitor to a local refrigeration dealer and ask if they would test your run capacitor for free. I will be here if you should have questions beyound what I have mentioned here today, Thanks, Sea Breeze
Jun 13, 2011 | Amana 26 cu. ft. Side-By-Side...
9-10 year old Frigidaire Gallery FRS26ZSH refrigerator stopped cooling as only the fan was running and not the compressor. Cleaned the lower coil and fan of a small amount of dust. The unit worked for 1-2...
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
ED5SHEXKQ01 is 7 years old. Stopped cooling. Fan is running.
It could be your compressor trying to kick in. Or it could be your defrost system trying to start or stop. The least expensive thing to start is to replace the start kit on the compressor. Call or email us and we'll be sure to get the right part to you asap. You need to turn it off NOW before you burn the other parts up and don't turn it back on until you install new parts.
Sep 09, 2009 | Refrigerators
Amana Cooling Condensing Unit fan won't kick on
be aware that not repairing this asap that you are causing yourself more problems First I would change out the fan capacitor and see if this could be the problem. Secondly if the capacitor isn,t the problem change out the motor . By continuing to allow the system to cycle like this the compressor will take a dive on you costing more . Good Luck
Dave
Aug 04, 2009 | Amana PTH123B25AJ Heat Pump Air...
Freezer not freezing and fridge not cooling
Check the back wall of the freezer for ice buildup.
If yes, a defrost parts problem.
Check the freezer fan. Is it running?
If no, replace the freezer fan.
Check the condenser fan at the compressor. Is it running?
If no, is compressor hot?
If compressor is hot replace condenser fan motor.
If compressor is not hot.
Replace the compressor start relay.
Feb 27, 2009 | Kenmore 53502 / 53504 Side by Side...
Compressor starts and doesn't stop
Relay for the compressor may be stuck ( Contacts welded) both the fan and the compressor should operate at the same time. Have the relay(s) checked and possibly replaced.
Apr 29, 2008 | Dometic Rooftop RV Air Conditioner
General Electric GE GSH22JSX (22.0 cu. ft.) Side by Side Refrigerator Logo
15 people viewed this question
Top General Electric Refrigerators Experts
Van Allen II
Van Allen II
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
