Powerpack manual - Computers & Internet
Powerpack 300
It's dead. Replace it.
Jan 06, 2014 | Computers & Internet
Tip
Battery replacement in Xantrex XPower Powerpack 600 > 600 watts 12 VDC >...
Battery replacement will require opening the case of the Powerpack 600. The four rubber feet must be removed first (Phillips head #2 screwdriver). Next the two orange handle halves come off starting on the radio side. The screw heads may be either 9/32" or 1/4" heads depending on age of your Powerpack 600. Use either a 9/32" or 1/4" nutdriver to remove the screws. The orange handle halves swing open like a clamshell at the carrying handle and lift off. The orange handle half on the flashlight side has two hidden latches in the handle area that must be released with a flat head screwdriver first before that half can be fully removed. Now that the orange handles are out of the way, slip off the bumpy rubber handgrip from the gray handle. On the radio side of the gray plastic case are 9 Phillips head #2 screws that are in recessed holes to remove. Once those screws are removed, the gray plastic case seperates in half and you can unplug the two pin connector going to the radio and set the radio half aside. You are now inside the Powerpack 600 and can replace the battery if needed.<br><br>Replacement 12 volt, 28ah battery numbers:<br>Sealake # FM12280<br>Zipp Battery # 12V-28AH-T3<br>CSB # GP12260<br>Powersonic PDC-12260<br>Tempest # TD28-12<br>Panasonic LC-C1228PG<br>Universal Power Group # UB12260<br>BB Battery # BP28-12
on Sep 01, 2013 | Xantrex XPower Powerpack 600 > 600 Watts...
Hi there I lost my adapter for my FGA # 852 0302 Power pack 300 and I was wondering which adapter I needed and where I can buy one. Thanks Neil
Follow this link for the manual: http://www.xantrex.com/documents/Discontinued-Products/445-0092-98-01_rev_2_(xP300_web_english).pdf
Unfortunately, the manual doesn't list the specifications for the AC adapter you need. You can however, charge the Powerpack via the cigarette lighter in your car. (see p. 16 of the manual). Also, look at p. 23 of the manual.
Follow this link to read what another FixYa expert suggests: http://www.fixya.com/support/t7844005-lost_power_supply
Good luck, please post back to this solution if you have any difficulties, and thanks for using FixYa.
Apr 29, 2011 | Xantrex Technology XPower Powerpack 200...
Xantrex PowerPack 300 will not hold a charge
Machine no longer takes a charge. Light remains yellow, if you plug anything in there's not enough power. Any suggestions? Purchased XPower Powerpack 300 Plus from QVC appx. 6 - 8 years ago.
Mar 28, 2009 | Xantrex Technology Xantrex Xpower...
Compaq Presario R3000
If you are getting no lights at all on the laptop, you need to check the "powerline" - everything between the outlet and the back of the laptop.
Start by removing the battery. Then, check to see if the power pack has an ON light, if it does, make sure it is on, if it has a light and it is off, try plugging the power pack into a different outlet you know works. If it is still off, you have a bad powerpack and needs replacing. If the powerpack does not have a light, you need to find a geek friend with a multimeter (or get one at WalMart for $4), and check the powerpack's output in volts matches whatever it says on the side of the pack. If the voltages do not match up (generally) you have a bad powerpack. If you are getting normal voltage from the powerpack but the laptop is not getting any power, you have a different set of problems. Is the laptop beeping when you try to turn it on? Do you get any activity at all?
Good luck...
Nov 17, 2007 | Compaq Presario R3000 Notebook
Computers & Internet Logo
161 people viewed this question
David Payne
David Payne
