Windows vista virus
Unable to use my computer
    President:
  • 1,996 Answers
Please follow the malware cleaning protocols in this link up through step 4 to scan your system for malware and remove any problems MBAM detects.
If you do not have an updated antivirus program running on your system, please download and install Avira personal from here as well, and run an in-depth scan of your system. If your AV licence has lapsed or expired, uninstall that application before installing Avira, as you should only have one AV on your system at a time. (It is ok to run MBAM in conjunction with other AV or anti-spyware software.)
Then report back with the results and we'll take it from there.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on May 20, 2009
  • efs_perpends
    efs_perpends May 20, 2009
    ps If you can't even get online anymore, you'll have to download the programs using another internet connected computer, burn them to disk, and install them from the cd to your desktop, where you can run the ATF cleaner, etc. If you have any trouble installing MBAM (some viruses block it's installation), simply rename the .exe file and it will setup ok. Then run a quick scan and allow it to fix any problems it finds...
Wont boot in safe mode
start your laptop before booting windows press f8 button continuously
ndows 2000 / XP users
bulb.gif If you are running Safe Mode because you cannot get into Windows, you may want to first try loading the last known good configuration.
To get into the Windows 2000 / XP Safe mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers, if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Windows 2000 or Windows XP Safe mode - If after several attempts you are unable to get into Windows 2000 or Windows XP Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Please select an option:
Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt
Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode
Start Windows Normally
Reboot
Return to OS Choices Menu
Use the up and down arrow keys to move the highlight to your choice.
Once you're done in Safe mode if you want to get back into Normal Windows restart the computer like you normally would and let it boot normally. Click here to get additional information about getting out of Safe mode.
Microsoft Windows Vista and Windows 7 users
To get into the Windows Vista and Windows 7 Safe Mode, as the computer is booting press and hold your "F8 Key" which should bring up the "Windows Advanced Options Menu" as shown below. Use your arrow keys to move to "Safe Mode" and press your Enter key.
Note: With some computers if you press and hold a key as the computer is booting you will get a stuck key message. If this occurs, instead of pressing and holding the "F8 key", tap the "F8 key" continuously until you get the startup menu.
Trouble Getting into Safe mode - If after several attempts you are unable to get into Safe Mode as the computer is booting into Windows, turn off your computer. When the computer is turned on the next time Windows should notice that the computer did not successfully boot and give you the Safe Mode screen.
Sep 27, 2011 | Lenovo G460 Laptop Computer - 06779XU...
Tip
How to Recover Your Computer from Virus Attack {XP ,VISTA ,WINDOWS 7 ,Etc }
Software 1:DiskHeal
download
this software is used to Restore the
A:folder Option (Hidden files option restore)
B:C:, D:, E, F,_ _ Etc Drive not opening when double clicked from "MY Computer" Pendrive not opening etc.
C:Task man not openning (ie to recover Task Man is disabled by your ADMINISTRATOR error")
and more............
D:Restore Registry Editor
Software 2:Autorun virus removal (can remove autorun virus form your computer)
download
A:restore Exe file error's
B:anti-virus not installing {some viruses block installation of Anti-virus software } provide solution for these problem
C:can repair Safe Mode Option{if you are unable to access Safe mode .some viruses block's the safe mode}
and more........
software 3:similar software (file size is 22MB)
download
software 4:Antivicrypt
To recover files infected by .viCrypt” extension. virus
download
4:Install antivirs software
update and do full system scan
download
5:Go to Run type Cmd and Type SFC/SCANNOW and press enter key
if your windows files are missing this command will restore the missing
files from windows CD"
make sure that you have the windows installation CD to try command
6:Install Registry cleaner
download
Registry cleaner software -delete invalid entry in the registry thus speed up your system
(please rate me)
on Jan 12, 2010 | Computers & Internet
My laptop window vista is having problem to open the window suddenly Iam unable open my computer or any window prog So pls suggest me the error
While the computer is powering press F8 in 1 seconds intervals until you get the Advanced boot menu.
Select Safe Mode with Networking and press enter
Once it is booted up try to navigate around. If it is running at normal speeds, I would say your computer is infested with viruses If it is still running really slow and won't open anything I would say you need to wipe out the computer and re-install windows. Most likely your operating system is corrupted You can try the following to fix operating system problems without a re-install
Open a command prompt (Windows Key, then type cmd ) Type chkdsk /f hit enter, it will tell you the drive is locked do you want to run on next boot. Press Y and enter.
Type sfc /SCANNOW then hit enter. Let it run though and then reboot your computer for the chkdsk to run.
