Question about True T23 Refrigerator
Will not cool, blows out hot, condenser is clean.
The fan is blowing hot air in fridge, the compressor is is short cycling.
SOURCE: Fan works, just stopped cooling TRUE GDM 26
there is a leak of gas in the system,must see where the leak is, repair it then fill the gas,
Posted on Aug 21, 2009
  • 66 Answers
SOURCE: TRUE GDM 26 merchandiser has sealed lines to the
What do you mean the compressor was cleaned. It sounds to me you need to clean out the condenser coil. free it from all dust and debris. + Does the compressor work and what gas is in the system, does the condenser fan work. I'm assuming that when you say the fan works, it is the evaporator fan inside the cabinet working. You will have access the condenser fan either from the front or rear of the unit. The condenser unit is normally extracted from the rear. it should slide out but take care not to kink any of the pipework.
Posted on Apr 18, 2010
  • 135 Answers
SOURCE: compressor runs for a short
1 is freezer side ok?if it ok. it is easy. air vents blocked in either compartment.remove any objects from in front of the air vents.
2 evapor fan work ok.
3 how much frosts build up the evapor coil, if it build up to blockthe air vent. mayon the back wall of the rfrigerator self-defrost timer or deforst thermostat is bad
if it still not work. i have to see hat i an do for u. my e-mail is wongjimmysoon@qq.com
Posted on Jan 11, 2011
  • 1150 Answers
SOURCE: True back bar unit- Very old, Compressor fan
I agree. start there before investigating further.
Posted on Jan 15, 2011
heatman101
  • 43501 Answers
SOURCE: I have a model GDM-26.
The way you described the problem, I would be looking for a refrigerant leak... I think that it was low on charge and now it is so low that it will not cool at all...
Have a tech. find/fix the leak and recharge the unit...
heatman101
Posted on Jun 30, 2011
KF9000e. Why does compressor cycle at short intervals?
Yes. due to low rpm of fan motor in the condensor copil. or dirty condensor coil. I If so, replace fan capacitor.
If all good, check the seating of condensor set. It needs minimum 2mtrs open space for air throw. If not due to overheat compressor gets short cycling on and off.
Sep 07, 2015 | Amcor Heating & Cooling
Why isn't it cooling in either freezer or fridge compartments?
a lot of things can cause no cooling defrost problems defrost control board, compressor short cycling' low on freon, too much freon, air in the freon ect:
what is the model number and give me more symptoms like light's on, fans blowing, compressor clicking
Appliance 911 Sea Breeze
Aug 21, 2015 | Refrigerators
My lg gm-313sc keep on work and stop in lest than 3 minits
The refrigeration is short cycling. The cause may be due to airflow problem. There is an outside fan thalt blows across a radiator and another in the inside the fridge enclosed behind panels.
These two fans must run and blow across the refrigeration radiators. The outside one can clog with lint and dirt, the inside one can clog with ice buid up, or the fans simply quit working. Check that the fans run and that the radiator coils are clean and clear to airflow. For the outside one, paneling will need to be removed, as well for the inside one if the outside one does not do the trick.
The refrigerator compressor short cycles because it overheats. The cool refrigeration gas entering the compressor cools it and when the gas is not kept cool, the compressor may short cycle.
There may be a different problem but checking for airflow is a start.
Jan 06, 2015 | LG Refrigerators
What do I need to fix a cycling compressor fan in my Kenmore refrigerator?
The compressor fan is powered by the same contractor/relay as the compressor. It should run the same time. If it is stopping, then either an electrical problem exists or the bearings are dried up and it overheats and the internal thermal safety is kicking it out.. You could try lubricating the shaft of the motor but I suggest replacing it.
Dec 31, 2014 | Kenmore Refrigerators
Condenser Fan Shuts off after 15-20min, Compressor continues to run but gets hot
Condenser fan motor or motor wiring is bad. That compressor should never run without the fan. Good luck.
Jun 14, 2014 | Beverage-Air MT27 Beverage Cooler...
LG model LFX21960ST. No cooling in either fridge or freezer. The compressor comes on for about 7 seconds when first turned on and then will cycle on for a few seconds every few minutes. The fan in the...
There could be a loss of freon(unlikely but possible), the start capacitor for the compressor is bad (most likely) or the thermal cut off switch on the compressor is cycling from the hot compressor.
Mar 28, 2017 | LG Refrigerators
Isn't cooling, doors feel hot to touch
check the condenser fan motor,pull out the machine from the wall and then remove the back bottom panel,you'll see the condenser fan down there,make sure it's blowing,also check the condenser coil,it should be cleaned out at least once a year.next time you write it would help sending the model number and brand name.good luck.if it is the fan you can stick a regular house fan back there to keep the compressor cool until you get a new fan motor,keep the bottom panel off and just point the fan at the compressor.hope this helps.
Sep 02, 2012 | Refrigerators
Is the condenser fan blowing air over the coils? These symptoms sound like a bad condenser fan. Hope this helps.
May 13, 2012 | Refrigerators
True T23 Refrigerator Logo
52 people viewed this question
Top True Refrigerators Experts
Dennis Boxerman
John Tripp
John Tripp
Are you a True Refrigerator Expert? Answer questions, earn points and help others
