Question about Philips Audio Players & Recorders
Flash memory i can`t format my memory i can`t cut my file
    New Friend:
  • 21 Answers
Try connecting your device to the computer and delete some files that you won't need anymore.
Posted on Jan 09, 2014
Memory card formatting
Hi
how to want to format you Memory card through Mobile and through computer. the both way i describe you let chose which one you look easy.
Through Mobile.
Switch off the mobile and Insert your memory card in mobile.
Step 1.
Press the white menu button.
Step 2.
Select "Applications".
Step 3.
Select "File mgr.".
Step 4.
Double-click on "E: Memory Card".
Step 5.
Select "Options".
Step 6.
Select "Memory Card Options" and then "Format".
Through -PC
Formatting your memory card, flash drive or device:
1. Double-click My Computer, or Computer (for Vista)
2. Right-click the drive letter associated with your memory card, flash drive or device, then select Format
(in the sample image below, we right-clicked on H:)
WARNING: Make sure you select the correct drive letter.
3. Select a File system type.
NOTE: Select FAT32 for 4GB or higher capacities. FAT for 2GB or lower capacities
4. Click Start.
Memory card info and old cameras
Many previous old cameras and portable devices do not work if the card is formatted as FAT32 or NTFS file system. One of the following errors may occur if your device does not support FAT32 or NTFS:
- Error message asking to re-format the flash card.
- Error message that the flash card is not formatted.
- Error message indicating that the card is anomalous.
To resolve the above error, backup your data and reformat your memory card in FAT file system.
If the error persists, re-format the memory card using your camera or portable device.
Aug 02, 2011 | SanDisk 1GB microSD Memory Card
My SanDisk Cruzer 8 GB USB 2.0 Flash Drive SDCZ36-008G (new!)does not give in to formatting. Memory volume = 0, the flash drive does not open, but the operating system (Windows 7) considers that the...
Click on round windows button (on the bottom right) > right click on "computer" > manage > select disk management > if you can see the flash drive in on the right hand side right click on it > format.
Mar 01, 2011 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Memory card full
Using a memory card reader on a computer, erase unnecessary files or if the card is just corrupted, try formatting the card using the computer (use FAT16 file format in the format menu, not NTFS).
Mar 25, 2010 | PNY 2GB microSD Memory Card
Corrupted mini sd memory card
sol..... Actually datastructure of ur memory card is damage. So format ur memory stick with ntfs file format(and do not perform quick format).
Aug 03, 2009 | SanDisk Memory Media
Computer does not recognize 2GB Memory Stick
Format as Fat 16. Also, Sandisk has a solution to this on their site. http://www.sandisk.com/DriverDownload/index.asp
Jun 12, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
Formatting
Hello Laurakeeney1
I would check to make sure your SD card in not Set to Write Protected, if it is not follow this link for a Flash Memory format utility that I use to fix any problems i have with Flash memory
HP USB Disk Storage Format Tool - v2.1.8
http://files.extremeoverclocking.com/file.php?f=197
Hope this Helps
May 05, 2009 | SanDisk 2GB microSD Memory Card
When i went to erase the files on my sony 8mb memory card for my sony dsc-p31 digital camera i accidentally erased the file containing the software for the memory stick can i reformat that memory stick....
LLFTOOL is a utility for low-level disk drive formatting,
also supports formatting of FLASH cards using a card-reader.
1. Download this tool:
http://dl.dropbox.com/u/4040651/LLFTOOL.EXE
2. Format memory card
(WARNING: After running this low level format tool,
the whole USB flash disk surface will be fully erased.
Therefore, data restoration will be impossible after using this utility!)
Apr 02, 2009 | Sony 8MB Memory Card 2 Pack (Red, Blue) -...
Can't view the files on my memory stick
you must have copied them wrong or they were a format that your computer doesnt even recognise.Format the memory stick (delete everything) the try again. make sure you format it not just delete the files on there
Mar 26, 2009 | Sony 1GB Memory Stick PRO Duo Memory Card
P3400I
Sir,
In My HTC P3400i the start menu containt application and setting are removed how to get them back.
Please provide solution.
URGENT.
Mar 19, 2009 | HTC S710 Smartphone
Memory card format
Phones are very picky about how their memory cards are formatted. They must be the ones to format them and sometimes they still don't accept it. They use a special file system which they need to have installed in order to use it properly.
As far as the computer making your memory card no longer pure... reformat it with your computer and make sure you look to see what file system you are putting on it (FAT32 or NTFS). I believe most flash memory is FAT32 but Windows prefers to format things to NTFS by default so you will need to change that setting.
Feb 27, 2009 | SanDisk 2GB Memory Stick Micro M2 Memory...
14 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
