Question about Cell Phones
Forgot unlock passcode
How do you recover the passcode for unlocking an iphone 5c?
  • 20 Answers
SOURCE: I forgot my passcode to unlock my iphone
It depends on the severity and the settings you have given the iPhone and whether you have the computer that you synced your iPhone with... Here's the full explanation. I would recommend reading the second paragraph first, but the solution if you really forgot your password is in the first paragraph.
==If you have the computer you synced your iPhone with==
If you cannot remember the passcode, you will need to restore your device on the computer that was used to originally sync the iPhone or iPod touch so that you can reset your passcode and resync the data from the device (or restore from a backup). If you restore on a different computer that was never synced to the iPhone or iPod touch, you will be able to unlock the device for use and remove the passcode but your data will not be present. Refer to "Updating and restoring iPhone and iPod touch software."
"If you enter the wrong passcode too many times, you'll see a message that says "iPhone is disabled" and to try again later. If you repeatedly enter the wrong passcode, iPhone or iPod touch will be disabled for longer intervals, before you can try again. After too many unsuccessful attempts, you won't be able to try again until you connect to the computer you normally sync with. Note that starting with iPhone 2.1 software, there is a setting to cause the device to erase itself after 10 consecutive incorrect password attempts. This setting is off by default. It  can be turned on by tapping Settings > General > Passcode Lock after you enter a correct passcode."
The full article can be found here: http://support.apple.com/kb/HT1212
==If you don't have the computer you synced your iPhone with==
If you don't have the original computer the iPhone synced with, the only solution is to force your iPod Touch into recovery mode and then restore it. You will lost all the data on the iPod Touch, but after this method is done, everything will work. You can find the steps to solving this problem here:
http://support.apple.com/kb/HT1808?viewlocale=en_US
Posted on Feb 13, 2009
SOURCE: I set a passcode on my iphone and now i forgot it
if you still have your instructions it has an 1800 number on it and they will fix it or go to an electronic store
Posted on Sep 19, 2009
MoeWizz
  • 42 Answers
SOURCE: how can unlock my iphone but i forgot my passcode
Don't worry, u have to restore your phone through recovery mode.
Here is what u have to do;
Master reset your iphone while connected to itunes (By holding down the home and power button at the same time for 10 seconds)
the trick is, DO NOT let go of the home button, and power it back up... now u will see the itunes sign with a usb cable on the screen... Restore it through itunes, and problem solved...
Posted on Feb 24, 2010
  • 29 Answers
SOURCE: forgot my passcode to unlock my iphone what do i
try contacting your provider or entering the code number on the back of your phone
Posted on Jul 07, 2010
  • 15 Answers
SOURCE: how do i unlock my iphone i forgot the passcode
Note: This process will wipe all data from your iPhone 4. You may be able to sync most of the data back once you have restored it.
1. With the iPhone 4 disconnected from your computer, power it off. Press and hold the Power button on the top of the device for a few seconds, then slide the red slider. If this method doesn't work, press and hold the Power and Homebuttons for a few seconds until it goes off.
2. With the iPhone 4 off, press and hold the Home button while connecting it to the computer you registered it from. It should then power on.
3. Keep holding the Home button until you see a Connected to iTunes message appear on the screen.
4. Open iTunes and it should provide a message about an iPhone connected in Recovery Mode.
5. In iTunes, select the Summary tab and click Restore and follow the prompts.
When the process is finished, your iPhone 4 should be available again without the need for a password.
Posted on Jun 15, 2011
How do i unlock my apple 5c i phone?
Hello Earl. Do you want to unlock a disabled iPhone 5C?
You can actually do this with the Find My iPhone website, as long as your iPhone was registered with your Apple ID and Find My iPhone was enabled in the iCloud menu. This will only work if the iPhone is currently connected to a wireless network.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Once the reset is finished, you'll be prompted to setup your iPhone as if it were new. You'll be given the option to load a backup if you've made one in the past. Use the Setup Assistant on your device to restore the most recent backup of your device.
How to Unlock Disabled iPhone with without iTunes
Jan 10, 2017 | Apple iPhone 5c
Forgot passcode how do i unlock my phone
Generally the only way that you are going to be able to get into your iphone is plugging your phone into the computer which itunes is installed that you originally set your phone up with.
Aug 04, 2014 | Apple iPhone 5c
I forgot my pattern to unlock my Samsung 1827 can my phone be unlocked? And how do I unlock it
Didn't catch what passcode have you lost on earth. You mean the iPhone lock password? If so, go to this page - forgot iPhone passcode to get the answer. Good luck.
Apr 18, 2013 | Cell Phones
My iphone is only displaying IPhone is disabled connect to Itunes. i connect and it says that u have to unlock your passcode. how do i get to enter the passcode?
Recover it from that state with the help of my tip:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: sale-47hyk-1863377234@craigslist.org
Jul 20, 2010 | Apple iPhone 3G
Forgot my passcode
Bad News... you may have to Restore from iTunes. Here is some info from the users manual:
Passcode Lock By default, iPhone doesn’t require you to enter a passcode to unlock it. Set a passcode: Choose General > Passcode Lock and enter a 4-digit passcode, then enter the passcode again to verify it. iPhone then requires you to enter the passcode to unlock it or to display the passcode lock settings.
Turn passcode lock off: Choose General > Passcode Lock, enter your passcode, and tap Turn Passcode Off, then enter your passcode again. Change the passcode: Choose General > Passcode Lock, enter your passcode, and tap Change Passcode. Enter your passcode again, then enter and reenter your new passcode.
If you forget your passcode, you must restore the iPhone software. See “Updating and Restoring iPhone Software” on page 204.
Set how long before your passcode is required: Choose General > Passcode Lock and enter your passcode. Tap Require Passcode, then select how long iPhone can be idle before you need to enter a passcode to unlock it.
Nov 10, 2009 | Apple iPhone 3G
Forgot my personal unlock code for my i phone
Forgot password unlock iPhone backup? I did meet such problem with my new white iPhone 5! Well, it is "iPhone Backup Password Unlocker", you can go to Google search the tool iPhone Backup Unlocker and visit http://www.windowspasswordsrecovery.com/product/iphone-backup-unlocker.htm to try to use it!
Hope it also helps more users!
Jun 23, 2009 | Apple iPhone Smartphone
Cell Phones Logo
57 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
