Question about Kirby Ultimate G Bagged Upright Vacuum
Drive lever the neutral/ drive lever does not engage. seems loose. I have open up the bottom of gear area and have a loose bracket,how does it go back together, need a parts diagram?
  • Kirby Expert
  • 324 Answers
Assembly instructions (lots of pictures) HERE.
Posted on May 29, 2009
    Problem Solver:
  • 7 Answers
That bracket is worn.....[ part number 557689 A ]...but is tricky to reassemble....
Posted on May 21, 2009
Replacement of v belt
Instructions1 Place the riding mower on a level surface and set the emergency brake. Open the engine or tilt the seat back to gain access to the battery. Disconnect the negative battery cable with a socket. Turn off the main fuel petcock valve from the tank to the carburetor. Set the attachment clutch in the "Disengage" position. Set the motion control lever to neutral. Place the mower deck lift lever in its lowest position to drop the deck.
2 Pull the belt against the engine drive pulley, then pull upward on it and slip it off the pulley. Unclasp the small clutch retainer spring from the pulley bolt. Detach the big retaining spring and then slide the collar sleeve off. Shove the housing guide out from the br
3 Pull the retainer springs off that hold the rear suspension arms to the rear mower deck bracket. Disconnect the front link arms that hold the front of the mower deck to the chassis. Pull the lift lever to put the suspension arms at full height.
4 Slide the mower deck out from the bottom of the tractor. Tilt the mower deck and prop it up with wood blocks. Use a stiff cleaning brush to remove all mud, twigs and grass clumps. Wipe the top of the deck and undercarriage with a rag.
5 Un-thread the belt from around the idler and mandrel pulley. Place the new belt around the mandrel pulley and idler pulley first, then stretch it up to the drive pulley and loop it into the pulley grooves. Make sure the V part of the belt rests inside the pulley.
6 Use the lever to raise the suspension arms on the deck. Push the deck back under the tractor. Lower the suspension arms and replace all the retaining springs in reverse or the order in which you removed them. Slide the sleeve back into position and secure it with the spring. Reattach the spring to the anti-sway bar. Shove the housing guide back into its bracket.
7 Raise the mower deck with the lever. Reconnect the negative battery cable with a socket. Turn on the fuel petcock valve. Start the engine and engage the main drive lever. Test-drive.
THanks
Apr 02, 2012 | Vacuums
The foot pedal to go from drive to nuetral on my G series fell off and i cant seem to get it back in
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it off. Four screws hold the upper motor shell in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and remember to replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items.
Mar 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
How do you replace the drive/neutral lever (foot pedal) if it falls off? (The yellow and gray lever that you step on to put it into drive or neutral.) Not sure what happened but it just fell off. Now I...
The pedal assembly must be replaced,( part # 558401S), as it has a gear pressed to it which has come loose. The handle, switch plate, and upper motor cover must be removed first. To remove the plastic switch plate, remove it's screws and insert a flat screwdriver into the rectangular slot in it to pop it of. Four screws hold the motor cover in place. Next the switch button must be removed. The Techdrive assembly can be removed by removing the three screws on the bottom. Drop the drive down, and unhook it's belt from the gear on the end of the armature shaft. The pedal assembly can be removed by removing the remaining screw from the bottom of the drive unit. The N/D pedal has two parts - the pedal itself, and the shift cam. Observe carefully how these units fit together. After installing the new pedal and replacing the screw and washer to secure it, re-install the drive unit. The shift must be in the Drive position to install it, and replace the belt. Be sure to line up the arm on the drive unit so that it engages the slot at the base of the handle pivot and re-install the other items
Feb 28, 2011 | Kirby G5 Bagged Upright Vacuum
The tech drive has come off, how do i put it back in place.
Feb 26, 2011 | Kirby G5 Bagged Upright Vacuum
The lever came off (drive/neutral)
Feb 06, 2011 | Kirby Ultimate G Bagged Upright Vacuum
My G7D kirby vac was accidently dropped and the D & N lever came out of the machine. When I put the lever back in the hole it belongs in it is very loose and it doesn't switch from D or N.
