Question about Techno Source Tablets & eReaders
Jailbreak reset how do iget app
How do I delete all my google apps
You can remove apps from your device if you don't want them anymore or you need to clear memory space. If you uninstall an app you paid for, you can reinstall it later without buying it again.
Uninstall or disable apps
  1. Open your device's Settings app .
  2. Tap Apps or Application manager.
  3. Tap the app you want to uninstall. You may need to scroll to find the app.
  4. Tap Uninstall or Disable.
Uninstall vs. disable There are two ways to remove apps depending on whether you downloaded the app or if it came preinstalled on your device:
  1. Uninstall downloaded apps: If you downloaded an app from Google Play, you can completely remove it from your device.
  2. Disable preinstalled apps: Some apps come preinstalled on your device. You can disable these apps, but you can't remove them completely. After an app has been disabled, it will be hidden on your device.
Note: Disabling a system app may cause other apps to misbehave and will delete your associated data for that app.
You can find more information here:
https://support.google.com/googleplay/answer/2521768?hl=en-GB
Dec 05, 2016 | Tablets & eReaders
How can Iget my fire registered
To buy content and deliver it to your device, you'll need to connect to a wireless network and register your Fire tablet to an Amazon account. Registering also allows you to transfer purchases between devices and Kindle reading apps. To learn more about connecting to a wireless network, go to Connect Wirelessly.
  1. From Home, swipe down from the top of the screen and then tap Settings.
  2. Tap My Account.
  3. Tap Register.
    • If you already have an Amazon account: Enter your Amazon account information, and then tap Register.
    • If you do not have an Amazon account: Tap Create Account, and then follow the instructions to set up a new account.
May 01, 2016 | Amazon Kindle Fire HDX 7
How do I get back to factory settings?
http://www.androidauthority.com/google-android-quick-start-guide-314400/
could not find manufacturer website but you need an operating system manual I think. Visit above link, it may be helpful
Jun 16, 2015 | Tagital Tablets & eReaders
How do I use my SD card for internal storage?
There are a quite a few options.
  1. Open Terminal Emulator and check with the 'df' command, how much space is left on your partitions. Is /data or /system full?
  2. Goto system/apps/all > 'Sort by size to' find out which apps eat
    up the most space.
  3. Check if you have big size apps installed where you could change data location within the app to sdcard. Thinking of navigation apps and games. Every app where you have to download additional data to the actual app.
  4. Make sure you use the sdcard for media like photos (camera settings) music and video.
  5. CM has a built-in system to move apps to SD under settings/apps/on sdcard. Check apps that are big and you use rarely and are not interactive first. Reason: If you still use the USB feature those moved apps are not available to system anymore and are least likely to cause trouble.
  6. Another option is to use the app Foldermount. Use it to move certain locations to SD like the Download folder. Or the DCIM folder if the camera doesn't support sdcard location in settings.
  7. Use the app Link2SD which is able to move every bit from an app (including app data) to SD. It has a good overview on how much space an app really needs. You will have to create a separate partition on the SD card for that to work.
Mar 20, 2015 | Tablets & eReaders
Ipad apps
there are 2 different ways to delete an App on iPhone/iPad:
1) - Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner.
that's it.
2) - For devices running iOS 5 and later, there is also another way to do this:
hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-0.jpg ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-2.jpg ipad-apps-b0fxfox1xpqm1xswiisyf0vv-4-5.jpg
Jun 28, 2014 | Tablets & eReaders
Google play not downlaoding apps
Try going Settings>Accounts>Google> Tap your account> Three dots in the upper right (or press menu button) "Remove Account" ... then read your account .. then if you want, clear Play store cache and data and try it
Dec 26, 2013 | Irulu 7" 4gb Mid Google Android 2.3...
Reset my ipad
How to reset you IPad completely:
1.Go to settings and select general.
2.Scroll to the bottom and there will be a separated Reset button.
3.At the top hit reset all settings.
It will reset your IPad to factory defaults and it will start up like a brand new ipad.
Warning:
The things you had on the IPad will never come back unless you back it up to icloud (witch I highly suggest).
Dec 14, 2013 | Tablets & eReaders
Tablets & eReaders Logo
Top Techno Source Tablets & eReaders Experts
David Payne
David Payne
ray gallant
independebts
independebts
Level 1 Expert
Are you a Techno Source Tablet and eReader Expert? Answer questions, earn points and help others