If it is still really slow in safe mode then it's a re-install of windows
IF NOT SLOW IN SAFE MODE (Do this) You can try and clean up viruses in safe mode with the following free programs Run the Full Scan and remove any viruses/spyware you find MalwareBytes (http://www.malwarebytes.org/) SpyBot (http://www.safer-networking.org/en/home/index.html) Spyware Doctor (http://www.pctools.com/compare/protection/?ref=spyware_doctor_antivirus_compare_winningchallenger&gclid=CN2rsMjwlasCFQJOgwodCUtevw)
Are just a few.
I typically run through about 12 different programs on an infected computer. Then you would want to purchase some good antivirus These are the Top 3 http://www.webroot.com/En_US/index.html http://usa.kaspersky.com/ http://www.bitdefender.com/
Comment back if you have any questions
Sep 11, 2011 | Microsoft Windows Vista Ultimate Edition
Unable 2 remove viruses and unable to uninstalling AVG Anti virus.
There is an AVG removal tool here.
I would suggest MalwareBytes to remove viruses.
Mar 01, 2011 | Computers & Internet
Unable to access safe mode using f8 or msconfig because a virus has exe,
try to scan ur system using your anti-virus or if still not work you need to reset it to its factory default or reformatting your HDD...
How to Format a Computer with Windows Vista
Warning - Formatting hard drive information does not permanently erase the data. Even after a computer has been formatted, deleted files can be easily recovered. If you want to permanently wipe your hard drive by completely overwritting hard drive data, check out WipeDrive.
To format your hard disk during Windows Vista installation, you'll need to start, or boot, your computer using the Windows Vista installation disc or USB flash drive.
  1. Turn on your computer so that Windows starts normally, insert the Windows Vista installation disc, and then shut down your computer.
  2. Restart your computer.
  3. Press any key when prompted, and then follow the instructions that appear.
  4. On the Install Windows page, follow any instructions that are displayed, and then click Install now.
    • If the Install Windows page doesn't appear, and you're not asked to press any key, you might need to change some system settings. To learn how to do this, see Start Windows from a CD or DVD.
  5. On the Get important updates for installation page, we recommend getting the latest updates to help ensure a successful installation and to help protect your computer against security threats. You will need an Internet connection to get installation updates.
  6. On the Type your product key for activation page, do one of the following:
    • If you are reinstalling Windows Vista, you should enter your product key now.
    • If you are not reinstalling Windows Vista, you can skip this step.
  7. On the Please read the license terms page, if you accept the license terms, click I accept the license terms.
  8. On the Which type of installation do you want? page, click Custom.
  9. On the Where do you want to install Windows? page, click Drive options (advanced).
  10. Click the partition that you want to format and click Format
    • If you have more than one partition on this hard drive and want to get rid them to make one big drive again, then select a partition and click on the Delete option for each partition. Once you have deleted all of the partitions, select the Unallocated Space partition and click Format
  11. When you've finished formatting, click Next.
  12. Follow the instructions to finish installing Windows Vista, which include naming your computer and setting up an initial user account.
    • If you do not want to reinstall Windows Vista, you can cancel the installation at this point and keep your newly formatted drives.
Oct 03, 2010 | Computers & Internet
I have a pc that has a virus. i cannot get into my control panel and it wont install programs. how do i repair this manually
First try to install MBAM (malware bytes anti-malware) in safe mode (press f8 while the computer is booting) Boot in Safe Mode with Networking.
If that doesn't work, the easiest way would be format the hard drive with the windows disc that came with the computer. That is the best way to ensure the problem is gone. All your information will be deleted, so you will want to copy things you need or want to an external hard drive or burn them to a CD.
http://lifehacker.com/157578/geek-to-live--how-to-format-your-hard-drive-and-install-windows-xp-from-scratch
Sep 23, 2010 | Computers & Internet
I'm unable to get internet connection and trying to update my ethernet driver but every time getting a faulty message. help please.
DISABLE YOU FIREWALL AND DISABLE ALSO YOUR ANTI VIRUS IF STILL CANT CONNECT DELETE YOUR ANTI VIRUS AND REBOOT
Jun 24, 2010 | Microsoft Windows Vista Home Premium...
Windows Vista - Right-Click causes Windows Explorer to Crash
this has happened to me once or twice the only things I did was to run disk cleanup then reboot the computer. It worked for me.
Jun 28, 2009 | Microsoft Windows Vista Ultimate Edition...
JBL Platinum Series speakers won't work pls help
reinstall the audio driver for vista,and then use the speaker it will works
Aug 15, 2008 | HP JBL Platinum Computer Speakers
Computers & Internet Logo
David Payne
David Payne
