Question about Toshiba Satellite A100-S8111TD Notebook
Timing for 1969 400 big block?
What do i set the timing for on my 1969 pontiac 400 cin. big block?
  • willmsbrt May 11, 2010
    clarify , is this fitted with electronic ignition or points i.e. standard coil ignition , if standard ignition , remove # 1 spark plug and roll over engine until piston is at top of stroke,replace plug,remove distibutor cap and check gap,clearance on points,should be quite small but open not closed,verify you have spark,DO NOT HOLD SPARK PLUG WIRE,to plug,if you do not have spark you can test coil using a temporary jumper wir to coil from battery directly to coil but remember you cannot stop the engine with key switch during this test,you have to remove the wire to shutdown
    President:
  • 2,976 Answers
Put a timing light on the number one wire and start the engine. The timing should be set for 6° before top dead center. Turn the distributor to accomplish this.
Posted on May 31, 2009
No fuel gettin to the carb
If you have a carb your fuel filter is clogged or the fuel pump is bad. Fuel pump is on front of block and follow the gas line to it the filter is in line near the carb or behind the big nut on the front of the carb use two wrenches. These brass filters plugged all the time
Dec 19, 2011 | 1984 Pontiac Firebird
I've often heard that some Pontiac engines (vintage 1980-2002) used a plastic or quiet type timing chain and sprockets. Owners of these vehicles I have talked to said that this kept them from buying...
No one has ever used plastic gears and chains. Some of the older big block models used timing gears with nylon teeth. This is true for all manufacturers and I believe ford still uses them in some engines. The disavantage to the nylon teeth was they would wear out somewhat faster, usually in the 80K-100K range. The pontiac V6 3800 engine has had steel toothed gears from 1986 to present and considered the most reliable V6 model ever built. While it is rare to actually break a timing chain under normal driving conditions, it does happen in race applications. However, when teeth and chains wear out, rough running and high fuel consumption due to poor mechanical time is the result. 350 GM engines were recommended to replace timing sets at 80K miles for optimum performance and were notorious for chewing off teeth. The aftermarket high performance replacement sets were made of cast iron or tempered steel. Double roller chain types, while noisier, lasted longer with fewer timing relasted issues. I had a 1979 firebird for 17 years with 200K+ miles on it and it still ran like a champ, so like anything else, proper maintenance and good driving habits have a huge affect on engine component life....Mike
Jun 27, 2011 | 2001 Pontiac Grand Prix
I need to know how to set the timing on a 92 pontiac bonneville
buy a haynes manual at one of those discount places or go to library and use chilton books
Nov 09, 2010 | 1992 Pontiac Bonneville
How to change the thermostat on a 3.4L engine for the 2004 Pontiac Grand Am GT
You have to locate the big hose that comes off the radiator and follow it to where it goes into the the engine block. There will be 4 bolts on the flanged housing. The thermostat is in that housing.
Mar 09, 2010 | 2004 Pontiac Grand Am
My Cin X/A stem (26.4) will not take a Cin 26.4 bar
lovely retro gear! used to have one just like it, i took screwdriver and put flat tip into slot on stem and shimmied bar into place, worked like a dream, no stress probs either.
Oct 07, 2009 | Cinelli 26.0 140mm 101 Quill Bicycle Bike...
How do I adjust my timing for a 79 Pontiac Bonneville Brougham, and if my lifters are worn is this a job that I could do myself or something I may want the shop to handle
To set the timing,unplug the vacuum line to distributer and plug. Loosen the hold down bolt and with the light set timing at 12 degrees if it is a pontiac engine,if chevy engine set at 8 degree's,if buich engine 15 degree's,if olds engine set at 20 degree's.They used all these engines in pontiac product'a in 1979.To change lifter's it's a pretty big job,I talked to ya earlier about your veh., and usually if you replace lifter's due to wear the came should really be replaced due to wear and that's a pretty big job for most. If you really want to keep your veh. for a while that is the proper repair procedure.Most shop's probably won't do one without the other to warranty their work.
Aug 11, 2009 | 1978 Pontiac Bonneville
How do you set the degree when installing a camshaft on a small block chevy engine?
install the cam shaft and line up the timing marks on the cam gear with the mark on the block
Apr 22, 2009 | Pontiac Firebird Cars & Trucks
C++ program for insertion, deletion in linked list and 2d array pls send the details for linked list so that i can understand it the best..considering me as a beginner.
program for deletion
#include<iostream.h>
void main()
int a[10],i,n,x;
cout<<"\n\t\tPROGRAM TO DELETE AN NUMBER FROM AN ARRAY";
cout<<"\nEnter the size of the array:";
cin>>n;
for(i=0;i<n;i++)
cout<<"\nEnter the number:";
cin>>a[i];
cout<<"\nEnter the position to be deleted:";
cin>>x;
for(i=x;i<n;i++)
a[i]=a[i+1];
for(i=0;i<n-1;i++)
cout<<a[i]<<" ";
Oct 13, 2008 | Computers & Internet
Wht is the solution..........following program is giving compile time error
could you please send me an example of source code for my example in school?
example
#include<stdio.h> etc....
plssss!
Oct 03, 2008 | Microsoft Windows Vista Ultimate Edition
Thermostat
On the 6-cyl 3.4L, it's under the throttle body. Just follow the large hose from the top left side (driver's side) back to the engine.
Jun 21, 2008 | 1999 Pontiac Grand Am GT
Toshiba Satellite A100-S8111TD Notebook Logo
813 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
