Question about Pioneer DVL-V888 DVD Player
PIONEER DVL-V888 POWER SUPLY FAULT - Pioneer DVL-V888 DVD Player
  • oslecab May 20, 2009
    PIONEER DVL-V888 FUSE KEEP BLOWING UP.POWER SUPPLY FAULT.HOW DO I FIX THIS.
    Sergeant:
  • 296 Answers
Hi
Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is.
thankyou
Posted on May 20, 2009
  • Anjana Batabyal
    Anjana Batabyal May 20, 2009
    fuse is blowing is cause you have a short somewhere. It could be anywhere in the wiring system.
    seems u can't figure out the problem? The benefits of electrical fuses are that they can help prevent damage to appliances, but their main purpose is to keep electrical wiring from getting hot and catching on fire. Fuses are rated to open an electrical circuit before any harm can be done. If your electrical fuse keeps blowing, do not despair. You can track down and find out why your electrical fuse is blowing if you follow some basic guidelines. Electrical fuses may blow because of poor electrical connections. Check your plugs and outlets. Wiring may become loose over the years and need to be re-attached securely. If you have an appliance that's really warm or the electrical outlet is hot to the touch, turn off your electricity and check the outlet. The electrical outlet may be corroded, especially if in a moist location such as a bathroom or laundry, or it may just need to be replaced. Faulty appliances may cause an outlet to feel hot. If you sense danger of a fire, discard and replace the appliance. Even if it is possible to replace a fuse with a higher rated fuse, do not do it. You will invite a fire risk. Wiring that is arcing may also be causing a fuse to blow. Your wiring insulation may be worn or torn and contacting a ground. This can also cause a build up of heat and risk of fire. Last, but not least, make sure there are not too many high amp appliances running on a single circuit. If you run an air conditioner, freezer and clothes dryer all on the same circuit, you're just asking to blow a fuse. If you're still unsure of the electrical problem, contact an electrical contractor to help you figure out why the fuse keeps blowing.
    Top Expert:
  • Pioneer Master
  • 78,267 Answers
In order to repair this you must replace the power supply circuit board inside the player, u will find that this will cost more than just replacing the entire player.
    Sniper:
  • 117 Answers
Hello There
Most Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is, if it blows again, you will have a power supply fault so a new power supply circuit board is need. If it just stopped working all of the sudden then it will be the fuse. ( Please ensure the unit is not plugged in when opening the unit)
Hope this helps. Please don't forget to rate me.
Many Thanks
2 Suggested Answers
  • 3 Answers
SOURCE: power supply fault.fuse keep burning out.
replace d105 it shorted
Posted on Nov 17, 2009
I insert disc, but after a little while, disc ejects without even playing. Help!
happen to all disc?
if so, check the 'home' sensor for the tray. need to open up and take a look.
Jun 14, 2014 | Pioneer DVL-V888 DVD Player
I'm looking for the owner's manual.
go please to www.fitness.manualsonline.com or www.retrevo.com or www.manualsfactory.com
God bless you
Jul 21, 2012 | Pioneer DVL-V888 DVD Player
My pioneer dvl-v888 no power at all.
Likely that it's just a fuse, take the cover off and replace the mains fuse located close to where the power lead is, if it blows again, you will have a power supply fault. Phil
May 19, 2009 | Pioneer DVL-V888 DVD Player
No power at all.
replaced d105 it shorted
Pioneer DVL v888 disk tray will not open. There is a disk in it.
There isn't a way to open it by hand without removing the cover.
As for fixing the tray, there might be a few reasons why its not working. When you press one of the eject buttons, do you hear the usual whirring of motors? If you do and the tray still does not open, then the problem may be a broken rubber belt near the front.
If you don't hear the whirring of motors, then try playing the disk. If the disk does not play either, then the disk loading mechanism is out of sync and may require manually resetting it. This is accomplished by carefully pulling the spring loaded carriage upwards or downwards until it responds to the play button. Be very careful not to touch any of the exposed electrical components and capacitors, electrical shock may occur.
Apr 05, 2009 | Pioneer DVL-V888 DVD Player
DVL-V888 has MECHA CPU message
DVD players are a dime a dozen, go get a new one....
Next time try to get a name brand such as a sony etc...
Aug 29, 2008 | Pioneer DVL-V888 DVD Player
DVL-V888
You need to remove the cover and expose the area where the motor sits close to the front, you will find a broken belt, replace that, if you can't get to the screw to remove the assembly, use your fingers or screwdriver to turn the cog so that the drawer is manually opened. make sure power cable is unplugged first.
Jul 26, 2008 | Pioneer DVL-V888 DVD Player
DVL-V888 disk tray
you will have to take apart and see if you can push the disk into position other wise have to take apart tray system and remove disk.
Dec 03, 2007 | Pioneer DVL-V888 DVD Player
Disk Tray won't open
is there a tiny pinhole to push in a paper clip to eject the tray?
Jun 03, 2007 | Pioneer DVL-V888 DVD Player
Pioneer DVL-V888 DVD Player Logo
134 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
