Question about Texas Instruments TI-1795 SV Calculator
How do i add/subtract running total
How do I add several numbers then get the running total when I have a negative number to figure in?
4 Suggested Answers
SOURCE: Add number of checks
on the 5660... on the printer tape there is "off" "on" IC (for item count) and GT (which might be grand total)
for every entry of $check you add the item count will total to the left of the register tape.
Posted on Jul 31, 2008
SOURCE: HELP WITH SIMPLE ADDING, SUBRACTING AND MULTIPLYING
I love that old, little calculator, the TI-1795+ (not the new one, SV).
Does anyone know where to get any more of these. I'd buy a few,
but they are probably out of production. I've had my three for years
and years and years. They still work fine.
Posted on Jan 02, 2009
lvinja
SOURCE: TI-84 problems
Ok, if your trying to do something like this: 2+2=4 then make it continue adding by 2's (6,8,10...)
What you do is after you type 2+2 and press enter, you need to press the "+" and u should see it show this "ans+" then type 2. Then this should continue adding by 2's. Hope this helped.
Posted on Mar 02, 2009
How can I get my sharp calculator to add and subtract correctly?
Could it be that it has adding machine logic and not calculator logic?
Let's do an experiment. 3+ 3+ 5-. Is the answer 1?
If so, it is working like an adding machine. Every number you enter is considered positive or negative and it keeps a running total.
Let me know if you have any questions.
Good luck.
Paul
Feb 25, 2015 | Sharp "el-2630piii desktop calculator,...
Why won't my calculator add or substract?
It looks like it may have adding machine logic.
Do this key sequence:
5 + 5+ 6-. Is the answer 4?
Each number you enter is positive or negative and it is just keeping a running total, rather than adding and subtracting numbers.
Let me know if this helps.
Good luck.
Paul
Jul 22, 2014 | Sharp EL-2630PIII Desk Calculator 12-Digit...
I want to do subtraction. But when I enter the "
There's a negative button and a minus button. I think you're accidently pressing the negative button. The actual subtraction button is the red "-" button above the "+" button. I hope this helps, but if all else fails, you can always add a negative!
Apr 16, 2011 | Canon P23-DH Calculator
I do not have the manual. If I want to add or subtract do I put the total amount in and than hit the plus or minus key ? i.e., $128,000 -10000. do I hit the minus before the amount or after? -1500....
You can download the manual from
http://downloads.canon.com/cpr/software/calculator/P170-DH-(USA-HWB).pdf
128000 - 10000 then press = or chain the calculation by pressing + or - and the number you want to add or subtract.
Sep 30, 2010 | Canon P170-DH Calculator
How to add figures and then subtract from a larger number
use the + key after each number to add the total will appear on screen. When all numbers have been added, enter number to subtract and then press - key. The subtracted number will appear in read on the paper (if two color). and then press the star key to get total.
Jul 08, 2010 | Canon P23-DHV Calculator
How do I get this calculator to substract
Big calculators work a little different than handheld calculators. Like the above commentor explained, if you have a basic "whats 100 minus 20?" You have to entered as 100 + 20 -- And when you hit the minus button at the end, it will give you the total. 100 is the positive number, and the 20 is the negative number that your subtracting. Also you can hit 20 -- 100 + and get the same total because you entering 20 as the negative and 100 as the positive, just in reverse.
Jul 27, 2009 | Casio HR-100TEPlus Calculator
How to add and subtract on a canon p23-dh v
Enter a number, then press + for positive, or - for negative.
Example,
47 +
12-
___
35
It is bass-ackward from most calculators, and you will screw up with any other calculator when you get used to it.
Just remember what value the number is that you just put in (i.e. positive or negative.)
Apr 02, 2009 | Canon P23-DHV Calculator
Tring to subtract
With an adding machine, which is what this is, you enter the number followed by the + or -. If you wanted to add 10+20, you would enter 10 then + then 20 then +. This would show your answer. If you are using the printer and you wish to see the final answer on the paper, hit the * key and your answer will print.
If you are subtracting, let's say 100-40, you would enter 100 then + then 40 then - then *. Adding machines expect you to enter long strings of numbers to total. You may have both positive and negative numbers. So, you always enter the number first followed by either positive + or negative -.
You might have 100 + 25 - 37 - 1 + 50. For that enter:
100+25+37-1-50+ then *
Different than a calculator but the same for all "adding machines". This machine should really be called an adding machine since that is the kind of input it is looking for.
Jan 13, 2009 | Canon P23-DHV Calculator
Electricity bill coding in java
First think how you would solve this problem yourself on a piece of paper. Then try programming it using the things you learned (if they've given you this assignment without teaching you to multiply, subtract and use if's, drop the course).
Well here is an idea.
Take the total kilowattage and send it to a function. What the function will do is subtract 14KW from the total Kilowattage and add the amount for the first 14KW then subtract 85KW from the total KW and add the amount for the 85KW. But once you subtract the number of KW from the total make sure to check if the total KW isn't negative, if so just break out of the function and return the total due.
Or if you have formula for how much the rate grows over how many miles.
For example lets say the rate grows by $1 every time the KW doubles you could have something like
int rate = 1; //Begining rate
int KW = 14; //First flat rate
int amount; //total amount they have to pay
while(totalKW > 0)
totalKW -= KW; //subtract the first rate
if(totalKW <= 0) //check if too much subtracted
break; //if so break
amount += rate; //add the rate to the total
rate += 1; // Add $1 to the rate every time
KW *= 2; // KW is doubled
Jan 05, 2009 | Computers & Internet
Printing Totals
The asterix (*) next to the big fat plus key prints the running total.
Just figured that out. Why doesn't Canon have a downloadable manual for this thing?
Oct 23, 2008 | Canon P23-DHV Calculator
Texas Instruments TI-1795 SV Calculator Logo
16 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
