Question about Oster Regency Controlled Power Kitchen Center Mixer Grinder Blender Salad Dough
Oster Kitchen Center repair manual
Need output rpm for each motor speed
3 Suggested Answers
greenspan
  • 1734 Answers
SOURCE: need owners manual
I didn´t find it with google. Maybe ask the experts from manualfox.com - if they don´t find it, it does not exist.
Posted on May 27, 2009
  • 10 Answers
SOURCE: oster kitchen center 5500-08a
I have not seen this problem with ours yet but if turning up the speed doesn't help (first thought would be the motor's overloading because you're using hard foods in it on a low setting). If it shuts off even under light loads, judging by the manual it's something you need to send it in for. See if there's a service center in the area. These Kitchen Centers aren't made any more and it's unlikely you can fix it yourself.
Posted on May 04, 2011
There is liquid leaking through the bearing on the base that adapts to the motor. Is there a service repair center in my area, my zip code is 60415?
Oster.com shows one Oster service center in Illinois:
(http://www.oster.com/ServiceCenters.aspx?state=Illinois)
Household Appliance Sales and Service 7034 North Milwaukee Avenue
Niles, Illinois
60714-3707
Phone: 847-647-8250
Fax: 847-647-2214
It's a roughly 45-minute drive from your zip code, according to Google Maps. You may want to call them with a description of your problem and see if they can service. There are also several locations in PA that will service Oster blenders.
Apr 30, 2011 | Oster 4093-8 Osterizer Classic Blender...
Need owners manual
May 12, 2009 | Oster 6812 / 6813 / 6814 16 Speed Blender
Problems with Oster 4172 10 Speed Blender
Most probably find a Oster 4172 manual here. Just send them a search request.
Feb 18, 2009 | Oster 4172 10 Speed Blender
Oster kitchen center 5500-08a
Sep 23, 2008 | Oster Blenders
Replace oster kitchen center base drive part
I'am the guy who posted the comment I found out how to do this.
There are 2 possible solutions the 2nd is not pretty, hope the first works for you it didn't for me.
1- The motor must be lock up, by placing a thin screwdriver through the holes in the base into the fan down into the motor,holding the screwdriver, remove the square drive from the top.The part you are trying to remove actually is screwed into a gear in the gear box, you will need a spanner wrench,(sometimes a strong pair of long nose pliers will work, engage the spanner holes,hold the screwdriver ,and try to unsrew it, you may need someone to hold the screwdriver,because it takes a lot of force to loosen it.These are regular threads,and unscew counter clockwise.
2- if #1 doesn't work-this will- but its not so pretty.The motor assembly attached to the gear box will have to be removed,it will come out as one piece
Remove the bottom plate,unplug the white wire from the speed control,and the blue- white wire from the board,also you will have to remove one of the brushes with the white -blk lead.
Now you will have to actually break off of the top plastic(bakelite)by whatever means you dream up (I actually used a small wood chisel to score a line, and crack it) once its cracked, it breaks apart easily.Once thats done turn it over and remove the four screws holding the gear box to the housing you will now be able to remove the gear-box motor assembly.
Remove the 3 screws from the top of the gear box pry the box open,remove the gear with the piece that needs to be replaced,now you need to get the piece unscrewed from the gear.I did this by locking the nurled end into a vise, and very carefully grabing the gear teeth with large channel locks(if you think of a better way thats great)it work for me,but I was very concerned about the gear teeth,you can't slip.
Try the new piece to make sure it sets all the way down to the bottom of the gear(it must or your head will be to high ,and won't lock down)if all is well,make sure everything is greased,and start re-assembly, the new coupler ,and the square drive will be the last 2 pieces assembled from the top, once again locking the motor with a small screwdriver.
Feb 11, 2008 | Blenders
Oster Regency Controlled Power Kitchen Center Mixer Grinder Blender Salad Dough Logo
186 people viewed this question
Top Oster Blenders Experts
Dan Webster
Dan Webster
Dave
Dave
Angel Joseph Jr.
Angel Joseph Jr.
Are you an Oster Blender Expert? Answer questions, earn points and help others
