Question about Liebert GXT 1000MT BATT KIT 36V 1000MT (GXT2-7A48BATKIT) UPS System
Our emerson liebert GXT2000-MT is beeping along with alarm led and indication led glowing
Liebert gxt2-10000rt208 fault indicator and A + E LEDs on. Did anyone know this alarm?
I'm going to go on a limb and say the unit also has the bypass indicator on as well, is that correct? A=On bypass due to overtemperature condition & E=On bypass due to inverter failure.
I can't see in the picture or hear it but is it beeping also? 1 second beep every 2 seconds? Thats on internal bypass. If none of this is true then you have a tricky problem.
Dec 09, 2014 | Liebert Computers & Internet
How to correct fault on liebert gxt3?
Disconnect batteries. Shut off the UPS wait 5 min. If alarms returns then something is wrong with your unit
Aug 18, 2014 | Liebert UPStation GXT2700RT-208...
Dear sir, For past two days, the battery indicator
replace batteries,low capacity or charge.
cant hold charge
Aug 28, 2013 | Liebert Computers & Internet
Error light in my apc smart ups sc 1500va ups
1. Four beeps every 30seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery PowerSupplied outlets are now supplying battery power as opposed to power from theutility. If the UPS determines that the input utility power is unsafe for yourcomputer equipment, the UPS will switch to battery power.
Note: Ifthe power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will beilluminated)
This alarm indicates that a Low Batterycondition has been reached and that the UPS will soon shutdown. Once the UPStransfers to On Battery operation, it can only stay on battery for a limitedamount of time. The UPS will sound this alarm about two minutes before thebatteries are totally exhausted. Once exhausted, the UPS will shutdown and turnoff its output power to your equipment. If you hear this tone you shouldimmediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (BackUPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected anOverload condition after it has performed a self-test during start-up.
4. Continuous Two-Tone Beep
This alarm indicates a severe Overload wasdetected while the unit was on-battery operation. This tone will continue tosound until the unit shuts down.
5. Continuous Tone (On Battery LED will beflashing)
This alarm indicates that the battery-poweredoutlets are overloaded.
6. Continuous Tone (On Line and On BatteryLEDs flashing) Back UPS OFFICE 350,400, and 500 ONLY
This alarm indicates that an internal UPS faulthas occurred.
Dec 08, 2011 | APC Smart-UPS SC 1500VA UPS System
Emerson UPStation, Liebert GXT21000RT120. 2 tower battery is continuing to alarm. Bypass light is on and AC input light is on. This happened after dropping a plastic water bottle on top of the main...
Hi Tammy, this can only be done if the load is not critical....
If load is critical then shut it down first.
On bypass you will be getting one beep every min or so
Try pressing the inverter on button, there should be a single beep, and then if all is well the inverter will come back on line. All leds will then be green.
Suggest once working that it be checked to see if it will still support load during outage.
If this does not work then please post again.
In the manual there is pages of fault diagnostics which may assist, if you don't have the manual it can be downloaded from the Emerson website.
Hope this helps,thanks for using FixYa
Vote for this if you like it.
Sep 13, 2011 | Liebert Computers & Internet
Our hard wire smoke detector model i12060 just beeped really lound a few times and stopped, it glows green and flashes red every few minutes?
Change the 9V backup battery,with a new one.Push and hold the reset button for a minute or two for the alarm to to go off like about 30-40 sec. for the smoke detector to dectected the 9V backup battery power sourced.The green power LED light indicator will stop flashing also the beeping sounds too.
Jul 12, 2011 | Kidde 120-Volt Front Load Battery Smoke...
Strange noise comes out from the ups after a power cut
The Back-UPS Office unit has five different tones or alarms:
1. Four beeps every 30 seconds (On Battery LED will be illuminated)
This alarm indicates that the Battery Power Supplied outlets are now supplying battery power as opposed to power from the utility. If the UPS determines that the input utility power is unsafe for your computer equipment, the UPS will switch to battery power.
Note: If the power disturbance is brief, you may only hear one or two beeps.
2. Continuous Beeping (On Battery LED will be illuminated)
This alarm indicates that a Low Battery condition has been reached and that the UPS will soon shutdown. Once the UPS transfers to On Battery operation, it can only stay on battery for a limited amount of time. The UPS will sound this alarm about two minutes before the batteries are totally exhausted. Once exhausted, the UPS will shutdown and turn off its output power to your equipment. If you hear this tone you should immediately shutdown your computer to prevent data loss or corruption.
3. Continuous Beeps for 30 seconds (Back UPS OFFICE 250 and 280 ONLY)
This alarm indicates the unit has detected an Overload condition after it has performed a self-test during start-up.
This alarm indicates a severe Overload was detected while the unit was on-battery operation. This tone will continue to sound until the unit shuts down.
5. Continuous Tone (On Battery LED will be flashing)
This alarm indicates that the battery-powered outlets are overloaded.
6. Continuous Tone (On Line and On Battery LEDs flashing) Back UPS OFFICE 350, 400, and 500 ONLY
This alarm indicates that an internal UPS fault has occurred.
Jan 06, 2010 | APC Back-UPS ES 700 - UPS ( external ) -...
Liebert PS700MT-230
Emerson/Liebert do not release diagrams, if the u nit is less than 2yrs old it is still under warranty.
Jul 22, 2008 | Liebert PowerSure InterActive PS700MT...
Liebert GXT 1000MT BATT KIT 36V 1000MT (GXT2-7A48BATKIT) UPS System Logo
57 people viewed this question
Top Liebert Computers & Internet Experts
Computer Links
Are you a Liebert Computer and Internet Expert? Answer questions, earn points and help others