The drive/ neutral pedal assembly must be replaced. This part is pressed together and cannot be repaired. A new assembly is about $17-$20. The power drive unit must be removed from the machine.
Jan 23, 2011 | Kirby Ultimate G Bagged Upright Vacuum
I have a Kirby G5 and need to replace the gear drive shaft, as the lever inside fell off and the shaft came out. (Common problem by the sound of it.) How do i remove the actual gearbox itself. I have...
I have never touched a Kirby vacuum before and my wife had the same issue. The neutral/drive pedal just fell out so I figured I would give it a shot to see if I could fix it and quickly figured out the 3 screws in the bottom plate for the drive unit wasn't the answer.
I was able to figure things out out after I found a parts list with diagrams at the follow web site and address:
Vac Parts Warehouse.com
http://www.vacpartswarehouse.com/category-s/2821.htm
The two parts involved are:
13. Bracket Cam Assembly Neutral Drive Pedal 557689A
16. Kirby Pedal Cam For Neutral Drive G6 558499A
Here's how to get to a point that you can get these two parts in/out of the machine.
- Remove bag and fill tube from handle and main unit
- Remove floor nozzle assembly
- Remove the handle via the two screws at the handle fork plate (these have loctite on them so needed a socket wrench with torex bits to get them out).
- Remove the plastic rear scuff plate vie the screw with the power cord anchor and screw by the Pedal Cam For Neutral Drive. Note release plastic tab in slot in the center and lift from the back and then over the base where the handle attaches.
I did not do this as I removed the the power drive assembly so I could figure out how to put the dive assembly back together. The pressed on arm that drives the cam assembly had pulled of the pedal shaft so this also made it easier to fish out the parts and experiment on positioning the arm in the right spot . I found the arm and a spring washer inside.
I assume at this point you could loosen the screw (don't remove it, it's the only one with a star lock washer on it) on the bottom plate that attaches the Bracket Cam Assembly and slide the Pedal Cam out and a new one in if you can get the part and replace it. The part was 16. Kirby Pedal Cam For Neutral Drive G6 558499A at Vac Parts Warehouse.com. The one listed on the website said it was for a G6 even though the parts listing is for a G5 so I don't know....
To continue to disassemble and take the power drive assembly out:
- Remove the 4 screws from the Cover Shell assembly - the metal top part. You do not need to remove the hinged Headlight Cap that is attached to it.
- Remove the 4 screw from the bracket assembly that has the handle attachment and forward/reverse switch. It attached by two wires. I only disconnect one and swung it to the side.
- Snap off the the on/off switch and disconnect from the Actuating Rod Foot Pedal to Power Switch.
- Remove the 3 screw from the bottom plate of the power drive assembly.
- Remove the drive belt.
- The power drive assembly will now drop out the bottom.
I just put the spring washer and arm back on the shaft and reassembled. I'll see how long that lasts before before buying the new part.
Have fun.
Aug 08, 2010 | Kirby G5 Bagged Upright Vacuum
THE NEUTRAL/DRIVE LEVER HAS COME AWAY FROM THE HOOVER AND SOME OF THE INSIDES HAVE ALSO COME AWAY. I WOULD LIKE TO KNOW HOW TO PUT IT ALL BACK TOGETHER
I dismantled the cover, withdrew the gear drive assembly and found the bits that had come loose. The mechanism that selects neutral or drive had come away from its shaft. I simply put it all back together and tightened everything back up. Works a dream again.
Jan 10, 2010 | Kirby Heritage II Vacuum
The drive on my Kirby G-5 is stuck in forward.
Motor housing will need to be removed and transmission a linkage adjusted. Take to a pro shop for this one.
Sep 08, 2009 | Kirby G5 Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
210 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Gerry Harvey
Gerry Harvey
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
