Question about Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
Xenyx 1202fx effects want turn off - Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx
3 Suggested Answers
SOURCE: Please, I need a Behringer xenyx 1202fx list of
Here you go: _34.png
Posted on May 04, 2011
  • 1212 Answers
SOURCE: Behringer XENYX 1202FX Mixer
It is possible one of the IC's failed.
You can apply an audio signal to the input and with a small amplifier with speaker you can trace through the circuit to locate which IC failed.
The input to the small amp split iattach 2 wires pr test least leads from a meter, ground the ground lead of the little amp to the mixer chassis, and then with the other wire/test lead trace the defective channel 1 IC at a time until you lose signal.
If you download the IC's data sheet, Most likely a 4558 typse, you can speed the testing by simly testing at the amplifier inputs and output of each section of the IC. When you lose the signal, you found the offending IC- use the other channel for compairison.
Digikey has a site search, so you can enter the number on the IC to find if they carry it, or a similar IC, and who makes it- on the item specification page there is a link to the datasheet. While they may not have all of them, they have quite a few.
http://www.digikey.com
Posted on Apr 01, 2012
Testimonial: "thanks john i'm trying to fault find this board at the moment these chips apear to be simple dual opamps however a schematic would come in extreemly handy, if you know where i can get my hands on one would be nice."
How do i connect a monitor to the 1202FX mixer
Hi, you can use the Control Room outputs to give you an additional output with it's own level control but of you want a separate "mix" rather that overall level you could try the FX send & use the FX controls per channel to set the mix - depends how / if you are using the FX of course! - Else upgrade to a mixer with 2 Aux sends - use one for FX & the other for monitor :-) e.g. some of the Alesis do this! 'Good Luck!
Dec 21, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Clipping always lit
  1. Make sure nothing is plugged in.
  2. Turn the GAIN, LEVEL, and FX knobs for each channel, counter-clockwise all the way.
  3. Bring the MAIN fader all the way down.
If the signal LED's above the MAIN fader are still lit, then the board most likely has a short in it and will require repair.
If the signal LED's are dark, repeat the following on each channel...
  1. Rotate GAIN clockwise until the mark on the knob is at "12 oclock".
  2. Rotate LEVEL clockwise until the mark on the knob is at "3 oclock"
  3. Raise the MAIN fader to "0".
  4. Check LED's - if they light up then the channel you are working on is "noisy" or has a short in it.
  5. Return GAIN, LEVEL, and MAIN to "all off".
  6. Repeat with next channel.
Jan 25, 2014 | Behringer Xenyx 1202fx Mixer 12 Input 2...
Xenyx mixer effects
USERNAME OR PASSWORD WANT ME
Dec 17, 2013 | Music
1202 fx phantom power swith will not stay engaged
The mechanical push on - push off latching mechanism may have broken. Probably the switch will have to be replaced.
Sep 02, 2012 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I bought a Xenyx 1202fx roughly 9 months ago. I plugged it in following the instructions of desk to pack first, then pack to mains, but the LED display didn't show. I've heard that there's no...
If the blue power light does not light up then there is a problem with the unit or power supply. As it is less than a year from purchase I would advise returning it to the shop.
Sep 15, 2011 | Behringer Xenyx 1202fx Mixer 12 Input 2...
I have a Behringer 1202fx and I'm going to use it with a pair of Harbinger APS15. The line inputs on the APS15 are unballanced R&L RCA and XLR. The Behringer 1202fx mains are 1/4" unballanced...
Personally I would run the RCA outputs to the RCA in on the APS.
If you insist on using XLR from the APS to the board (like through a snake etc) I would higly recommend using XLR to 1/4" adapters. These things have wonderful little transformers in them (yes, wire wound transformers) that do the 1/4" to XLR conversion really nicely so that you can run your signal through the snake or just so that you don't get the hum and distortion that can be associated with unbalanced signal transfer.
You want a HI-Z unbalanced to LO-Z balanced adapter.
Not always easy to find, but if you absolutely cannot locate any, I have a couple in stock.
I suggest you look around though, because mine aren't cheap!
Feb 27, 2011 | Behringer Xenyx 2222fx Premium 22 Input...
What imput do i use for on/off footswitch
Sorry, this device does NOT have a footswitch input to control the effects processor. I would suggest using an external effects unit that does have a foot switch input using the FX send and Aux returns of this unit.
Jan 30, 2011 | Behringer Rx 1202fx 12 Channel Line and...
I am having problems with the effects. I cannot get any effect from it now. Please, help!
Make sure that BOTH the FX gain at each channel you want the FX on AND the "FX to Main" gain are turned up. Also when you select an effect push in the selection knob to activate the selection.
Jan 21, 2011 | Behringer Rx 1202fx 12 Channel Line and...
How do i hook 1202fx to computer?
just connect a baby plug to rca from the pc to the mixer respectively
Feb 14, 2010 | Behringer Xenyx 1002fx Mixer 10 Input 2...
Open Questions:
See all Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Questions
Behringer Xenyx 1002fx Mixer 10 Input 2 Bus with Efx Logo
54 people viewed this question
Top Behringer Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Are you a Behringer Music Expert? Answer questions, earn points and help others
