Question about KitchenAid Kt2651xww Epicurean 6-Quart Stand Mixer
How Old is KitchenAid Model KT2651XWW - KitchenAid Kt2651xww Epicurean 6-Quart Stand Mixer
My KitchenAid 9708416 will not turn on at all. It worked fine the last time I used it.
You have not supplied the model number, that is the part number for the silver trim band that goes around the motor housing. Also as well as the model number a rough idea of how old your mixer is may be relevant.
Mar 28, 2017 | KitchenAid Food Mixers
I need a flat beater for a K4-B kitchenaid mixer, probably 40 plus years old but works great. do you have one?
Have you contacted Kitchen Aid service department and asked if another flat beater from a current model will fit?
Jan 25, 2016 | KitchenAid Food Mixers
Will current speed control plate work in a KitchenAid model 3B?
The short answer is no. The newer control plate is in some ways the same and performs the same function but its physical configuration pretty much ensures that it will not function properly.
Old-type control plates sometimes show up on Ebay (few and far between).
Jun 05, 2014 | KitchenAid Food Mixers
MY kitchen Aide mixer was running alittle rough /loud and now has stop completely. It is approx 24 years old and has never had any problems. It is hard to find a local repair [place. any suggestions
Two things you can do for a 24-year old machine:
1. Replace both motor brushes (Black large plastic Caps on each side
of the Moto Housing). Without these, the motor wouldn't even run.
2. Replace the Worm Gear (the cause of the Rough Loud noises)
Download a copy of the Repair Part List from Kitchenaid.com for
your model KSM90.
Also don't forget to tighten all the screws inside the mixers and use
fresh Kitchenaid Grade Food Grease for all the gears.
Jun 21, 2011 | KitchenAid KSM90 Ultra Power Series Stand...
Kitchen Aid Manual for RRK90 mixer I need one
http://forum.kitchenaid.com/forums/pdfs/u_c_classic4.5_5qtmodels.pdf
old model k5ss
http://downloads.mendingshed.com/KitchenAid_Service_Manual.pdf
Mar 16, 2010 | KitchenAid K5SS Heavy Duty Commercial...
Mixer quit working
Quite likely you overloaded the capacity of the motor and it simply overheated. The brushes inside the motor may be burned out/corroded. I suggest putting a light load on it and seeing how it performs. Often, when this kind of thing occurs, a bit of light duty use will get the motor back into good working order. But be careful to not over-tax the unit again. There are several different KitchenAid mixers on the market, some nothing more than ornamental, all the way up to commercial-grade.
Sep 07, 2009 | KitchenAid K5SS Heavy Duty Commercial...
KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Apr 02, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Hobart N50 / KitchenAid Model G: how do i remove planetary?
you need to remove all the back screws then if it doesnt come tap it with arubber mallet it may be seized on
Nov 19, 2008 | Hobart N50 Stand Mixer
KitchenAid Kt2651xww Epicurean 6-Quart Stand Mixer Logo
Top KitchenAid Food Mixers Experts
Appliance engineer
jack arons
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
