Question about AT&T 650530003417 Cordless Phone
Handset screen display gone on BT1000 handset but backlight and phone still work
Both handsets have gone dead
Sadly that does happen tho not often .
Nov 14, 2015 | BT 4500 Cordless Phone - DECT - Satin...
The display quit working.
The CP backlights got the problem, try uninstall and install a new light bulb on the phone.
The CP still ok, just only replacing the backlight,
Mar 06, 2008 | Motorola Mobility RAZR V3
No backlights
Sadly the backlight has gone in your handset.
It is not a huge job to have fixed most local phone clinics or repair centeres can do this at a minimal cost
Jan 14, 2011 | Nokia 1110 Cellular Phone
My handset fell down yesterday and the display is gone.Though I can receive and make calls
Hello
When the handset fell down, the flex that connect the screen and the panel has shift. Get a screw driver, unscrew the phone and try to adjust the screen.
If after doing his the problem continues you need to change the screen of the phone.
Thanks
Aug 12, 2010 | Nokia 6300 Cellular Phone
The handset display cannot be seen, the backlighting is working. A580IP handset.
the display unit is not functioning... it is either the problem with the bus(wires) connecting the display and the board, or the problem with the display IC...
backlight is an ordinary led light, it will continue to work whenever there is a power supply to it...
Aug 09, 2010 | Siemens Gigaset A580 IP Cordless Phone
Acer 5810t laptop. screen gone black
Press and hold the Power button for 45 seconds to turn the laptop off.
Then, remove the battery from the battery compartment and clean the metal contacts.
Next, reinsert the Battery and try to turn it ON.
If the display still doesn't come then you may try connecting an external display to check if the Computer is able to produce display and the issue is with the backlight of the LCD screen.
wish u good luck!!!!!!!!!!!
Sep 17, 2009 | Computers & Internet
Uniden TRU888 5.8 Digital Phone Display no longer lights up
I purchased this model phone as a refurb item and also had display blanking out issues. Mine related to a problem with the battery, which new batteries fixed. Try swapping the batteries between handsets and see if the fault moves to the other handset, which will prove if it is a battery problem. Otherwise, it would seem to be an internal fault in that handset. Try and arrange repair/replacement from the seller.
Jun 21, 2009 | Uniden TRU8888 Corded Phone
My Nokia 1100 fell down and display is not working.
if you are good at opening the handset then just open the handset and adjust the display the screen correctly bcoz it will be in loose contact as it fall it might have became loose or the display might have gone one you open the handset and adjust it will work ...
once you press the display screen after opening the panel near edges and in the middle with a little pressure ...
if the display is gone then you can get the new display screen and you can replace that by your self it is easy to do it ...
the display screen of the 1100 is very cheap so no problem if it is gone means ...
if you are not good at opening then just take your cell to the service center he will do it but he may take some service charge ..
i think you can do it ,it is not so much difficult task ..
thank you
regards
-Dileep
rate my solution
Nov 14, 2008 | Nokia 1100
Re-registering the Handset is not working
The solution is this - unplug the base unit then plug it back in. After that it worked fine.
Jun 22, 2008 | Panasonic KX-TG2356 Cordless Phone
AT&T 650530003417 Cordless Phone Logo
23 people viewed this question
Top AT&T Lands Phones Experts
george  peters
george peters
Paul C.
Level 1 Expert
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
