Question about Samsung Refrigerators
Samsung srl551dp not cooling fridge section - Samsung Refrigerators
  • 54 Answers
SOURCE: Indiset Fridge not cooling
If the compressor is running and not cooling then there is no refrigerant circulating in the refrigerator or no air moving across the one or both coils. No ice in the freezer section indicates that no cooling is taking place at all, pointing to a lack of refrigerant rather than poor air circulation due to a bad fan or frozen coil.
You can try a manual defrost to ensure it's not a frozen coil by unplugging the unit for several hours with doors open then starting it again. If there is still no cooling occurring you need to check the refrigerant level. If its low you will have to find and seal the leak, pressure test with nitrogen, evacuate and weigh in the correct amount and type of refrigerant listed on the unit.
Hope this helps, needless to say be sure to find a reputable qualified technician to open and service your refrigerant circuit this will make or break your unit.
Posted on Mar 15, 2008
  • 6 Answers
SOURCE: Fridge freezer over heating and is not cooling fridge section
It is normal for the middle strip to be hot. Did you check the temp setting in the fridge section?
Also - you might check for blockage in the bottom. Excessive dirt/dog hair can block the air flow.
Good luck
Posted on Jan 18, 2009
  • 327 Answers
SOURCE: The fridge section does not cool items. The Freezer is freezing
Hello,here are a couple of tips that i think can help
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer.
Thanks
Posted on May 28, 2010
woodchuck789
  • 4066 Answers
SOURCE: Hi, I have a Samsung
Most samsung have a separate evaporator coil just for the fridge side. Check it out. If it's the other kind then The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Posted on Sep 08, 2010
heatman101
  • 43501 Answers
SOURCE: my samsung fridge section stops
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Nov 25, 2010
Hi there I have a Samsung model SRL551DP upside down fridge. Recently our whole block had a power outage. When power restored fridge did not resume. Refrigerator door panel blinks the letter d only?
modern fridges do not like power surges as it burns the electronics
call in a technician to check it out and put a surge protection in the power supply cord
Apr 18, 2016 | Samsung Refrigerators
Need to turn off the alarm on my Samsung SRL551DP FRIDGE it refuses to change from 9 degrees and alarm keeps going off
You may be having cooling issues due to a defrost problem and the alarm is warning you of the problems
Appliance 911 Sea Breeze
Aug 27, 2015 | Samsung Refrigerators
Samsung cooltech needs reset to keep cooling
HI.JAMES. shot in the dark.it might work for a quick cheap fix.ok 1-get a 24 hour ac plug in timer.plug fridge into it.set timer to run for 4 hours and off for 10 minutes.it might work.let me know if it does.better then PCBs and sensors etc.good luck.ali
Jun 19, 2012 | Refrigerators
Samsung SR518DW freezer works fridge section not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 06, 2011 | Samsung Refrigerators
Need to turn off the door alarm on my srl551dp. fridge is working fine but refridgerator temp stays on 9 degress
Whats the serial number of the fridge Its on the top of the sticker in the fridge and on the sticker on the outer left side of the freezer
Mar 19, 2011 | Samsung Refrigerators
Have broken two bottom shelves in fridge door. Model no SRL551DP
Whats the serial number of the fridge. Its inside the fridge on the left on top of the sticker and also outside the left side of the freezer
Nov 08, 2010 | Samsung Refrigerators
SRL551DP, fridge stops, display on door flashing.
You most likely have a problem in the freezing/cooling circuit. Check your condenser, evaporator fans to see if they are running okay. Most likely it may be the condenser fan.
Dec 17, 2007 | Samsung CoolTech Plus / Basic Bottom Mount...
Refrigerators Logo
14 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
