Question about Refrigerators
Foul smell in nose - Refrigerators
How do I install a whirlpool top gas stove?
You need a gas connection .then flex tube channel locks or a pipe wrench and some Teflon tape. Connection should have shut off valve.should be shut off. Put Teflon tape on threads then connect the connectors. Open valve.check your work twice listen and use your nose for a foul smell.
Jul 15, 2014 | Stoves 600SiDOm Gas Kitchen Range
Nasal odor/bad smell in nostril, cause and how to get rid of it
a few things you can try,
1 blow your nose hard making sure there is nothign trapped up there.
vic vapour will ease all smells depending on how close it is to your nose.
you might have an infection in nostrils and therefore you would need to go to your local GP and have it looked at
Mar 10, 2014 | Computers & Internet
Foul smell in nose
What does this pertain to?
Apr 26, 2013 | Cars & Trucks
Does air cnditioner give any foul smell when running
Hello typically a air conditioner does not give off a foul smell, sometimes the condensate that drains out can have a moldy kind of smell or if mold is growing inside the unit it can give off a foul smell called " dirty sock syndrome". The last possibilty is that if the condensate line is drained to a floor drain and on the negative pressure side of the evaporator coil it could be pulling the sewer gas up thru the line, in this case the condensate line must be trapped to prevent this. Also, I would recommend pouring some bleach into the condensate line every few monthes.
Jul 16, 2012 | Amana Heating & Cooling
Foul burning odor
you could possible be right on if your frig has an electronic disp control put your nose their and sniff if seem close to what you earlier smelled you solved your problem pcb control '
Aug 20, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Need to have a foul smell removed in kitchen
bleach spray in a squirt bottle
1part bleach
10 parts water
pull the pan out from under the fridge, clean it
lift stove top, clean underneath
if dishwasher present, spray it and cycle
if garbage disposal present, spray and cycle
if A/C ducts in floor, open and clean
also, replace air filter, turn on blower, and spray solution into return
use your nose and try to find the source
Jun 27, 2009 | KitchenAid Superba KSRG25FK Side by Side...
Electrical smell
The most common cause of electrical smell on these units is from the compressor start relay. Get behind the fridge and remove the cardboard cover at the bottom. The relay plugs onto the compressor. See if the smell is stronger there. Also listen for it to try and start the compressor. If it just humms and clicks off, the relay is probably shorted out and needs replacing. Do not let anyone put a "fit all" relay on it, some of them will work ok for a while but cause a compressor failure a few months down the road.
If the relay is ok, check the icemaker area. A burned icemaker module will sometimes give off a foul odor.
Post back if you have any questions.
Thanks/Mike
Nov 06, 2007 | Whirlpool ED0GTQXMQ Side by Side...
Refrigerators Logo
247 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
